[INFO] IX67: Firmware 4.03 erhältlich
der_Gersthofer
Admin-Team
17 Apr 2004
IX67: Firmware 4.03 PRE1 (BETA!!) erhältlich
We have now put pre-release 1 of 4.03 on our site.
Pre-release 1 of 4.03 is available for IX67 only:
There will be no 4.03 release for the IX68.
This is a hidden link, the release is not public yet. In fact, as the name tells, it is only a pre-release. This is only for you guys reading IX Central!
NOTE: This pre-release is provided "as-is". Intertex does not support it officially. You cannot contact neither our resellers' nor Intertex's support with questions about it.
But of course will we try to help you through this site!
New features in pre-release 1 of 4.03:
TELEPHONE PORTS
o GUI telephony control button enhancements
- Press conference while calling a second party for immediate conference.
- Answer a call waiting by pressing conference.
- Blind transfer of an incomming call wihout answering it.
- Pressing transfer after dial will convert the dial into a transfer.
- When last connection is deleted dial tone is generated in case it was triggered by GUI hangup, otherwise hangup tone is played.
- On hook from remote side gives hangup tone for all cases.
- Ring pickup duration has its own duration which is shorter than normal ring.
o Signifficant updates to help texts
o Configuraion of numbering plans improved
o Add u-law and A-law prioritization
o Changed and improved some error and log messages
o Improved jitter buffer
o Fault tone if no WAN connection
SIP
o New configuration option "modify request-URI"
o Stability improvements
o Incoming call authentication improved
o Protocol use corrected (CANCEL is sent over TCP if INVITE was)
o Fallback on registrations corrected
o FXO prefix dialing corrected
o Recovery from configuration errors improved
o Interoperability enhancements
VPN
o Hardware acceleration added for DES and triple-DES.
OTHER
o WLAN client improved
o Display of MAC address added (SET 5 sec then ALT 4 times)
o Provisioning improved
o Stability improved for self-destined traffic when VPN enabled
o Better interoperability with some PPP/PPPoE servers
HARDWARE ACCELERATED VPN
This upgrade enables the DES/3DES hardware accelerator in your IX67.
Until now VPN encryption was done in firmware, resulting in 3DES UDP throughput of about 2.4Mbps.
With the hardware acceleration in 4.03, 3DES throughput is increased to 9.9Mbps, more than 4 times as fast as before!
AES encrypted throughput is however not affected, as the VPN accelerator hardware is DES/3DES only - AES encryption is continued to be done in firmware.
Die finale 4.03 ist nun erschienen
http://www.intertex.se/upfiles/67F403__.tar
Firmware: 4.03 date: 2007-MAY-28
Release notes:
TELEPHONE PORT FUNCTION ENHANCEMENTS
  • GUI telephony control button enhancements:
    • Press conference while calling a second party for immediate conference
    • Answer a call waiting by pressing conference
    • Blind transfer of an incomming call wihout answering it
    • Pressing transfer after dial will convert the dial into a transfer
    • When last connection is deleted dial tone is generated in case it was triggered by GUI hangup, otherwise hangup tone is played
    • On hook from remote side gives hangup tone for all cases
    • Ring pickup duration has its own duration which is shorter than normal ring
  • Signifficant updates to help texts
  • Configuraion of numbering plans improved
  • Add u-law and A-law prioritization
  • Changed and improved some error and log messages
  • Improved jitter buffer
  • Improved provisioning support
SIP HANDLING IMPROVEMENTS
  • Interoperability enhancements
  • Added "modify request-URI" configuration option to static domain forwarding
  • Bug that caused unit to crash fixed
  • Improved authentication on incoming calls
  • Protocol violation fixed
  • Fallback on registrations fixed
  • FXO prefix dialing fixed
  • Recovery from configuration errors improved
  • Adaption to other SIP equipment
  • FXS don't play fault tone if calling with no WAN connection
  • Fixed beginning of SIP log sometimes chopped off
  • SipUA now responds with 200 OK to INFO in dialog
  • Both FXS ports can now have same SIP URI, making both ring
VPN ENCRYPTION IMPROVEMENTS
  • Hardware acceleration added for DES and triple-DES
OTHER ENHANCEMENTS
  • WLAN client improved
  • Display of MAC address added (SET 5 sec then ALT 4 times)
  • Automatic firmware upgrade supported (by provisioning server)
  • Minor improvements of provisioning
  • Support for fully associated provisioning
  • Stability improved for self-destined traffic when VPN enabled
  • Better interoperability with some PPP/PPPoE servers
FURTHER INFORMATION:
Flash power-on test:
The improved power-on test of flash files now displays "FEr" (Flash Error) if any severe error is found in the flash file system of the unit that requires it to be reformatted. If your unit displays "FEr" after power-on go to the upgrade firmware page and follow instructions on how to reformat your unit and reload the firmware.
LAN SIParator: Presentation
The LAN SIParator adds SIP traversal to an existing, non SIP aware firewall. The LAN SIParator is only connected to the LAN and requires simple setup in the existing firewall and the SIP clients on the LAN. This functionality is part of the SIP Switch option or can be purchased separately.
UweS71
