Problem mit Annahme von ISDN-Gesprächen
chaos2000
Aktives Mitglied
22 Aug 2004
hallo,
ich habe das problem, das is mit asterisk keine Gespräche die über ISDN ankommen annehmen kann. Meine Konfiguration:
Asterisk mit FritzPCI an internen S0-Bus der Telefonanlage
neuste Version von chan_capi
Asteriskversion 1.0
capi.conf
; CAPI config
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
[interfaces]
msn=20,26,44
incominmsn=*
;mode=immediate
controller=1
softdtmf=1
accountcode=
context=pstn
devices=2
Beim anrufen des "Asteriskservers" bekomme ich folgende Meldung
capi debug:
CAPI Debugging Enabled
    -- CONNECT_IND ID=004 #0x6935 LEN=0033
  Controller/PLCI/NCCI            = 0x101
  CIPValue                        = 0x4
  CalledPartyNumber               = <81>26
  CallingPartyNumber              = A<80>13
  CalledPartySubaddress           = default
  CallingPartySubaddress          = default
  BC                              = <90 90 a3>
  LLC                             = default
  HLC                             = default
  AdditionalInfo                  = default
Oct 27 19:45:43 NOTICE[1085459376]: chan_capi.c:1932 capi_handle_msg: CONNECT_IND ID=004 #0x6935 LEN=0033
  CIPValue                        = 0x4
  BC                              = <90 90 a3>
  LLC                             = default
  HLC                             = default
  == CONNECT_IND (PLCI=0x101,DID=26,CID=13,CIP=0x4,CONTROLLER=0x1)
Oct 27 19:45:43 ERROR[1085459376]: chan_capi.c:2051 capi_handle_msg: did not find device for msn = 26
    -- INFO_IND ID=004 #0x6936 LEN=0017
  InfoNumber                      = 0x1e
  InfoElement                     = <81 83>
  InfoNumber                      = 0x1e
Oct 27 19:45:43 ERROR[1085459376]: chan_capi.c:1198 find_pipe: unable to find a pipe for PLCI = 0x101 MN = 0x6936
Oct 27 19:45:43 NOTICE[1085459376]: chan_capi.c:1302 pipe_msg: INFO_IND ID=004 #0x6936 LEN=0017
  InfoNumber                      = 0x1e
    -- INFO_IND ID=004 #0x6937 LEN=0018
  InfoNumber                      = 0x70
  InfoElement                     = <81>26
  InfoNumber                      = 0x70
Oct 27 19:45:43 ERROR[1085459376]: chan_capi.c:1198 find_pipe: unable to find a pipe for PLCI = 0x101 MN = 0x6937
Oct 27 19:45:43 NOTICE[1085459376]: chan_capi.c:1302 pipe_msg: INFO_IND ID=004 #0x6937 LEN=0018
  InfoNumber                      = 0x70
    -- INFO_IND ID=004 #0x6938 LEN=0016
  InfoNumber                      = 0x18
  InfoElement                     = <89>
  InfoNumber                      = 0x18
  InfoElement                     = <89>
Oct 27 19:45:43 ERROR[1085459376]: chan_capi.c:1198 find_pipe: unable to find a pipe for PLCI = 0x101 MN = 0x6938
Oct 27 19:45:43 NOTICE[1085459376]: chan_capi.c:1302 pipe_msg: INFO_IND ID=004 #0x6938 LEN=0016
  InfoNumber                      = 0x18
  InfoElement                     = <89>
    -- DISCONNECT_IND ID=004 #0x693d LEN=0014
  Reason                          = 0x0
  == DISCONNECT_IND PLCI=0x101 REASON=0
Oct 27 19:45:43 ERROR[1085459376]: chan_capi.c:1198 find_pipe: unable to find a pipe for PLCI = 0x101 MN = 0x693d
Ich hoffe Ihr hab eine Idee wo mein Fehler liegt. DANKE
P.S.: Über Asterisk ins ISDN Netz funktioniert problemlos
Hast Du eine Extension 26 definiert?
ja hab ich;
habs auch schon mit
exten => _.,1,Dial(SIP/user1)
versucht
hi,
ich hab ein ähnliches problem.
ich hoffe mal das es ueberhaupt geht,
ich wuerde gerne die komplette durchwahl als callerid/MSN mitsenden.
setcallerid hat da leider nicht geholfen.
ich hänge an einem S0 bus von einer tkom-octopus zum testen,
kann es sein das die anlage das einfach abschneidet?
cu nobody
danke
Siyar361
