problem with VPN between 2x FBF 7170 - fixed
vpe
24 Feb 2006
hello, i have little problem with VPN between 2x FBF 7170 (first.fqdn.com and second.fqdn.com represents real IP and connection is via ADSL)
Green Status in both sides show - connection OK, but ping from 192.168.177.0 LAN to 192.168.178.1 side and vice versa not reply and access to FBF (IP .1) not work too :-(
I must manually set up routes in Windows and/or FBF or how work please?
Here is configs for both sides:
This is not for Standart AVM Firmware! You have to compile Freetz first.
Is there a Way to solve this Issue with the Standart AVM VPN?
yes, i have problem with AVM VPN
http://www.avm.de/de/Service/Servic...dlagen/einsatzmoeglichkeiten.php?portal=VPNen
Connecting Remote Networks
A network, or a LAN-LAN link lends itself to situations in which geographically separate locations like branch offices are to be networked. Remote networks can be connected using FRITZ!Box.
Once two networks are connected, all devices from one network can access all of the devices in the other network. For instance, servers can be synchronized, databases compared and backups transferred.
problem fixed, how?
problem is if upgrade from .76 fw to .80 fw (not support unbridging)
If i change .178.0 subnet to different and re-setup back to .178.0, all is OK and AVM VPN WORK!!!
Maybe is some thing in my FBF setting before, i not know....
ps: i found some things:
GERMAN VPN CONFIG Ver1.0.0.7 not allow set .178.0 subnet !!!
But english version (lower Ver) allow!!! I ask - WHY is this difference?
I make corrections by hand in cfg files, but ... :mad:
now i ask - how work P2P call via AVM VPN? On destination side not reachable ports 5060 - how i must set?
vulubalulu
