- Mitglied seit
- 22 Jun 2004
- Beiträge
- 1,311
- Punkte für Reaktionen
- 0
- Punkte
- 0
Change Log
25.04.2005 Skype for Linux version 1.1.0.13
* feature: Esc closes subwindows
* feature: updated layouts of Options and Profile Editor forms
* feature: API: "OPEN CHAT chat_id" implemented
* feature: expand/collapse group with single click
* feature: Options are moved from File to Tools menu
* feature: API: added command-line options "--disable-dbus" and "--use-session-dbus"
* feature: API: added command-line option "--callto" (if another instance of Skype exists, makes API request. If not, launches, and makes a call after logging in if credentials are saved)
* feature: API: fast callto handler script for dispatching call to be placed to existing instance of Skype, or runs Skype if it isn't running
* change: API: can now run under multiple user accounts using session API bus
* change: DBus 0.23 linked statically - eliminates installation/dependency problem
* bugfix: erroneous CPU usage
* bugfix: clean up when API client disconnects (memory leaks and DBUS overload when numerous clients connect and disconnect)
* bugfix: no ringtone, if you receive incoming SI call
* bugfix: addressee starts with semicolon - empty string before username
* bugfix: possible to send duplicated contacts
* bugfix: missing information dialog while sending contacts
* bugfix: sending contacts to yourself - should be disabled
* bugfix: cannot send contacts to multiple users
* bugfix: delete call history doesn't delete history of addressbar
* bugfix: some functions should be disabled, if user blocked
* bugfix: adding user - redundant authorization request
* bugfix: Skype crashes when using "/history" shortcut
* bugfix: if you switch users, you can see previous user's missed/finished call tabs
* bugfix: writing is slow, if online status = away/NA
* bugfix: possible to receive duplicated voicemails
* bugfix: hangup not working when playing back VM greeting
* bugfix: only one instance per user
* bugfix: Skype crashes when connecting
* bugfix: activate main window when another running instance found
* bugfix: improved search by e-mails
* bugfix: contact list should scroll
* bugfix: notifications are not shown too early
Download-Links unter: http://www.skype.com/products/skype/linux/
