28.07.2005 Skype for Linux version 1.2.0.11
* feature: "Find dialog" in chat
* change: no Start tab anymore –> new event panel
* change: new voicemail icons in call list
* change: echo123 is always seen as online user
* bugfix: Can't open URL in multichat window
* bugfix: sending message to someone who is using older version of skype - cosmetic
* bugfix: Missing Services section
* bugfix: Renaming groups - duplicated counter
* bugfix: file transfer: send-file — write permission
* bugfix: file transfer: send-file — inexact error dialog
* bugfix: Changing password — it was possible to enter illegal characters
* bugfix: inexact information dialog
* bugfix: Inexact dialog content when calling to paid number
* bugfix: Authorization request should contain Call button
* bugfix: incorrect order of buttons, if you send or receive a file
* bugfix: Can't interrupt third party in conference call
* bugfix: skype's network traffic is stopped, if presence is set to offline
* bugfix: proper header selections in multichat window
* bugfix: upsell msgs to VM/SI for non-subscribers
* bugfix: profile image file in /tmp not checked properly (thanks to Giovanni Delvecchio for reporting)
* known issue: some crash scenarios exist with Find in the Chat window — e.g. if an empty string is used, an emoticon is part of the string, or a formattted phone number is part of the string (like +44201234567)
* known issue: a crash may occur if the chat window is closed while it is loading the history
* known issue: the main window redrawing may be poor in some cases, the workaround is to disable the watermark
