Skype for Windows: Aktuelle Version 1.3.0.45 (13.06.2005)
Clemens
Aktives Mitglied
1 Apr 2004
Change Log
13.06.2005 version 1.3.0.45
known issue: when you have chatted a lot, new version startup might
take several minutes
feature: improved Contact Importers
feature: Voicemail subscribers can leave voicemails to anyone
feature: animated emoticons
feature: missed events panel
feature: services panel
feature: possibility to send multiple authorization requests from one window
feature: Arabic, Hungarian, Bulgarian, Czech and Turkish languages
added
feature: improved Profile
feature: main menu -> help -> Getting Started Wizard
feature: automatically answer the call option is back
change: VM options visible to everyone
change: Receive contacts: requesting authorization through one
single form
change: removed calltab toolbar
change: added hold and mute buttons to main toolbar
change: improved chats and calls connectivity behind proxy
change: improved logging in behind proxy
change: improved Central Contact List
change: if a SkypeIn call is sent to voicemail, custom greeting is
played
change: new splash and About images
change: new language files
bugfix: current status is disabled in onlinestatus selector menus
bugfix: File Transfer toolbar button disabled if address bar does
not contain valid Skype Name
bugfix: range check errors when moving window on dual-monitor setup
bugfix: accessibilty — extra large fonts support improved
bugfix: some login and startup related issues cleared
bugfix: could not bookmark a chat without topic
bugfix: rare access violation in 'Manage blocked users'
bugfix: multiple language support in search
bugfix: trayicon did not always respond correctly to doubleclicks
bugfix: close the search tab if no results found
bugfix: status not updated when USB phone is used
bugfix: options: Sound Alert keeps playing
bugfix: call history context menu 'listen' is now visible only on voicemails
Quelle und Download: www.skype.com
Lebeat
