tftp-server (tft-hpa) für fli4l 3.1.x K2.4/2.6
Netview
IPPF-Promi
1 Apr 2004
Das tftp-server opt. von Henning Ryll mit neuen binaries für fli4l 3.1.x (V. 0.42):
Changes in 0.42:
	Try to disable path MTU discovery for TFTP connections (it's
	useless anyway.)
	Add a hack to allow the admin to specify a range of local port
	numbers to use.
	Fix local IP number handling on systems which present
	IP_RECVDSTADDR in recvmsg().
Changes in 0.41:
	Fix bug by which patterns of the form \U\1 weren't converted
	correctly.
Changes in 0.40.1:
	Solaris build fix.
Changes in 0.40:
	Fix bug which would cause "r" remapping rules to be
	incorrectly rejected.
http://www.ip-phone-forum.de/downloads.php?do=file&id=307
Neu:
Changes in 0.43:
Fix double-free error on ^c in client.
Try to deal with clients that send TFTP requests to broadcasts
(apparently some recent Sun boxes do this instead of using the
address told by DHCP.  Bad Sun!  Bad Sun!)
Portability fixes.
Neu:
Changes in 0.44:
	Allow the client to specify a range of local port numbers,
	just like the server can.
	Fix sending SIGHUP to update the regular expression table.
Neu:
Changes in 0.45:
	Add -l (literal) option to the client, to override the special
	treatment of the colon (:) character as a hostname separator.
Neu:
Changes in 0.46:
	Minor portability improvements.
Neu:
Changes in 0.47:
	Add -L option to the server to run standalone without
	detaching from the shell.
	Parallel make fix.
Neu:
Changes in 0.48:
	Unbreak -l -s in the server, which was broken in 0.47.
	Parallel make fix.
hast du noch Bedarf ?
Ich will ohnehin einen fli4l 3.3 aufsetzen und könnte das opt auf einem neuen Stand bringen, falls sich der Aufwand in Grenzen hält.
Gruß Henning
michaelwarwel
