WuChuan TM HOP1001/1002 IP phone - H.323 , SIP & MGCP
ganjamen
6 Apr 2004
hab mal wieder wieder ein weiteres VOIP telefon gefunden.
das 3 verschiedene VOIP Protokolle beherrscht : H.323 , SIP & MGCP
Laut Hersteller ist es auch verdammt billig in kleinen stückzahlen . Weit unter 100Euro.
Damit ist es mit abstand eines der preiswertesten H.323 Telefone.
Es bietet auch wesentlich mehr Funktionen als das Grandstream Telefon , z.b. 100 kurzwahlspeicher, syslog funktion.
Ich hab mal was aus der Anleitung kopiert.
Hardware
1. LCD
2. Quick Dial
3. backspace
4. Volume Key
5. +(Volume)
6. –(Volume)
7. Phone Number
8. Record
9. Play
10. unanswered Num
11. Hold 12. flash/ring
13. Redial
14. Local IP 15. Handset
16.Num Key
17. earphone
18. LED 4
● Data memory—2MB SDRAM
● Program memory—512KB or 1MB Flash memory
● AC/DC adapter—Input AC 220V,output 9V-12V DC, 500mA
 Software
● ITU-T H.323 v4 support, compatible with most H.323 v1-v4 systems
and devices;
● MGCP protocal support;
● SIP protocal support;
● Support major ITU-G.7XX Audio codec;
● DHCP support for LAN or Cable modem;
● PPPoE support for ADSL or Cable modem;
● Dynamic voice test;
● VAD (Voice activity detection);
● CNG (Comfort noise generation);
● Dynamic voice jitter buffer;
● G.168/165 compliant 16ms echo cancellation;
● Tone generation and Local DTMF re-generation according with ITU-T;
● E.164 dial plan and customized dial rules;
● 100 entries for quick dial;
● 80 entries each for missed call, answered call and dialed call;
● Adjustable volume for both handset and speaker;
● 16 function keys, background LED and states indicating lights;
5
● Settings by HTTP web browser (IE6.0);
● Advanced settings by Telnet;
● Voice prompt;
● Upgrade by FTP.
 Standard and Protocol
The WuChuanTM HOP1001/1002 supports following standards and protocol:
● IEEE 802.3 10 Base-T;
● RJ-45 connector;
● Optional calling signal of H.323 or Net2phone;
● Quick start and H.245 string;
● Outband DTMF transmit by H.245 user input or Q.931 keypad;
● Caller ID send and receive by Q.931;
● Audio codec include G.723.1 6.4k/5.3k, G.729, G.711 A/mu-law;
● TCP/IP: Internet Transport and Control Protocol;
● RTP: Real-time Transport Protocol;
● RTCP: Real-time Control Protocol;
● G.723.1、G.729 VAD/CNG economical bandwidth;
● G.165 16ms Echo cancellation;
● NTS: Network Time service;
● DTMF:DTMF Tone Generate and Detection;
● DHCP: Dynamic Host Configuration Protocol;
6
● PPPoE: Point to Point Protocol over Ethernet;
● DNS: Domain Name Server;
● Telnet: Internet's remote login protocol;
● TFTP: Trivial File Transfer protocol;
● HTTP: Hyper Text Transfer protocol.
Note WuChuanTM HOP1001/1002 net phone choose G.723.1 or G.729 audio codec
algorithm to upgrade/update the software. After upgrading/updating the
software, the phone should be restarted.
 Electric requirements
● Voltage: 9V DC
● Power: 0.5W (max.)
● Power adapter: AD/DC input 100-220V, 400mA
● Network interface: RJ-45 Ethernet Connect
 Operating requirements
● Operation temperature: 0 to 40° C (32° to 104° F)
● Storage temperature: -30° to 65° C (-22° to 149° F)
● Humidity: 10 to 95% no dew
 Size
222 x 195x 75 mm (L x W x H)
Der hersteller hat keinen vertrieb in europa und usa.
Wenn jemand kontakt mit dem hersteller aufnehmen will schickt mir ne Privatnachricht.
Kannste mal irgendeine homepage nennen. Das interessiert doch bestimmt mehrere
ICh find den NAmen eher interessant ;-)
Wu Chu bedeutet KampfKunst auf Chinesisch ;-)
Chuan bedeutet wohl Faust bin mir nichtmehr sicher kenns nur noch vom Tai Chi Chuan :)
Kommt das teil aus China? *G*
ja , aus der kommunistischen republik china ;)
idealerweise: http://www.5111soft.com/eh/e_ipphone.htm
Ja Kommunismus ist was feines! :)
Aber bisher hats kein Land geschafft das so zu machen das es taugt...
Wu chu (oder Wu Schu) bedeutet ja KampfKunst... nichd as das Telefon ein Kampf ist... *G*
ich bekomme vorrausichtlich ende nächster woche ein gerät zum testen zugeschickt ;).
Ausserdem hat die Firma auch einen Analog telefon adapter im Programm der vorraussichtlich in 2 wochen offiziell verkauft werden soll.
michaelwarwel
IPPF im Überblick
