[En] 2nd IP [PVC] (1und1), dyndns, enum combination
cgabriel
2 Sep 2006
First sorry for not being able for write German (I can understand quite good).
I have since ~1week DLS from 1und1 (16MBit, with FB 7270).
Apart from "not so good" speed (~6-7Mbit instead of 16Mbit), I have another question.
As you probably know, 1und1 has a second channel for VOIP. But I use a few other VOIP numbers, and I would like to enable ENUM.
The dyndns client only updates the Internet channel IP; the VOIP channel is not easily available (I can of course see it in the log), but used for all VOIP accounts.
That means, I can't use ENUM with the build-in dyndns client. My ENUM records point to the Internet channel IP, where no VOIP is active.
Possible options: not use the second channel (at least for my other VOIP accounts), and/or enable dyndns for the VOIP channel also.
Is there a solution?
Thanks,
Gabriel
Try to disable the 2nd PVC. If you are an "poweruser", then you will become trouble with the fone-quality. But in the normal case thats the easiest way, to work with enum. ;)
I tried in weekend my older pseudo images for re(de)branding, but it seems not to work on my 7270.
When comparing the settings, I see lots of changes and 1und1 rejects the VOIP registration.
I will search first the forum for newer info about this.
I think, an option to apply dyndns for VOIP channel would be just perfect.
Thanks,
Gabriel
DiamondExchangeNetwork
