7360v1 mit Replace Kernel - "Build failed" vmlinux.eva_pad
JohnDoe42
Aktives Mitglied
17 Mrz 2009
mit dieser .config
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6840 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
FREETZ_TYPE_7360_V1=y
# FREETZ_TYPE_7360_V2 is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7390 is not set
# FREETZ_TYPE_7490 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_EN=y
# FREETZ_TYPE_FIRMWARE_05_2X is not set
# FREETZ_TYPE_FIRMWARE_05_5X is not set
FREETZ_TYPE_FIRMWARE_06_XX=y
# FREETZ_TYPE_FIRMWARE_EWE_05_2X is not set
# FREETZ_TYPE_FIRMWARE_EWE_05_5X is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="en"
FREETZ_TYPE_7360=y
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
# Replace kernel (not available, no sources by AVM)
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS=y
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_PRIME is not set
# Remove piglet
FREETZ_REMOVE_ASSISTANT=y
FREETZ_REMOVE_ASSISTANT_SIP=y
FREETZ_REMOVE_AHA=y
FREETZ_REMOVE_AURA_USB=y
FREETZ_REMOVE_MEDIASRV=y
FREETZ_REMOVE_NAS=y
FREETZ_REMOVE_MYFRITZ=y
FREETZ_REMOVE_FHEM=y
FREETZ_REMOVE_AVM_VPN=y
# Remove brandings
# FREETZ_REMOVE_BRANDING_avme is not set
FREETZ_REMOVE_CAPIOVERTCP=y
FREETZ_REMOVE_CHRONYD=y
FREETZ_REMOVE_DECT=y
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_FTPD=y
FREETZ_REMOVE_HELP=y
# FREETZ_REMOVE_JFFS2 is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_NTFS is not set
FREETZ_REMOVE_PRINTSERV=y
FREETZ_REMOVE_PRINTSERV_MODULE=y
# FREETZ_REMOVE_RUNCLOCK is not set
FREETZ_REMOVE_SAMBA=y
FREETZ_REMOVE_SUPPORT=y
# FREETZ_REMOVE_SUPPORT_EVENTSDUMP is not set
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
FREETZ_REMOVE_TR069_HTTPSDL=y
# FREETZ_REMOVE_TR069_PROVIDERS is not set
FREETZ_REMOVE_UMTSD=y
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
FREETZ_REMOVE_VOIPD=y
FREETZ_REMOVE_TELEPHONY=y
FREETZ_REMOVE_WEBDAV=y
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_SIGNED is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_SSL_LIBS is not set
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
FREETZ_PACKAGE_STRACE=y
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
FREETZ_PACKAGE_BRIDGE_UTILS=y
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# Cifsmount (not available, needs replace kernel)
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_DROPBEAR_UTMP is not set
# FREETZ_PACKAGE_DROPBEAR_WTMP is not set
# FREETZ_PACKAGE_DROPBEAR_STATIC is not set
# FREETZ_PACKAGE_DROPBEAR_NONFREETZ is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_ISC_DHCP is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# NFS-root (not available, needs replace kernel)
# nfs-utils (not available, no sources by AVM)
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# Build OpenSSH client (ssh) (not available, provided by dropbear)
# Build OpenSSH secure copy utility (scp) (not available, provided by dropbear)
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# Build statically linked binaries ---
# FREETZ_PACKAGE_OPENSSH_STATIC is not set
# FREETZ_PACKAGE_OPENSSL is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_2 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
# FREETZ_PACKAGE_OPENVPN_POLARSSL is not set
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
# FREETZ_PACKAGE_OPENVPN_USE_V2_CGI is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PORTMAP is not set
# Point-to-Point (not available, no sources by AVM)
FREETZ_PACKAGE_PRIVOXY=y
FREETZ_PACKAGE_PRIVOXY_WITH_ADBLOCK=y
FREETZ_PACKAGE_PRIVOXY_WITH_SHARED_PCRE=y
FREETZ_PACKAGE_PRIVOXY_WITH_ZLIB=y
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TMUX is not set
FREETZ_PACKAGE_TOR=y
FREETZ_PACKAGE_TOR_GEOIP=y
# FREETZ_PACKAGE_TOR_STATIC is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
# FREETZ_PACKAGE_VSFTPD_STATIC is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_WGET=y
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
# FREETZ_PACKAGE_WGET_USE_GNUTLS is not set
# FREETZ_PACKAGE_WGET_STATIC is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
# FREETZ_PACKAGE_IPTABLES_CGI is not set
# FREETZ_PACKAGE_NHIPT is not set
# FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES is not set
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
# FREETZ_MODULE_ip_conntrack is not set
FREETZ_MODULE_nf_conntrack=y
FREETZ_MODULE_nf_conntrack_ftp=y
FREETZ_MODULE_nf_conntrack_h323=y
FREETZ_MODULE_nf_conntrack_irc=y
FREETZ_MODULE_nf_conntrack_ipv4=y
FREETZ_MODULE_nf_conntrack_pptp=y
FREETZ_MODULE_nf_conntrack_proto_gre=y
FREETZ_MODULE_nf_conntrack_tftp=y
FREETZ_MODULE_nf_defrag_ipv4=y
FREETZ_MODULE_nf_nat=y
FREETZ_MODULE_nf_nat_ftp=y
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
FREETZ_MODULE_nf_nat_tftp=y
FREETZ_MODULE_iptable_filter=y
FREETZ_MODULE_iptable_mangle=y
FREETZ_MODULE_iptable_nat=y
FREETZ_MODULE_iptable_raw=y
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
FREETZ_MODULE_ipt_ttl=y
FREETZ_MODULE_ipt_TTL=y
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
FREETZ_MODULE_xt_CLASSIFY=y
FREETZ_MODULE_xt_comment=y
FREETZ_MODULE_xt_esp=y
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
FREETZ_MODULE_xt_NFQUEUE=y
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
FREETZ_MODULE_xt_quota=y
FREETZ_MODULE_xt_realm=y
FREETZ_MODULE_xt_state=y
FREETZ_MODULE_xt_statistic=y
FREETZ_MODULE_xt_string=y
FREETZ_MODULE_xt_tcpudp=y
FREETZ_MODULE_xt_tcpmss=y
FREETZ_MODULE_xt_time=y
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
FREETZ_LIB_libipt_ah=y
FREETZ_LIB_libipt_CLUSTERIP=y
FREETZ_LIB_libipt_DNAT=y
FREETZ_LIB_libipt_ecn=y
FREETZ_LIB_libipt_ECN=y
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
FREETZ_LIB_libipt_MIRROR=y
FREETZ_LIB_libipt_NETMAP=y
FREETZ_LIB_libipt_realm=y
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
FREETZ_LIB_libipt_SAME=y
FREETZ_LIB_libipt_SNAT=y
FREETZ_LIB_libipt_ttl=y
FREETZ_LIB_libipt_TTL=y
FREETZ_LIB_libipt_ULOG=y
FREETZ_LIB_libipt_unclean=y
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
FREETZ_LIB_libxt_comment=y
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
FREETZ_LIB_libxt_CONNSECMARK=y
FREETZ_LIB_libxt_conntrack=y
FREETZ_LIB_libxt_dscp=y
FREETZ_LIB_libxt_DSCP=y
FREETZ_LIB_libxt_esp=y
FREETZ_LIB_libxt_hashlimit=y
FREETZ_LIB_libxt_helper=y
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
FREETZ_LIB_libxt_NFLOG=y
FREETZ_LIB_libxt_NFQUEUE=y
FREETZ_LIB_libxt_NOTRACK=y
FREETZ_LIB_libxt_owner=y
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
FREETZ_LIB_libxt_quota=y
FREETZ_LIB_libxt_rateest=y
FREETZ_LIB_libxt_RATEEST=y
FREETZ_LIB_libxt_sctp=y
FREETZ_LIB_libxt_SECMARK=y
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
FREETZ_LIB_libxt_statistic=y
FREETZ_LIB_libxt_string=y
FREETZ_LIB_libxt_tcpmss=y
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
FREETZ_LIB_libxt_time=y
FREETZ_LIB_libxt_tos=y
FREETZ_LIB_libxt_TOS=y
FREETZ_LIB_libxt_TRACE=y
FREETZ_LIB_libxt_u32=y
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_ZABBIX is not set
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FORWARDING=y
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# NFSD CGI (not available, no sources by AVM)
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
FREETZ_PACKAGE_OPENVPN_CGI=y
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
FREETZ_PACKAGE_RRDSTATS=y
# FREETZ_PACKAGE_RRDSTATS_CABLEMODEM is not set
# FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD is not set
FREETZ_PACKAGE_RRDSTATS_STORAGE=y
FREETZ_PACKAGE_RRDSTATS_NETWORK=y
# FREETZ_PACKAGE_RRDSTATS_DIGITEMP is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# Nettle ---------------------------------
# FREETZ_LIB_libnettle is not set
# FREETZ_LIB_libhogweed is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
# FREETZ_OPENSSL_VERSION_1 is not set
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_liblept is not set
FREETZ_LIB_libpng12=y
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libspandsp is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
FREETZ_LIB_libpcreposix=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libubacktrace=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libev is not set
FREETZ_LIB_libevent=y
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_librrd=y
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
FREETZ_KERNEL_VERSION_2_6_32_60=y
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_VR9=y
FREETZ_KERNEL_LAYOUT="vr9"
FREETZ_MODULES_KVER="2.6.32.60"
FREETZ_KERNEL_PATCHES="${FREETZ_MODULES_KVER}"
# Kernel modules (not available, no sources by AVM)
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_BUNZIP2=y
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
# FREETZ_BUSYBOX_FEATURE_TOUCH_NODEREF is not set
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
# FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_FANCY=y
FREETZ_BUSYBOX_WHICH=y
# Editors
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_FEATURE_AWK_GNU_EXTENSIONS is not set
FREETZ_BUSYBOX_CMP=y
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_FSTRIM is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_F2FS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_RFKILL is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
FREETZ_BUSYBOX_UBIMKVOL=y
FREETZ_BUSYBOX_UBIRMVOL=y
FREETZ_BUSYBOX_UBIRSVOL=y
FREETZ_BUSYBOX_UBIUPDATEVOL=y
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
# FREETZ_BUSYBOX_NC_SERVER is not set
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
# FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS is not set
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
# FREETZ_BUSYBOX_FEATURE_TFTP_GET is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_PUT is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
# FREETZ_BUSYBOX_LSOF is not set
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
FREETZ_SKIN_phoenix=y
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
# FREETZ_TARGET_UCLIBC_0_9_32 is not set
FREETZ_TARGET_UCLIBC_0_9_33=y
# CAUTION: Usage of an uClibc version higher than that used by AVM may lead to an unstable box
FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace=y
# FREETZ_TARGET_UCLIBC_REQUIRES_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.33.2"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="4622c6e00b05f6369ed3d777acb57ad2"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r11090"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="0f312a36c93b4de8b12fbfc97d6f4905"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="80bab95f103b2ad29e1af07ff0006e20"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7360_v1/firmware/english"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7360.en-de-es-it-fr.111.06.04.image"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
FREETZ_DL_SOURCE_MD5="10ab64d2e3436e36e4068ae2462508c1"
# FREETZ_AVM_HAS_LABOR is not set
FREETZ_AVM_HAS_FW6XX=y
FREETZ_AVM_HAS_FW55X=y
FREETZ_AVM_HAS_FW52X=y
# FREETZ_AVM_HAS_FW4XX is not set
FREETZ_AVM_HAS_FWEWE_05_2X=y
FREETZ_AVM_HAS_FWEWE_05_5X=y
# FREETZ_AVM_HAS_LANG_DE is not set
# FREETZ_AVM_HAS_LANG_A_CH is not set
FREETZ_AVM_HAS_LANG_EN=y
# FREETZ_AVM_HAS_LANG_IT is not set
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_CIFS_SUPPORT_NEEDS_REPLACE_KERNEL=y
# FREETZ_CIFS_SUPPORT_AVAILABLE is not set
# FREETZ_NFS_SUPPORT_NEEDS_REPLACE_KERNEL is not set
# FREETZ_NFS_SUPPORT_AVAILABLE is not set
# FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE is not set
FREETZ_AVM_HAS_AR7CFG_V12_MIN=y
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_PIGLET_ISDN is not set
# FREETZ_AVM_HAS_PIGLET_POTS is not set
FREETZ_AVM_HAS_PTY_SUPPORT=y
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_SOCAT is not set
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
# FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
FREETZ_AVM_HAS_JFFS2=y
# FREETZ_AVM_HAS_JUNK_BYTES is not set
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_AHA=y
# FREETZ_AVM_HAS_TEMPERATURE_SENSOR is not set
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7490_06_01=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_06_XX_MIN=y
FREETZ_AVM_VERSION_06_XX=y
FREETZ_AVM_VERSION_STRING="7490_06.01"
FREETZ_TYPE_PREFIX="7360_v1"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_5X"
bekomme ich beim Kompilieren folgenden Fehler:
 mips-unknown-linux-gnu-ld  -m elf32btsmip   -r -o net/core/built-in.o net/core/sock.o net/core/request_sock.o net/core/skbuff.o net/core/iovec.o net/core/datagram.o net/core/stream.o net/core/scm.o net/core/gen_stats.o net/core/gen_estimator.o net/core/net_namespace.o net/core/secure_seq.o net/core/sysctl_net_core.o net/core/skb_dma_map.o net/core/dev.o net/core/ethtool.o net/core/dev_mcast.o net/core/dst.o net/core/netevent.o net/core/neighbour.o net/core/rtnetlink.o net/core/utils.o net/core/link_watch.o net/core/filter.o net/core/net-sysfs.o net/core/generic-ct.o
make[1]: *** [net] Fehler 2
make[1]: Verlasse Verzeichnis '/home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/linux-2.6.32'
ERROR: Build failed.
make: *** [source/kernel/ref-vr9-7490_06.01/linux-2.6.32/vmlinux.eva_pad] Fehler 1
Ein auf der 05.51er-FW basierendes Image ist vorher sauber gelaufen, ein make kernel-dirclean hatte ich vorher schon angestoßen.
Hat jemand eine Idee, woran das liegen könnte ?
Grüße,
JD.
In deinem Log ist kein Fehler zu sehen.
Deshalb hatte ich den Teil "weiter oben" mit gepostet.
Aber hier sicherheitshalber das ganze Log:
make -f scripts/Makefile.build obj=net/avm_pa
make -f scripts/Makefile.build obj=net/bluetooth
make -f scripts/Makefile.build obj=net/bluetooth/bnep
make -f scripts/Makefile.build obj=net/bluetooth/rfcomm
make -f scripts/Makefile.build obj=net/bridge
make -f scripts/Makefile.build obj=net/core
make -f scripts/Makefile.build obj=net/ethernet
make -f scripts/Makefile.build obj=net/ieee802154
make -f scripts/Makefile.build obj=net/ipv4
  mips-unknown-linux-gnu-gcc -Wp,-MD,net/ipv4/.ip_output.o.d  -nostdinc -isystem /home/john/freetz-trunk-7360/toolchain/build/mips_gcc-4.6.4/mips-unknown-linux-gnu/bin/../lib/gcc/mips-unknown-linux-gnu/4.6.4/include -Iinclude  -I/home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/linux-2.6.32/arch/mips/include -include include/linux/autoconf.h -D__KERNEL__ -D"VMLINUX_LOAD_ADDRESS=0xFFFFFFFF80002000" -D"DATAOFFSET=0" -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -Wno-error=unused-but-set-variable -Os -freorder-blocks-and-partition -ffunction-sections -falign-functions=32 -falign-loops=32 -falign-jumps=32 -fstrict-volatile-bitfields -mno-check-zero-division -mabi=32 -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -ffreestanding -march=34kc -U_MIPS_ISA -D_MIPS_ISA=_MIPS_ISA_MIPS32 -Wa,-march=34kc -Wa,--trap -Iarch/mips/include/asm/mach-infineon -I/home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/linux-2.6.32/arch/mips/include/asm/mach-generic -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -g -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack   -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(ip_output)"  -D"KBUILD_MODNAME=KBUILD_STR(ip_output)"  -c -o net/ipv4/ip_output.o net/ipv4/ip_output.c
net/ipv4/ip_output.c:84:1: error: unknown type name 'IFX_int32_t'
In file included from include/net/netfilter/nf_conntrack_tuple.h:13:0,
                 from include/linux/netfilter/nf_conntrack_dccp.h:28,
                 from include/net/netfilter/nf_conntrack.h:23,
                 from include/net/ifx_ppa_stack_al.h:40,
                 from include/net/ifx_ppa_api.h:77,
                 from net/ipv4/ip_output.c:85:
include/linux/netfilter/x_tables.h: In function 'cpu_port_extended_cfg_get':
include/linux/netfilter/x_tables.h:456:1: error: section attribute cannot be specified for local variables
include/linux/netfilter/x_tables.h:471:20: error: invalid storage class for function 'xt_info_rdlock_bh'
include/linux/netfilter/x_tables.h:481:20: error: invalid storage class for function 'xt_info_rdunlock_bh'
include/linux/netfilter/x_tables.h:495:20: error: invalid storage class for function 'xt_info_wrlock'
include/linux/netfilter/x_tables.h:500:20: error: invalid storage class for function 'xt_info_wrunlock'
include/linux/netfilter/x_tables.h:508:29: error: invalid storage class for function 'ifname_compare_aligned'
In file included from include/linux/netfilter/nf_conntrack_dccp.h:28:0,
include/net/netfilter/nf_conntrack_tuple.h:125:20: error: invalid storage class for function 'nf_ct_dump_tuple_ip'
include/net/netfilter/nf_conntrack_tuple.h:135:20: error: invalid storage class for function 'nf_ct_dump_tuple_ipv6'
include/net/netfilter/nf_conntrack_tuple.h:145:20: error: invalid storage class for function 'nf_ct_dump_tuple'
include/net/netfilter/nf_conntrack_tuple.h:169:20: error: invalid storage class for function '__nf_ct_tuple_src_equal'
include/net/netfilter/nf_conntrack_tuple.h:177:20: error: invalid storage class for function '__nf_ct_tuple_dst_equal'
include/net/netfilter/nf_conntrack_tuple.h:185:20: error: invalid storage class for function 'nf_ct_tuple_equal'
include/net/netfilter/nf_conntrack_tuple.h:193:1: error: invalid storage class for function 'nf_ct_tuple_mask_equal'
include/net/netfilter/nf_conntrack_tuple.h:201:1: error: invalid storage class for function 'nf_ct_tuple_src_mask_cmp'
include/net/netfilter/nf_conntrack_tuple.h:224:1: error: invalid storage class for function 'nf_ct_tuple_mask_cmp'
In file included from include/net/ifx_ppa_stack_al.h:40:0,
include/net/netfilter/nf_conntrack.h:157:1: error: invalid storage class for function 'nf_ct_tuplehash_to_ctrack'
include/net/netfilter/nf_conntrack.h:163:25: error: invalid storage class for function 'nf_ct_l3num'
include/net/netfilter/nf_conntrack.h:168:24: error: invalid storage class for function 'nf_ct_protonum'
include/net/netfilter/nf_conntrack.h:180:27: error: invalid storage class for function 'nf_ct_net'
include/net/netfilter/nf_conntrack.h:202:1: error: invalid storage class for function 'nf_ct_get'
include/net/netfilter/nf_conntrack.h:209:20: error: invalid storage class for function 'nf_ct_put'
include/net/netfilter/nf_conntrack.h:265:20: error: invalid storage class for function 'nf_ct_refresh_acct'
include/net/netfilter/nf_conntrack.h:274:20: error: invalid storage class for function 'nf_ct_refresh'
include/net/netfilter/nf_conntrack.h:287:20: error: invalid storage class for function 'nf_ct_kill_acct'
include/net/netfilter/nf_conntrack.h:295:20: error: invalid storage class for function 'nf_ct_kill'
include/net/netfilter/nf_conntrack.h:319:19: error: invalid storage class for function 'nf_ct_is_confirmed'
include/net/netfilter/nf_conntrack.h:324:19: error: invalid storage class for function 'nf_ct_is_dying'
include/net/netfilter/nf_conntrack.h:329:19: error: invalid storage class for function 'nf_ct_is_untracked'
net/ipv4/ip_output.c:136:1: error: non-static declaration of 'ip_local_out' follows static declaration
net/ipv4/ip_output.c:126:5: note: previous definition of 'ip_local_out' was here
net/ipv4/ip_output.c:139:12: error: invalid storage class for function 'ip_dev_loopback_xmit'
net/ipv4/ip_output.c:150:19: error: invalid storage class for function 'ip_select_ttl'
net/ipv4/ip_output.c:199:1: error: non-static declaration of 'ip_build_and_send_pkt' follows static declaration
net/ipv4/ip_output.c:163:5: note: previous definition of 'ip_build_and_send_pkt' was here
net/ipv4/ip_output.c:201:19: error: invalid storage class for function 'ip_finish_output2'
net/ipv4/ip_output.c:254:19: error: invalid storage class for function 'ip_skb_dst_mtu'
net/ipv4/ip_output.c:262:12: error: invalid storage class for function 'ip_finish_output'
net/ipv4/ip_output.c:466:13: error: invalid storage class for function 'ip_copy_metadata'
net/ipv4/ip_output.c:781:1: error: non-static declaration of 'ip_fragment' follows static declaration
net/ipv4/ip_output.c:519:5: note: previous definition of 'ip_fragment' was here
net/ipv4/ip_output.c:801:1: error: invalid storage class for function 'csum_page'
net/ipv4/ip_output.c:811:19: error: invalid storage class for function 'ip_ufo_append_data'
net/ipv4/ip_output.c:1304:13: error: invalid storage class for function 'ip_cork_release'
net/ipv4/ip_output.c:1434:12: error: invalid storage class for function 'ip_reply_glue_bits'
net/ipv4/ip_output.c:1767:1: error: non-static declaration of 'ip_generic_getfrag' follows static declaration
net/ipv4/ip_output.c:784:1: note: previous definition of 'ip_generic_getfrag' was here
net/ipv4/ip_output.c:1768:1: error: non-static declaration of 'ip_queue_xmit' follows static declaration
net/ipv4/ip_output.c:377:5: note: previous definition of 'ip_queue_xmit' was here
net/ipv4/ip_output.c:1769:1: error: non-static declaration of 'ip_send_check' follows static declaration
net/ipv4/ip_output.c:105:17: note: previous definition of 'ip_send_check' was here
net/ipv4/ip_output.c:1772:1: error: non-static declaration of 'ip_mc_output' follows static declaration
net/ipv4/ip_output.c:283:5: note: previous definition of 'ip_mc_output' was here
net/ipv4/ip_output.c:1774:1: error: expected declaration or statement at end of input
net/ipv4/ip_output.c:102:5: warning: unused variable 'sysctl_ip_default_ttl' [-Wunused-variable]
include/net/ifx_ppa_api.h:2664:16: warning: unused variable 'vcc_map_skb_prio_qos_queue' [-Wunused-variable]
include/net/ifx_ppa_api.h:2654:16: warning: unused variable 'vcc_set_nr_qos_queues' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1137:21: warning: unused variable 'ppa_get_ip4ip6_phyif_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1124:21: warning: unused variable 'ppa_get_6rd_phyif_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1110:18: warning: unused variable 'ppa_get_ip4ip6_dmac_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1096:18: warning: unused variable 'ppa_get_6rd_dmac_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1083:18: warning: unused variable 'ifx_ppa_hook_get_port_mib' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1069:18: warning: unused variable 'ifx_ppa_hook_get_dsl_mib' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1054:18: warning: unused variable 'ifx_ppa_hook_quick_del_multifield_flow' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1039:18: warning: unused variable 'ifx_ppa_hook_del_multifield_flow' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1026:18: warning: unused variable 'ifx_ppa_hook_get_multifield_flow' [-Wunused-variable]
include/net/ifx_ppa_hook.h:1012:18: warning: unused variable 'ifx_ppa_hook_add_multifield_flow' [-Wunused-variable]
include/net/ifx_ppa_hook.h:997:18: warning: unused variable 'ifx_ppa_hook_get_multifield_max_flow' [-Wunused-variable]
include/net/ifx_ppa_hook.h:987:18: warning: unused variable 'ifx_ppa_hook_get_multifield_status' [-Wunused-variable]
include/net/ifx_ppa_hook.h:973:18: warning: unused variable 'ifx_ppa_hook_multifield_control' [-Wunused-variable]
include/net/ifx_ppa_hook.h:956:18: warning: unused variable 'ifx_ppa_hook_reset_qos_wfq' [-Wunused-variable]
include/net/ifx_ppa_hook.h:941:18: warning: unused variable 'ifx_ppa_hook_get_qos_wfq' [-Wunused-variable]
include/net/ifx_ppa_hook.h:925:18: warning: unused variable 'ifx_ppa_hook_set_qos_wfq' [-Wunused-variable]
include/net/ifx_ppa_hook.h:909:18: warning: unused variable 'ifx_ppa_hook_get_ctrl_qos_wfq' [-Wunused-variable]
include/net/ifx_ppa_hook.h:894:18: warning: unused variable 'ifx_ppa_hook_set_ctrl_qos_wfq' [-Wunused-variable]
include/net/ifx_ppa_hook.h:875:18: warning: unused variable 'ifx_ppa_hook_reset_qos_rate' [-Wunused-variable]
include/net/ifx_ppa_hook.h:860:18: warning: unused variable 'ifx_ppa_hook_get_qos_rate' [-Wunused-variable]
include/net/ifx_ppa_hook.h:843:18: warning: unused variable 'ifx_ppa_hook_set_qos_rate' [-Wunused-variable]
include/net/ifx_ppa_hook.h:826:18: warning: unused variable 'ifx_ppa_hook_get_ctrl_qos_rate' [-Wunused-variable]
include/net/ifx_ppa_hook.h:811:18: warning: unused variable 'ifx_ppa_hook_set_ctrl_qos_rate' [-Wunused-variable]
include/net/ifx_ppa_hook.h:794:18: warning: unused variable 'ifx_ppa_hook_get_qos_mib' [-Wunused-variable]
include/net/ifx_ppa_hook.h:780:18: warning: unused variable 'ifx_ppa_hook_get_qos_qnum' [-Wunused-variable]
include/net/ifx_ppa_hook.h:767:19: warning: unused variable 'ppa_hook_wan_mii0_vlan_ranges_get_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:752:19: warning: unused variable 'ppa_hook_wan_mii0_vlan_range_del_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:737:19: warning: unused variable 'ppa_hook_wan_mii0_vlan_range_add_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:723:18: warning: unused variable 'ppa_hook_get_ifid_for_netif_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:710:21: warning: unused variable 'ppa_hook_get_netif_for_ppa_ifid_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:697:18: warning: unused variable 'ppa_hook_directpath_rx_restart_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:678:18: warning: unused variable 'ppa_hook_directpath_rx_stop_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:661:18: warning: unused variable 'ppa_hook_directpath_send_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:636:18: warning: unused variable 'ppa_hook_directpath_register_dev_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:616:18: warning: unused variable 'ppa_hook_get_if_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:600:18: warning: unused variable 'ppa_hook_del_if_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:584:18: warning: unused variable 'ppa_hook_add_if_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:568:18: warning: unused variable 'ppa_hook_get_if_mac_address_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:553:18: warning: unused variable 'ppa_hook_set_if_mac_address_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:538:18: warning: unused variable 'ppa_hook_get_accel_stats_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:520:18: warning: unused variable 'ppa_hook_get_if_stats_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:503:18: warning: unused variable 'ppa_hook_vlan_filter_del_all_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:490:18: warning: unused variable 'ppa_hook_vlan_filter_get_all_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:474:18: warning: unused variable 'ppa_hook_vlan_filter_del_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:459:18: warning: unused variable 'ppa_hook_vlan_filter_add_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:444:18: warning: unused variable 'ppa_hook_get_bridge_if_vlan_config_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:428:18: warning: unused variable 'ppa_hook_set_bridge_if_vlan_config_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:412:18: warning: unused variable 'ppa_hook_bridge_enable_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:398:18: warning: unused variable 'ppa_hook_set_bridge_entry_timeout_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:382:18: warning: unused variable 'ppa_hook_bridge_entry_inactivity_status_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:366:18: warning: unused variable 'ppa_hook_bridge_entry_hit_time_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:350:18: warning: unused variable 'ppa_hook_bridge_entry_delete_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:336:18: warning: unused variable 'ppa_hook_bridge_entry_add_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:315:18: warning: unused variable 'ppa_hook_set_inactivity_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:301:18: warning: unused variable 'ppa_hook_inactivity_status_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:288:18: warning: unused variable 'ppa_hook_multicast_pkt_srcif_add_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:272:18: warning: unused variable 'ppa_hook_mc_entry_get_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:257:18: warning: unused variable 'ppa_hook_mc_entry_modify_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:241:18: warning: unused variable 'ppa_hook_mc_group_get_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:226:18: warning: unused variable 'ppa_hook_mc_group_update_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:206:18: warning: unused variable 'ppa_hook_session_get_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:190:18: warning: unused variable 'ppa_hook_session_modify_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:162:18: warning: unused variable 'ppa_hook_session_del_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:148:18: warning: unused variable 'ppa_hook_session_add_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:119:18: warning: unused variable 'ppa_hook_get_status_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:97:18: warning: unused variable 'ppa_hook_enable_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:74:15: warning: unused variable 'ppa_hook_exit_fn' [-Wunused-variable]
include/net/ifx_ppa_hook.h:65:18: warning: unused variable 'ppa_hook_init_fn' [-Wunused-variable]
include/net/ifx_ppa_api.h:2636:19: warning: unused variable 'g_ppa_min_hits' [-Wunused-variable]
include/net/ifx_ppa_api.h:2635:19: warning: unused variable 'g_ppa_ppa_mtu' [-Wunused-variable]
include/net/ifx_ppa_api_directpath.h:195:35: warning: unused variable 'g_ppe_directpath_data' [-Wunused-variable]
include/net/netfilter/nf_conntrack.h:336:21: warning: unused variable 'nf_conntrack_max' [-Wunused-variable]
include/net/netfilter/nf_conntrack.h:335:21: warning: unused variable 'nf_conntrack_htable_size' [-Wunused-variable]
include/net/netfilter/nf_conntrack.h:301:14: warning: unused variable 'nf_ct_nat_offset' [-Wunused-variable]
include/net/netfilter/ipv6/nf_conntrack_ipv6.h:21:25: warning: unused variable 'nf_ct_ipv6_sysctl_table' [-Wunused-variable]
include/net/netfilter/ipv6/nf_conntrack_ipv6.h:8:36: warning: unused variable 'nf_conntrack_l4proto_icmpv6' [-Wunused-variable]
include/net/netfilter/ipv6/nf_conntrack_ipv6.h:7:36: warning: unused variable 'nf_conntrack_l4proto_udp6' [-Wunused-variable]
include/net/netfilter/ipv6/nf_conntrack_ipv6.h:6:36: warning: unused variable 'nf_conntrack_l4proto_tcp6' [-Wunused-variable]
include/net/netfilter/ipv6/nf_conntrack_ipv6.h:4:36: warning: unused variable 'nf_conntrack_l3proto_ipv6' [-Wunused-variable]
include/net/netfilter/ipv4/nf_conntrack_ipv4.h:17:36: warning: unused variable 'nf_conntrack_l4proto_icmp' [-Wunused-variable]
include/net/netfilter/ipv4/nf_conntrack_ipv4.h:16:36: warning: unused variable 'nf_conntrack_l4proto_udp4' [-Wunused-variable]
include/net/netfilter/ipv4/nf_conntrack_ipv4.h:15:36: warning: unused variable 'nf_conntrack_l4proto_tcp4' [-Wunused-variable]
include/net/netfilter/ipv4/nf_conntrack_ipv4.h:13:36: warning: unused variable 'nf_conntrack_l3proto_ipv4' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:129:23: warning: unused variable 'nf_nat_sdp_media_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:124:23: warning: unused variable 'nf_nat_sdp_session_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:118:23: warning: unused variable 'nf_nat_sdp_port_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:111:23: warning: unused variable 'nf_nat_sdp_addr_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:105:23: warning: unused variable 'nf_nat_sip_expect_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_sip.h:102:23: warning: unused variable 'nf_nat_sip_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:84:14: warning: unused variable 'nat_q931_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:77:14: warning: unused variable 'nat_callforwarding_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:72:14: warning: unused variable 'nat_h245_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:67:14: warning: unused variable 'nat_t120_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:59:14: warning: unused variable 'nat_rtp_rtcp_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:54:14: warning: unused variable 'set_ras_addr_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:49:14: warning: unused variable 'set_sig_addr_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:44:14: warning: unused variable 'set_h225_addr_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_h323.h:39:14: warning: unused variable 'set_h245_addr_hook' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_pptp.h:320:3: warning: unused variable 'nf_nat_pptp_hook_expectfn' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_pptp.h:316:3: warning: unused variable 'nf_nat_pptp_hook_exp_gre' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_pptp.h:310:3: warning: unused variable 'nf_nat_pptp_hook_inbound' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_pptp.h:304:3: warning: unused variable 'nf_nat_pptp_hook_outbound' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_pptp.h:7:26: warning: unused variable 'pptp_msg_name' [-Wunused-variable]
include/linux/netfilter/nf_conntrack_ftp.h:38:23: warning: unused variable 'nf_nat_ftp_hook' [-Wunused-variable]
net/ipv4/ip_output.c:1774:1: warning: control reaches end of non-void function [-Wreturn-type]
make[3]: *** [net/ipv4/ip_output.o] Fehler 1
make[2]: *** [net/ipv4] Fehler 2
make[1]: mkdir -p /home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/bin/
*** Warte auf noch nicht beendete Prozesse...
cp drivers/net/avm_cpmac/common/supportdata.avmnet /home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/bin/supportdata.avmnet
chmod +x /home/john/freetz-trunk-7360/source/kernel/ref-vr9-7490_06.01/bin/supportdata.avmnet
make -f scripts/Makefile.build obj=drivers/pci
make -f scripts/Makefile.build obj=drivers/pci/pcie
make -f scripts/Makefile.build obj=drivers/pci/pcie/aer
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/lib
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/lib/notify_avmnet
make -f scripts/Makefile.build obj=drivers/platform
make -f scripts/Makefile.build obj=drivers/rtc
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/management
make -f scripts/Makefile.build obj=drivers/net/ifxmips_ppa
make -f scripts/Makefile.build obj=drivers/net/ifxmips_ppa/vectoring
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/phy
   mips-unknown-linux-gnu-ld  -m elf32btsmip   -r -o drivers/net/avm_cpmac/common/built-in.o drivers/net/avm_cpmac/common/avmnet_config.o drivers/net/avm_cpmac/common/avmnet_common.o drivers/net/avm_cpmac/common/avmnet_multicast.o
make -f scripts/Makefile.build obj=drivers/net/ifxmips_switch_api
rm drivers/net/avm_cpmac/common/avmnet_config.o
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/switch
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/switch/ifx
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/switch/ifx/7port
make -f scripts/Makefile.build obj=drivers/scsi
make -f scripts/Makefile.build obj=drivers/net/nlaudio
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/switch/ifx/common
make -f scripts/Makefile.build obj=drivers/serial
make -f scripts/Makefile.build obj=drivers/net/avm_cpmac/switch/ifx/vr9
make -f scripts/Makefile.build obj=drivers/spi
   mips-unknown-linux-gnu-ld  -m elf32btsmip   -r -o drivers/net/avm_cpmac/built-in.o drivers/net/avm_cpmac/common/built-in.o drivers/net/avm_cpmac/switch/built-in.o drivers/net/avm_cpmac/phy/built-in.o drivers/net/avm_cpmac/management/built-in.o
make -f scripts/Makefile.build obj=drivers/net/usb
make -f scripts/Makefile.build obj=drivers/ssb
make -f scripts/Makefile.build obj=drivers/usb
make -f scripts/Makefile.build obj=drivers/net/wireless
make -f scripts/Makefile.build obj=drivers/usb/class
make -f scripts/Makefile.build obj=drivers/usb/core
make -f scripts/Makefile.build obj=drivers/usb/early
make -f scripts/Makefile.build obj=drivers/usb/host
   mips-unknown-linux-gnu-ld  -m elf32btsmip   -r -o drivers/net/built-in.o drivers/net/mii.o drivers/net/avm_cpmac/built-in.o drivers/net/Space.o drivers/net/loopback.o drivers/net/tun.o drivers/net/wireless/built-in.o drivers/net/ifxmips_switch_api/built-in.o drivers/net/ifxmips_ppa/built-in.o
make -f scripts/Makefile.build obj=drivers/usb/misc
make -f scripts/Makefile.build obj=drivers/usb/mon
make -f scripts/Makefile.build obj=drivers/usb/musb
make -f scripts/Makefile.build obj=drivers/usb/serial
make -f scripts/Makefile.build obj=drivers/usb/storage
make -f scripts/Makefile.build obj=drivers/video
make -f scripts/Makefile.build obj=drivers/video/backlight
make -f scripts/Makefile.build obj=drivers/video/console
make -f scripts/Makefile.build obj=drivers/video/display
   mips-unknown-linux-gnu-ld  -m elf32btsmip   -r -o drivers/built-in.o drivers/gpio/built-in.o drivers/pci/built-in.o drivers/video/built-in.o drivers/char/built-in.o drivers/gpu/built-in.o drivers/serial/built-in.o drivers/base/built-in.o drivers/block/built-in.o drivers/misc/built-in.o drivers/mfd/built-in.o drivers/macintosh/built-in.o drivers/mtd/built-in.o drivers/spi/built-in.o drivers/net/built-in.o drivers/atm/built-in.o drivers/ieee1394/built-in.o drivers/cdrom/built-in.o drivers/auxdisplay/built-in.o drivers/usb/built-in.o drivers/input/built-in.o drivers/rtc/built-in.o drivers/i2c/built-in.o drivers/media/built-in.o drivers/md/built-in.o drivers/isdn/built-in.o drivers/lguest/built-in.o drivers/idle/built-in.o drivers/leds/built-in.o drivers/firmware/built-in.o drivers/crypto/built-in.o drivers/clocksource/built-in.o drivers/platform/built-in.o drivers/ieee802154/built-in.o
mit dieser .config
ich frage mich, welchen Sinn macht es hier eine .config zu posten, in der klar und deutlich steht Replace kernel (not available, no sources by AVM) und dann eine Frage zu stellen, warum sich der Kernel nicht übersetzen lässt. Die Form der Frage ist dabei auch etwas provokativ "mit dieser .config bekomme ich beim Kompilieren folgenden Fehler". Nein, nicht mit dieser, sondern mit einer anderen, mit einer in der Replace-Kernel aktiviert ist. Da in dem aktuellen trunk Replace-Kernel für 7360 06.XX (aus gutem Grund) deaktiviert ist, hast Du offensichtlich ein paar Änderungen an freetz-menuconfig vorgenommen, die Du uns verschwiegen hast.
Weder für 7360v1 noch für 7360v2 hat AVM irgendein 06er-Open-Source-Package veröffentlicht. Daher verwendet freetz aktuell kernel-sources von der 7490 (verwendet bedeutet an der Stelle, es werden nur Headers verwendet, die zum Übersetzen von Paketen benötigt werden). Es ist also kein Wunder, dass der Kernel selbst sich nicht übersetzen lässt.
Für 7360SL hat AVM allerdings ein 06er-Open-Source-Package veröffentlicht. Versuch mal die kernel-sources aus diesem zu integrieren.
... hast Du offensichtlich ein paar Änderungen an freetz-menuconfig vorgenommen, die Du uns verschwiegen hast.
Das Image basiert auf einem frisch ausgecheckten Trunk ohne jegliche Änderungen meinerseits. Das Replace kernel (not available, no sources by AVM) hatte ich in der Tat übersehen ..
Wurde allerdings auch vom menuconfig nicht darauf hingewiesen bzw. abgehalten.
Ich werde mal versuchen, die 7360SL-Kernel-Sourcen zu benutzen
Na ja, mit deaktivierten "Replace Kernel" wird der Kernel erst gar nicht übersetzt (i.e. Du würdest die Fehlermeldung erst gar nicht bekommen). Also hast Du entweder am menuconfig geschraubt oder aktiv make kernel-force aufgerufen, um zu erzwingen, dass es doch noch versucht wird, den Kernel zu übersetzen.
Habe 7360SL.06.00 Sourcen mit denen von 7490.06.01 verglichen. Diese sind überraschenderweise bis auf ein Zeitstempel in einer Makedatei absolut identisch. Und zwar auch die .config, was jedoch schon allein deswegen nicht sein kann, weil 7490 2 CPUs hat und 7360 nur eine. Also hat sich AVM da höchstwahrscheinlich vertan und die Sources von 7490 als die von 7360 veröffentlicht. Damit fehlen uns die richtigen Sources für 7360...
Edit: habe ein wenig getestet, bei mir lässt sich der Kernel (make kernel-force) auch in der Konfiguration, wo 7360 ausgewählt ist, problemlos übersetzen. Wäre überraschend, wenn das nicht der Fall wäre, denn es sind die selben Sources wie 7490, mit der .config von 7490 und für 7490 ist Replace-Kernel ja aktiviert. Also sofern es sich bei Dir um einen frischen Checkout handelt ohne irgendwelche Änderungen - wie viele CPUs hat Dein Rechner? Aus Erfahrung, unerklärliche Build-Fehler passieren häufig, weil die (make)-Abhängigkeiten unvollständig sind und beim parallel Build auf mehreren CPUs einiges daneben läuft.
Zum System:
Intel® Core™ i3-2310M CPU @ 2.10GHz × 4
Ich werde make kernel-force mal versuchen und wieder berichten.
Nur so als Hinweis, sofern die vorigen Posts diese Tatsache nicht klar genug hervorgehoben haben. Zum einen handelt es sich bei den Kernel-Sources um die vom 7490 und zum anderen (viel wichtiger) ist die .config, die verwendet wird, die von 7490 (selbes Kernel-Layout "vr9", aber andere Anzahl CPUs und sonst noch ein paar andere Abweichungen an der Kernel-Konfiguration). Auch wenn sich der Kernel übersetzen lassen wird, ist es nicht zu erwarten, dass dieser auf der 7360 (problemlos) laufen wird.
@er13
Mir war das beim Einpflegen schon aufgefallen, aber ich meine da waren noch mehr Quellen, die auch zu denen der 7490 identisch waren. Evtl. wirklich ein versehen von AVM. Da sollte mal jemand nachhaken...
Deine verlinkten Sourcen passen zu einer 3370, hier geht 's um einer 7360(v1) ...?
@JohnDoe42: Du hast hinsichtlich der FB-Variante natürlich Recht, ich hatte jedoch den Eindruck, dass es im Prinzip um das gleiche Problem ging, nämlich fehlende Source-Pakete. Ich räume auch unumwunden ein, dass ich im Augenblick nicht ganz durchblicke - zuletzt konnte ich in Freetz-trunk den Kernel nicht ersetzen, obwohl laut AVM keine Änderungen im Open Source Teil der FW vorgenommen wurden. Ist aber nicht so tragisch, da es mir nur um etwas Feintuning ging - die FB läuft.
Dann hat AVM bestimmt von einer anderen Firmware geredet. Es wurden keine Änderungen zur Behebung der Sicherheitslücke gemacht. Aber das Problem, dass sie uns scheinbar die richtigen Kernelkonfigurationen nicht rausgeben bestand schon vorher.
Die Kernelsourcen für die 7360 (v2) sind seit gestern draussen:
ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7360_v2/x_misc/opensrc/
Ich hab diese nicht mit den schon vorhandenn 6er Sourcen verglichen;
aber eventuell kommt AVM mal auf die 'schlaue' Idee für alle (zumindest da wo's geht) Boxen immer die gleichen Sourcen zu verwenden.
für die 7360v1 nun auch:
ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7360_v1/x_misc/opensrc/
Edit2:
Kernel-Configs in den von AVM veröffentlichen Sourcen für 7360 (sl, v1 und v2) und 7490 sind gleich:
http://www.ip-phone-forum.de/showthread.php?t=268038&page=2&p=1994962&viewfull=1#post1994962
Nach aktuellen Erkenntnissen ist das wohl nicht korrekt, der Lantiq VRX288 (7360v1/2, 3370 und 3390) hat wie der GRX388 (7490) und der ARX388 (3272 und 7272) einen MIPS 34Kc mit 2 CPU-Kernen und 500MHz, also hinsichtlich der CPU keine Unterschiede zwischen den aktuellen Lantiq-Boxen und von daher nicht unrealistisch das dort überall der gleiche Kernel zum Einsatz kommt.
Die 7490 ist also nicht schneller als die älteren Lantiq VR9 Boxen... ;)
edit
Wäre natürlich noch interessant zu erfahren ob in der 7362 SL noch ein VRX288 oder der neuere GRX388 zum Einsatz kommt. Ich tippe auf GRX388.
Das glaube ich so langsam auch.
In einer Presemittelung zum VRX288 (http://www.prnewswire.com/news-rele...boration-with-qualcomm-atheros-158838975.html)
und einer Pressemitteilung zur ARX300 Serie (http://www.lantiq.com/news/press/210-lantiq-adsl-wifi-wlan-gige-soc/)
wird jeweils von "High-performance dual-processor architecture with application processor CPU and dedicated 32-bit protocol processing engine..." geredet.
Das Blockdiagramm zum VRX288 enthält 2 CPUS (Netzwerk & Voip): http://www.lantiq.com/uploads/tx_abzlantiqproducts/PB-e-0028-v1_lres.pdf
Openwrt listet den VRX288 als Dual-Core: http://wiki.openwrt.org/toh/arcadyan/vgv7510kw22
Ausserdem läuft meine 7360v2 mit den 7490 Kernel-Sourcen seit ner halben Stunde :p http://www.ip-phone-forum.de/showthread.php?t=268038&page=2&p=1995065&viewfull=1#post1995065
holh-66
