voipcfg {
dnsport = 7077;
rtpport_start = 7078;
ua1 {
enabled = yes;
username = *** entfernt ***
authname = "";
passwd = *** entfernt ***
registrar = "terrasip.net";
ttl = 30m;
sipping_enabled = no;
sipping_interval = 280s;
name = *** Meine SIP-Nummer A***;
authenticatemode = authenticate_mode_none;
infodtmfnotsupported = no;
register_failwaitmax = 30m;
stunserver = "stun.terrasip.net";
stunserverport = 3478;
is_nat_aware = no;
clirtype = clir_displayname;
only_one_dialog = no;
presence_supported = no;
mwi_supported = yes;
tx_packetsize_in_ms = 30;
reject_refer = yes;
no_register_fetch = no;
do_not_register = no;
outboundproxy = "terrasip.net:5060";
is_ddi = no;
ua2 {
enabled = yes;
username = ***entfernt***
authname = "";
passwd = ***entfernt***
ttl = 30m;
name = "***Meine SIP Nummer B***";
is_nat_aware = no;
tx_packetsize_in_ms = 0;
reject_refer = yes;
outboundproxy = "terrasip.net:5064";
is_ddi = no;
use_audiocodecs = no;
audiocodecs = "PCMA", "PCMU", "G726-32", "G726-40", "G726-24";
verbose = no;
sip_prio = 0;
rtp_prio = 0;
dyn_codecs = yes;
prio_low_codec = no;
send_ringtone = no;
blacklist = no;
enum_support_enabled = yes;
enumdomains = "e164.arpa", "e164.org";
rtpstream {
voice_activity_detection {
enabled = no;
vad_threshold = 10000;
generate_noise {
on_capi_underrun = yes;
jitter {
auto_on = yes;
in_ms = 50;
in_packets = 0;
voip_assi_enabled = yes;
