2602R-61 with Zyxel firmware...
flemse
14 Mrz 2007
Hi there.
I have a 2602R-61 including bundled firmware from my ISP provider, that will say I can't upload the originaly Zyxel firmware.
The reason is the bit setting!
Maybe you can help? If you have a 2602R-61 with Zyxel firmware please do this::D
1) Login via telnet.
2) Select option 24
3) Select option 8 (CLI)
4) Type now this command "sys atsh"
5) Post the result...
My dump look like this:
RAS version : V3.40(ADC.7) | 12/06/2006
Ram Size : 16384 Kbytes
Flash Type and Size : Intel 32Mbits*1
romRasSize : 1980844
bootbase version : V1.10 | 12/02/2004
Product Model : Prestige 2602R-61
MAC Address : xxxxxxxxxxx(secure)
Default Country Code : FC
Boot Module Debug Flag : 00
RomFile Version : 35
RomFile Checksum : 32d7
RAS F/W Checksum : e693
SNMP MIB level & OID : 060102030405060708091011121314151617181920
Main Feature Bits : C0
Other Feature Bits :
9D 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 01 41 13 00 00 00
Thanks
//Flemming
Your Zyxel modem
The official Feature bits should be :
165 #define ZYNOS_MODEL_P_2602R_61 MID( 2205) -> 08 - 9D
TS
P.S.: Which modem is yours ? From which operator ? Can you email me the Bootrom of it ? As well as the firmware ? Please check here for all details :
http://www.jstic.com/Newsgroup/Zyxel/
9d 08
So should be...
9D 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TS
dag74
