2811 Kein Ton beim Anrufen
MikeS
14 Sep 2004
Hallo, vielleicht habe den Titel nicht so elegant gewählt, habe das problem, dass wenn ich ins Festnetz rufe, das Telefon klingelt, der andere kann mich hören, aber ich höre nichts....
hat jemand eine Idee, hier meine running config:
Cisco 2811
VIC2-2BRI NT/TE
PVDM2 - 8
no aaa new-model
clock timezone MEZ 1
clock summer-time Berlin date Aug 27 2008 22:55 Oct 26 2008 3:00
clock calendar-valid
network-clock-participate wic 2
network-clock-select 1 BRI0/2/0
dot11 syslog
ip source-route
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp pool pool1
   import all
   network 192.168.16.0 255.255.255.0
   domain-name domain.local
   dns-server 192.168.16.222 194.8.194.60
   default-router 192.168.16.253
   option 150 ip 192.168.16.252
no ipv6 cef
multilink bundle-name authenticated
isdn switch-type basic-net3
voice register global
 mode cme
 max-dn 144
 max-pool 42
voice statistics time-range since-reset
voice translation-rule 10
 rule 1 /\(^.*\)/ /00\1/ plan isdn national
voice translation-rule 11
 rule 1 /^27696333$/ /11/
 rule 2 /^2769540$/ /12/
voice translation-profile AZ-IN
 translate calling 10
 translate called 11
voice-card 0
 no dspfarm
interface FastEthernet0/0
 ip address 192.168.16.252 255.255.255.0
 no ip route-cache
 duplex half
 speed auto
 no mop enabled
interface FastEthernet0/1
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface BRI0/2/0
 no ip address
 no ip route-cache
 isdn overlap-receiving
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn skipsend-idverify
interface BRI0/2/1
 no ip address
 no ip route-cache
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
no cdp run
tftp-server flash:CP7912080003SCCP070409A.sbin
tftp-server flash:CP7902080002SCCP060817A.sbin
tftp-server flash:ATA030203SCCP051201A.zup
control-plane
voice-port 0/2/0
 translation-profile incoming AZ-IN
 echo-cancel coverage 32
 compand-type a-law
 cptone DE
 connection plar 1001
 description Netcologne
voice-port 0/2/1
dial-peer voice 6400 pots
 preference 6
 destination-pattern 0T
 progress_ind setup enable 3
 progress_ind progress enable 8
 direct-inward-dial
 port 0/2/0
no dial-peer outbound status-check pots
gatekeeper
 shutdown
telephony-service
 load 7902 CP7902080002SCCP060817A
 load 7912 CP7912080003SCCP070409A
 load ata ATA030203SCCP051201A
 max-ephones 35
 max-dn 20
 ip source-address 192.168.16.252 port 2000
 auto assign 1 to 6
 timeouts interdigit 3
 system message Cisco
 user-locale DE
 time-zone 23
 time-format 24
 date-format dd-mm-yy
 max-conferences 8 gain -6
 moh flash:music-on-hold.au
 transfer-system full-consult
 secondary-dialtone 0
 create cnf-files version-stamp 7960 Aug 31 2008 21:33:00
ephone-template  1
ephone-dn  1
 number 11
 name xyz
ephone-dn  2
 number 12
 name zyx
ephone  1
 device-security-mode none
 mac-address 0013.6090.9D8A
 type 7912
 button  1:1
ephone  2
 mac-address 0013.808D.A87E
 max-calls-per-button 2
 type 7902
 button  1:2
Wäre super wenn jemand ne Idee hätte
mfg
Mike
Wie ist denn das Netz aufgebaut?
NTBA -> CME -> SWITCH -> Phone
Gibt es noch irgendein Device zwischen den Switch an dem die Phones hängen und dem CME?
Wie sieht die Sache bei int. Telefongespräch aus?
Intern alles vollkommen in ordnung
noch jemand eine Idee?
Plan A:
IP Communicator auf den PC/Notebook und Wireshark drauf. Call aufbauen und tracen.
Plan B:
Phone -> HUB -> CME
...............-> PC mit Sniffer
Ich hatte bei 1&! das problem - Anrufe und kein Ton.
Telefonie -> Internettelefonie -> Erweitere Einstellungen ->
Einstellung: mmer Sprachkodierung mit Kompression verwenden
es funzt jetzt
Jetzt gehts!!!
Ich habe keine Ahnung woran es lag, aber als allerletzten Versuch habe ich einen Factory Reset gemacht und jetzt rennt das Teil....
vielen Dank für eure Hilfe!
Gruß Mike
Lishheshuyg
