2te Serielle / dev/ttyS1 auf 71nn
byteeater
25 Nov 2009
An der Ohio Cpu hat es 2 serielle...
Siehe /proc/sys/urloader/environment, bootlog etc.
Um das Ding mit nem Oszi hardwareseitig finden zu können, muss was dahin gesendet werden.
Hab nen Kernel gebaut, der 2 ttyS bewältigen kann und IRQ-sharing enable hat.
.config Änderung
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=2
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set       <- nötig, wenn mehr als 4 ports
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DETECT_IRQ=y
CONFIG_SERIAL_8250_RSA=y
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=16
Bootlogschnipsel:
//snipp
[avm] configured: watchdog eventled enable shift register enable direct gpio
        gpio usage: reset=12 clock=13 store=10 data=9
AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: May  1 2010 09:30:
09)
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled
[uart_add_one_port]
ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
[uart_add_one_port] dont register console port->type = 16
port->cons = 0x941e63dc port->cons->flags = 0x7
[uart_add_one_port] success
[uart_add_one_port]
[uart_add_one_port] dont register console port->type = 0
//snipp
[setup_irq]: irq 15 irqaction->handler 0x940e1f78 (serial8250_interrupt+0x0/0x13c)
//snipp
Woher kommt das:
uart_add_one_port?
Laut
/proc/tty/driver # cat serial
serinfo:1.0 driver revision:
0: uart:OHIO_UART port:00000000 irq:15 tx:3957 rx:35 RTS|DTR
1: uart:unknown port:00000000 irq:0
grep serial /proc/interrupts
 15:       9429    OHIO primary  serial
ist die 2te nicht wirklich da...
/proc/tty # cat drivers
/dev/tty             /dev/tty        5       0 system:/dev/tty
/dev/console         /dev/console    5       1 system:console
/dev/ptmx            /dev/ptmx       5       2 system
serial               /dev/ttyS       4 64-65 serial
pty_slave            /dev/pts      136 0-1048575 pty:slave
pty_master           /dev/ptm      128 0-1048575 pty:master
pty_slave            /dev/ttyp       3 0-15 pty:slave
pty_master           /dev/pty        2 0-15 pty:master
/proc/tty #
Das charakter dev ist mit 4 65 angelegt.
Dann hab ich mir nen setserial binary gebaut.
/freetz-trunk/packages/setserial-2.17/root/usr/sbin$ file setserial
setserial: ELF 32-bit LSB executable, MIPS, MIPS32 version 1 (SYSV), dynamically linked (uses shared libs), stripped
Ergebnis:
setserial -a -v /dev/ttyS1
/dev/ttyS1, Line 1, UART: unknown, Port: 0x0000, IRQ: 0
        Baud_base: 0, close_delay: 50, divisor: 0
        closing_wait: 3000
        Flags: spd_normal
:mad:
Hat einer ne Idee???
Files zum binary bauen im tar.
  • setserial.tar
