6.52 released
frater
23 Nov 2008
Only recently the 6.52 version for the International version has been released.
I'm very eager to implement this version on some of the routers I'm managing because it solves a long outstanding bug of the DHCP-server that wasn't recycling its IP-adresses.
Some Fritzbox owners use it for their restaurant or bar and soon these boxes become sluggish and stop giving out new IP's.
Only the 7490 has this update for now and all of them are using the 7390.
They probably need to wait a bit longer then.
It says "experimental" in Freetz.
I believe the German version existed for a while already and I can only assume that it has been tested by many of you.
Is the International release as of yesterday a token that most major bugs have been squashed or should I stay away of it still?
Even the german version 113.06.51 is "experimental" in Freetz and there are many known problems, especially with packages including a GUI modification and with "remove patches".
How far the support for the new version is really usable/helpful, depends on the packages to include into a Freetz image and - at this time - any modification, which requires an own kernel ("replace kernel" setting), can't be used - the published source files are not complete and you will never get a running kernel (only with own changes to the kernel setup routines) while you're using them.
And beside these known problems, it's "the same procedure as every year" ... you should try it and report detected problems. There are not so many users of the international version and the volume of "modders" in general and the number of them, who are running "Freetz" on a 7490 device, is smaller again.
You may wait some more times (from month to quarter to year/s) ... but don't expect, the situation will change without your own involvement.
I know, I wrote this already in the past (more than once) ... but it's still true and the Freetz developers (I'm not a member there, but I'm trying to help them within my limitations) are trying to solve already known problems and not necessarily to find new unknown ones in freshly released firmware - the Freetz users are responsible to do this and if no one makes the first step/test, nothing will happen.
If a new AVM release is added to the trunk, it's usually completely untested and without the interaction with users this will not be changed by a "big bang".
Maybe I misunderstood your question completely ... but if it was the "heart of the matter", if anybody could/would test this in the near future for you, you probably know the answer already and without any idea, which packages you would need for your customizations, nobody can give you a really substantive response.
No, just wanted to get some "feel" which I now have.
I will be testing it on the one I have at home and gradually some more.
Of course I will be reporting.
I recently upgraded all the 7360's to 6.31 and the only thing I noticed on one of them was that the answering machine which was set to a specific number suddenly reacted to all numbers.
A bit embarrassing as these were different households. Nothing to do with Freetz.
I have about 10 7490 and they are all monitored.
I installed it on my own private 7490.
The interface looks refreshing, but that is probably just because it changed.
Anyhow, it looks good.
Zabbix didn't notice any failures, but I did not see in Zabbix that the firmware changed. I will check that now....
Too bad it's only for the 7490
All boxes with the problem of too many lame leases are 7390's.
Hopefully it will not take too long before the International community has it for that model.
Was there a time-difference on the German versions (7390 vs 7490)?
It might be some indication on how long I have to wait for that.
# find ~/FritzBox/ftp.avm.de/ -name "*7?90*" -ls
27268309    4 drwxr-xr-x   4 root     root         4096 Apr  3  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490
27268356 23832 -rwxr-xr-x   1 root     root     24402272 Feb  3  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.24.recover-image.exe
27268353 23288 -rwxr-xr-x   1 root     root     23845216 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.03.recover-image.exe
27268364 23920 -rwxr-xr-x   1 root     root     24494080 Jul 16  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/alt/FRITZ.Box_7490.113.06.30.image
27268358 23808 -rwxr-xr-x   1 root     root     24377696 Jul 17  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/fritz.box_7490.06.30.recover-image.exe
27268576 23124 -rw-r--r--   1 root     root     23676888 Feb 17 12:47 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.51.recover-image.exe
27268351 23124 -rwxr-xr-x   1 root     root     23677264 Feb  8 15:55 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.50.recover-image.exe
27268354 23320 -rwxr-xr-x   1 root     root     23877984 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.05.recover-image.exe
27268357 23832 -rwxr-xr-x   1 root     root     24402272 Dec 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/fritz.box_7490.06.23.recover-image.exe
27268355 24416 -rwxr-xr-x   1 root     root     25000288 Aug 13  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch/FRITZ.Box_7490.06.20.recover-image.exe
27268374 23716 -rwxr-xr-x   1 root     root     24283488 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/english/FRITZ.Box_7490.en-de-es-it-fr-pl.06.04.recover-image.exe
27268375 24420 -rwxr-xr-x   1 root     root     25006080 Oct 24  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/english/FRITZ.Box_7490.en-de-es-it-fr-pl.06.20.recover-image.exe
27268377 24492 -rwxr-xr-x   1 root     root     25079808 Aug 27  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/english/FRITZ.Box_7490.en-de-es-it-fr-pl.06.30.recover-image.exe
27268675 23520 -rw-r--r--   1 root     root     24084480 May 26 10:02 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/english/FRITZ.Box_7490.en-de-es-it-fr-pl.06.52.recover-image.exe
27268381 621280 -rwxr-xr-x   1 root     root     636184674 Dec  9  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.01.tar.gz
27268386 734964 -rwxr-xr-x   1 root     root     752598382 Nov 20  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.30.tar.gz
27262977 692248 -rwxr-xr-x   1 root     root     708855888 May 25 12:16 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.50_25.05.2016.tar.gz
27268380 621276 -rwxr-xr-x   1 root     root     636181659 Oct 18  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-05.59.tar.gz
27262979 692328 -rw-r--r--   1 peh      1000     708936560 May 26 11:24 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.51_26.05.2016.tar.gz
27268385 734928 -rwxr-xr-x   1 root     root     752558309 May 21  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490_Labor-06.10-27948.tar.gz
27268382 621288 -rwxr-xr-x   1 root     root     636193771 Mar 18  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.05.tar.gz
27262978 692244 -rw-r--r--   1 root     root     708850744 Jun  1 11:17 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.50.tar.gz
27268577 692320 -rw-r--r--   1 root     root     708930889 Jun  1 11:18 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.51.tar.gz
27268384 734788 -rwxr-xr-x   1 root     root     752418079 Feb 19  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.23.tar.gz
27268383 734780 -rwxr-xr-x   1 root     root     752407631 Sep 16  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/opensrc/source-files-FRITZ.Box_7490-06.20.tar.gz
27268575 24492 -rw-r--r--   1 root     root     25079808 Feb 20 11:49 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.06.31.recover-image.exe
27268347 23712 -rwxr-xr-x   1 root     root     24281088 Jun 25  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.06.06.recover-image.exe
27268348 24420 -rwxr-xr-x   1 root     root     25006080 Oct 24  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.06.20.recover-image.exe
27268368 23716 -rwxr-xr-x   1 root     root     24283488 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.06.04.recover-image.exe
27268369 24420 -rwxr-xr-x   1 root     root     25006080 Oct 24  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.06.20.recover-image.exe
27268371 24492 -rwxr-xr-x   1 root     root     25079808 Aug 27  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.06.30.recover-image.exe
27268674 23520 -rw-r--r--   1 root     root     24084480 May 26 10:02 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/x_misc/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.06.52.recover-image.exe
27268325 70464 -rwxr-xr-x   1 root     root     72150569 Jul 26  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/fritzbox-labor-7490-28144.zip
27268324 24312 -rwxr-xr-x   1 root     root     24893440 Jul 26  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490_Labor.113.06.10-27982.image
27268320 23940 -rwxr-xr-x   1 root     root     24514560 Dec 12  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.23.image
27268318 23440 -rwxr-xr-x   1 root     root     24002560 Mar  4  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.05.image
27268322 23920 -rwxr-xr-x   1 root     root     24494080 Jul 16  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.30.image
27268321 23940 -rwxr-xr-x   1 root     root     24514560 Feb  2  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.24.image
27268323 24312 -rwxr-xr-x   1 root     root     24893440 Jul 26  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490_Labor.113.06.10-27948.image
27268326 46124 -rwxr-xr-x   1 root     root     47227521 Aug 22  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/fritzbox-labor_7390-28605.ZIP
27268574 25132 -rw-r--r--   1 root     root     25733120 Feb  3 17:45 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.51.image
27268327 72036 -rwxr-xr-x   1 root     root     73759247 Nov 27  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/fritzbox-labor_7490-29521.zip
27268319 24532 -rwxr-xr-x   1 root     root     25118720 Aug  8  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.20.image
27268329 25132 -rwxr-xr-x   1 root     root     25733120 Dec 10  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch/FRITZ.Box_7490.113.06.50.image
27268673 25532 -rw-r--r--   1 root     root     26142720 May 26 10:02 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/english/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.52.image
27268341 24612 -rwxr-xr-x   1 root     root     25200640 Aug 27  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/english/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.30.image
27268339 24540 -rwxr-xr-x   1 root     root     25128960 Oct 18  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/english/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.20.image
27268338 23832 -rwxr-xr-x   1 root     root     24401920 Feb 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/english/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.04.image
27268314 24540 -rwxr-xr-x   1 root     root     25128960 Oct 18  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.20.image
27268313 23840 -rwxr-xr-x   1 root     root     24412160 Jun 25  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.06.image
27268573 24612 -rw-r--r--   1 root     root     25200640 Feb 20 11:49 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/belgium/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.31.image
27268672 25532 -rw-r--r--   1 root     root     26142720 May 26 10:02 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.52.image
27268335 24612 -rwxr-xr-x   1 root     root     25200640 Aug 28  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.30.image
27268333 24540 -rwxr-xr-x   1 root     root     25128960 Oct 18  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.20.image
27268332 23832 -rwxr-xr-x   1 root     root     24401920 Feb 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.7490/firmware/deutsch_a-ch/FRITZ.Box_7490.en-de-es-it-fr-pl.113.06.04.image
27268189    4 drwxr-xr-x   5 root     root         4096 Aug 15  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390
27268217 46120 -rwxr-xr-x   1 root     root     47223531 Aug 15  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/labor/fritzbox-labor_7390-28585.ZIP
27268225 15576 -rwxr-xr-x   1 root     root     15948128 Jul 17  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/fritz.box_fon_wlan_7390.annexb.06.30.recover-image.exe
27268222 15524 -rwxr-xr-x   1 root     root     15894880 Jun 27  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/fritz.box_fon_wlan_7390.annexb.06.04.recover-image.exe
27270038 15264 -rw-r--r--   1 root     root     15628248 Apr 26 13:01 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.06.51.recover-image.exe
27268223 15544 -rwxr-xr-x   1 root     root     15915360 Sep  9  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/fritz.box_fon_wlan_7390.annexb.06.20.recover-image.exe
27268221 15516 -rwxr-xr-x   1 root     root     15886688 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.06.03.recover-image.exe
27268224 15508 -rwxr-xr-x   1 root     root     15878496 Jan 27  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch/fritz.box_fon_wlan_7390.annexb.06.23.recover-image.exe
27268239 15428 -rwxr-xr-x   1 root     root     15798272 Oct 29  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.20.recover-image.exe
27268241 15444 -rwxr-xr-x   1 root     root     15814656 Aug 31  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.30.recover-image.exe
27268238 15548 -rwxr-xr-x   1 root     root     15921152 Apr 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.06.recover-image.exe
27268237 15444 -rwxr-xr-x   1 root     root     15812960 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.03.recover-image.exe
27268250 91772 -rwxr-xr-x   1 root     root     93969266 May 27  2010 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.04.84.tar.gz
27268247 631504 -rwxr-xr-x   1 root     root     646655388 Jun 30  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files.06.04.tar.gz
27268252 433984 -rwxr-xr-x   1 root     root     444393063 Aug  4  2011 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.05.tar.gz
27268251 71664 -rwxr-xr-x   1 root     root     73379071 Mar 24  2011 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.01.tar.gz
27268254 908708 -rwxr-xr-x   1 root     root     930512580 May  7  2012 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.21.tar.gz
27270039 445020 -rw-r--r--   1 root     root     455699304 Apr 27 10:19 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files-06.51.tar.gz
27268253 951252 -rwxr-xr-x   1 root     root     974076082 Mar 23  2012 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.20.tar.gz
27268257 441160 -rwxr-xr-x   1 root     root     451740814 Nov  6  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files-06.30.tar.gz
27268245 631504 -rwxr-xr-x   1 root     root     646655803 Nov  1  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files.06.00.tar.gz
27268249 349364 -rwxr-xr-x   1 root     root     357744317 Jun 14  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source_files.05.52.tar.gz
27268248 441152 -rwxr-xr-x   1 root     root     451732190 Sep 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files.06.20.tar.gz
27268256 349368 -rwxr-xr-x   1 root     root     357745663 May 14  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.51.tar.gz
27268255 391612 -rwxr-xr-x   1 root     root     401006141 Dec  7  2012 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/fritz_box_fon_wlan_7390_source_files.05.50.tar.gz
27268244 441156 -rwxr-xr-x   1 root     root     451739236 Mar 16  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files-06.23.tar.gz
27268246 631512 -rwxr-xr-x   1 root     root     646661270 Dec  9  2013 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/opensrc/FRITZ.Box_Fon_WLAN_7390_source-files.06.01.tar.gz
27268232 15428 -rwxr-xr-x   1 root     root     15798272 Oct 29  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.20.recover-image.exe
27268234 15444 -rwxr-xr-x   1 root     root     15814656 Aug 31  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.30.recover-image.exe
27268231 15548 -rwxr-xr-x   1 root     root     15921152 Apr 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.06.recover-image.exe
27268230 15444 -rwxr-xr-x   1 root     root     15812960 Mar 20  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/x_misc/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.06.03.recover-image.exe
27268195 15760 -rwxr-xr-x   1 root     root     16138240 Jun 27  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.04.image
27268196 15760 -rwxr-xr-x   1 root     root     16138240 Sep  9  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.20.image
27268194 15752 -rwxr-xr-x   1 root     root     16128000 Feb  7  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.03.image
27268197 15732 -rwxr-xr-x   1 root     root     16107520 Jan 22  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.23.image
27268198 15792 -rwxr-xr-x   1 root     root     16168960 Jul 16  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.30.image
27270037 16700 -rw-r--r--   1 root     root     17100800 Apr 25 12:51 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.51.image
27268199 46080 -rwxr-xr-x   1 root     root     47184300 Jul 26  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch/fritzbox-labor_7390-28144.zip
27268212 16580 -rwxr-xr-x   1 root     root     16977920 Oct 29  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.20.image
27268211 15792 -rwxr-xr-x   1 root     root     16168960 Apr 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.06.image
27268214 16600 -rwxr-xr-x   1 root     root     16998400 Aug 31  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.30.image
27268210 15680 -rwxr-xr-x   1 root     root     16056320 Feb  7  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/english/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.03.image
27268205 16580 -rwxr-xr-x   1 root     root     16977920 Oct 29  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.20.image
27268204 15792 -rwxr-xr-x   1 root     root     16168960 Apr 17  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.06.image
27268207 16600 -rwxr-xr-x   1 root     root     16998400 Aug 31  2015 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.30.image
27268203 15680 -rwxr-xr-x   1 root     root     16056320 Feb  7  2014 /root/FritzBox/ftp.avm.de/fritz.box/fritzbox.fon_wlan_7390/firmware/deutsch_a-ch/FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.03.image
Timestamps of the latest (:-)) firmware files from ftp.avm.de for 7390/7490 ... may be you'll find the requested info therein.
It seems that 7390 is some 2 months behind on 7490 (used as indication)
Probably because it's their current flagship....
holh-66
