7050 and Winscp
Sterke-Jerke
1 Jan 2006
I have installed dropbear using "the construct"
I can connect OK using puttyssh.
Only proble is when I want to connect with winscp I can not edit files.
(I want to use it for edditing asterisk files).
I read this in the Wiki:
auch winscp funktioniert, wenn man es passend konfiguriert: Expertenmodus und nur scp im login-Fenster anhaken und dann unter scp bei Gruppen und Zeitstempel Haken entfernen (1, 2)
Can someone help me: I connot find the first mentionend option: scp im login-Fenster
Can someone tell me what option this is in theEnglish Winscp?
Hello Steke-Jerke,
i have never used winscp with my fritzbox but i have tested for you...
In the login window where the IP is there is the option what protocoll you want to use:
-> only scp
select advanced options:
select SCP
-> directory listing: "try to get full timestamp" => deselect
-> other options: "lookup user groups" => deselect
for me this worked. hope for you tooo.
gl
waldoo
Hm...
I tried this config to try to connect to one of my boxes, but I cann't connect.
I can connect via PuTTY at port 23, but not with WinSCP.
Who can help me?
Thanks.
Patrick89
