7050 uns usb speicher
Sterke-Jerke
1 Jan 2006
With a change of being flamed, I must ask the question.
I am wondering if its possible to use a USB stick as storage for my 7050. Because I want to run Asterisk on it...
(Sorry could not find the answer somewhere)
you can run asterisk without USB stick on it - as I do.
And regarding your question - imho no.
So you download asterisk every time after a reboot? Using the modifications in the debug.cfg?
The USB port of the 7050 can only be used to connect to a computer. There is no way to attach USB devices like an USB stick.
But asterisk does work the way you described.
nikitarajusa
