7140 international annex_a
flemse
14 Mrz 2007
Hi
I have lot of problem to get AVM's new fw .67 working with freetz.
I made a new fresh trunk and compile without any error. The router is cycle booting.
I only select bearSSH and samba. But in the new fw .67 avm all ready had a samba? How to handle that?
Up to .57 I had no problem but the new .67 i cant get running.
If other have it running, please post the setup or maybe the .config file.
Any suggest?
Which version of freetz did you try? Did you select inetd? Perhaps you can attach your .config.
Regards
Oliver
Hi
No inetd is selected by me, it it is included in some package maybe then.
Sure I will attach my .config later today.
Hi
Version:
7140_04.67freetz-devel-3100.en_20090224
Here are .config.
And the last line from compilation
installing mod base
  copying files
  installing libs
    libcrypt-0.9.29.so
    libuClibc-0.9.29.so
    libutil-0.9.29.so
    libdl-0.9.29.so
    libfreetz.so.1.0.0
    libgcc_s.so.1
    libm-0.9.29.so
    libpthread-0.9.29.so
    librt-0.9.29.so
    libz.so.1.2.3
    libnsl-0.9.29.so
    ld-uClibc-0.9.29.so
replacing busybox
  replacing busybox-8mb_26
  installing symlinks
  installing modules
    fuse.ko
    nls_iso8859-1.ko
    nls_cp437.ko
  generating modules.dep
installing packages
  syslogd-cgi-0.2.3
  avm-firewall-2.0.4_rc2
  dropbear-0.52
  samba-3.0.24
  fstyp-0.1
  haserl-0.9.25
  modcgi-0.2
  ntfs-1.5130
invoking custom script
done.
Hi
The new checkout solve the problem, SORRY!
Only problem is if from AVM's login page if hit the freetz link in the button, its not working.
It redirect to:
http://192.168.xx.xx/cgi-bin/freetz_status
There are missing the port number http://192.168.xx.xx:81/
One more sorry for the trouble but my latest compile was with a checkout 1 week ago.
_You can close this_
Regards
F.
Is telnet or ssh running? Can you attach the output of ps?
Does the webinterface work if you enter the direct URL?
Regards
Oliver
Hi
1) Freetz web interface is working but I must enter the :81 manually. The direct link in AVM is not working.
2) AVM web is working 100%.
3) Telnet is not running.
4) SSh is running.
4) Output of ps:
/var/mod/root # ps
  PID USER       VSZ STAT COMMAND
    1 root      1176 S    init
    2 root         0 SWN  [ksoftirqd/0]
    3 root         0 SW<  [events/0]
    4 root         0 SW<  [khelper]
    5 root         0 SW<  [kthread]
    6 root         0 SW<  [kblockd/0]
   23 root         0 SW<  [pdflush]
   24 root         0 SW<  [pdflush]
   26 root         0 SW<  [aio/0]
   25 root         0 SW   [kswapd0]
   62 root         0 SW   [pm_info]
   66 root         0 SW<  [CPMAC]
   70 root         0 SW   [mtdblockd]
   96 root         0 SW   [tffsd_mtd_0]
  277 root         0 SWN  [jffs2_gcd_mtd6]
  301 root         0 SW<  [capi_oslib]
  302 root         0 SW<  [capi_oslib]
  303 root         0 SW   [capitransp]
  309 root         0 SW   [glob_codecs]
  323 root         0 SW<  [khubd]
  458 root         0 SWN  [scsi_eh_0]
  459 root         0 SWN  [usb-storage]
  502 root      4392 S    igdd
  513 root      2528 S    multid
  614 root      4984 S    telefon a127.0.0.1
  618 root      4472 S <  voipd
  622 root      2340 S    pbd
  623 root      2340 S    pbd
  628 root      2340 S    pbd
  629 root      2340 S    pbd
  642 root       844 S    /bin/run_clock -c /dev/tffs -d
  688 root      4392 S    igdd
  689 root      4392 S    igdd
  690 root      4392 S    igdd
  694 root      1360 S    httpd -P /var/run/webcfg.pid -p 81 -c /mod/etc/httpd.
  710 root      1372 S    syslogd -L -C
  712 root      1356 S    /sbin/klogd -c 4
  743 root       996 S    ftpd -D -q -t 120 -m 15 -h FRITZ!Box Fon WLAN 7140 An
  802 root      1368 S    dropbear -p 22 -R
  873 root      1176 S    init
 1758 root      1956 S    wpa_authenticator
 2345 root      7824 S N  ctlmgr
 2348 root      2964 S    dsld -n
 2358 root         0 RWN  [kdsld_token]
 2377 root      7824 S N  ctlmgr
 2378 root      7824 R N  ctlmgr
 2379 root      7824 S N  ctlmgr
 2380 root      7824 S N  ctlmgr
 2381 root      7824 S N  ctlmgr
 2463 root      3012 S N  smbd -D -s /mod/etc/smb.conf
 2777 root      1424 S    dropbear -p 22 -R
 2778 root      1188 S    -sh
 2810 root      1168 R    ps
I think the only problem is the link from AVM login page to Freetz.
Thanks!
Okay. I didn't look at it yet. But I think the link is created in the wrong directory in fwmod. Perhaps you can have a look your self to fwmod.
Regards
Oliver
fusionK
