7140 & Welland Me-740k
pasza_sadyka
5 Dez 2006
Hallo :)
One question - if i want plug-in to FRITZ! 7140 LAN HDD Drive /like welland 740k/ what rj-45 cable mast i use - standard or cross?
Greetings, M.
Hi M.!
I hope, I understood your Problems, you want to connect a harddiscdrive by LAN? That´s not possible. The LAN-Ports are designated for any kinds of computers.
For your projekt use the USB-Port, please.
If you need some further information, let me know it.
Happy christmas!
Rainer
According to the standard it should be a standard cable. But I am quite sure the FritzBox is able to handle both sort of cables.
ChrisLamers
