7141 continuous reset
loplo
17 Sep 2009
I have the hardware (1u1 branding) mentioned in the subject and since today it keeps resetting himself. The Power/DSL starts to blink, WLAN LED goes on and after ~30 seconds all the LEDs flash once and everything starts from the beginning.
I've tried to recover it with "fritz.box_fon_wlan_7141.04.76.recover-image" but I get the following error:
FRITZ!Box Fon WLAN 7141 suchen an: 192.168.178.1
Eine Anlage gefunden! - Ermitteln der aktuellen Version.
Version erfolgreich ermittelt!
Hardware: FRITZ!Box Fon WLAN 7141
Urlader: 1190
Firmware: 40.04.76
Firmware der FRITZ!Box Fon WLAN 7141 ist mit der Recover-Firmware inkompatibel
I've tried to manually set the IP to 192.168.178.2 and connect to it via the webif, without luck.
Does anyone know what to do in this situation?
UPDATE:
My router stopped resetting, the power/DSL is flashing. Ni access via phone nor webif.
I'm able to access it via FTP with adam2:adam2. Can I try fixing something via FTP?
after researching a little bit, I've been able to get the following:
Verbindung mit 192.168.178.1 wurde hergestellt.
220 ADAM2 FTP Server ready
Benutzer (192.168.178.1:(none)): adam2
331 Password required for adam2
Kennwort:
230 User adam2 successfully logged in
ftp> quote GETENV HWRevision
HWRevision            108
200 GETENV command successful
ftp> quote GETENV ProductID
ProductID             Fritz_Box_7141
ftp> quote GETENV annex
annex                 B
ftp> quote GETENV firmware_version
firmware_version      avme
ftp>
Upon seeing "firmware_version avme" I've remembered that a few weeks earlier I've tried to change the language of my device, without success.
Somehow I have to change it back to 1und1
LE:
I did it:
ftp> quote SETENV firmware_version 1und1
200 SETENV command successful
ftp> quote GETENV firmware_info
firmware_info         40.04.76
ftp>
After this the recovery went good and my router works again.
Thanks for this forum and for the search function.
Some moderator can mark this forum as SOLVED.
DanielLares
