7150 don't recover. Can we coverter 7150 to the Spanish or English?
anibal58
9 Jun 2009
Hi I bought on eBay a Fritzfone 7150. I made several attempts to pass to
international version, once I was able to load a 7170 version of Annex A 58.04.78 in English, which worked but had trouble starting (this seems interesting it exists the possibility of using the 7150 English).
For a recommendation EL_VALIENTE generates an image for 7150 with the fritz-to-sport, then I load the firmware updete (said it was not compatible) I continue, the result was that 7150 did not work more. I could be accessed it by ftp, but I don' t know how to repair the 7150 with ftp.
A couple of days, from a notebook with Windows Vista I ran the FRITZ.Fon_7150.AnnexB.04.71.recover-image and gave me:
FT 7150 D suchen an: 169.254.172.1
Eine Anlage gefunden! - Ermitteln der aktuellen Version.
Version erfolgreich ermittelt!
Hardware: FT 7150 D
Urlader: 1413
Firmware: 38.04.77
Flashbereich (mtd1)
Lösche Flashbereich (mtd1)
Löschen der Partition mtd1 fehlgeschlagen! WinError -2
Friends, how do I retrieve my 7150? Can we coverter 7150 to the Spanish or English?
I trust your recommendations, you be patient with my English.
Greetings,
Anibal.
1. set the Speed of the NIC to "10 MBit/s Halfduplex" (LAN).
2. turn off Mediasensing:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters]
"DisableDHCPMediaSense"=dword:00000000
3. Set the IP-Adress of the PC to fixed: 192.168.178.100/255.255.255.0 without Gateway-Ip
4. Do the Recovery again with this FW
Fantastic Doc :doktor:, for 2 months that I have broken 7150.:p:p:p
I tell you my past experience, when I wanted to shift the 7150 to international, I did several tests, but in a moment load an image from 7170 in English. The 7150 uploaded several times after changing some environment variables (I do not know the platform and testing I did was copying recommendations I read in the forums).
But in fact I run a imagen of 7170, I didn' t a full test of the 7150, but I walked through the pages. The 7150 @ 7170 was disabled ISDN, 3 LAN ports, and 2 phone outlets. Worked so that allowed me to upload an image generated by fritz-to-speed '.
Will we be able to pass the English 7150?
Greetings
I was not clear in previous post, I already have recovered the 7150. With your indications I could recover in minutes the 7150.
Greetings, Anibal.
Ok, great! So you can set the Titel of the Thread to [solved]. How: 1.Post/Ändern/Erweitert an than fill [solved] into the titel down... Thx! ;)
Hello DOC:
I found a problem, I can not find where to configure the DECT. Should there be any particular configuration?
Greetings, Anïbal.
I do not know the 7150 as well, but did you activate the expert's view (Expertenansicht).
Hello DOC:
Yes, I tried that option.
Another thing I tried was to load an image I found in 7150 in Italian. The result was the same.
Player appearances cordless phone connects to the base, which does not appear the configuration www for DECT:confused:
Greetings
Uhhh, i think you forgot to flash the DECT-Firmwareupdate ( klick me. ) after recovering... ;)
Serge78
