7170 29.04.67: "ifconfig", "reboot" Befehle: not found
duffy6
24 Dez 2007
habe ein sonderbares Problem:
seit der 29.04.67 gibts auf meiner Box die Befehle ifconfig und reboot (und evtl. noch andere) nicht mehr.
Wie kann denn das sein?
Gruß,
duffy6
Was ist die Ausgabe von "busybox"?
BusyBox v1.8.2 (2008-09-04 11:11:03 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/1"
weitere telnet Verbindung aufgebaut
# busybox
[B][COLOR="Red"]BusyBox v1.12.4[/COLOR][/B] (2009-01-31 07:54:21 CET) multi-call binary
Copyright (C) 1998-2008 Erik Andersen, Rob Landley, Denys Vlasenko
and others. Licensed under GPLv2.
See source distribution for full notice.
Usage: busybox [function] [arguments]...
   or: function [arguments]...
        BusyBox is a multi-call binary that combines many common Unix
        utilities into a single executable.  Most people will create a
        link to busybox for each function they wish to use and BusyBox
        will act like whatever it was invoked as!
Currently defined functions:
        [, [[, addgroup, adduser, ar, arp, arping, ash, awk, basename, bunzip2, bzcat, cat, chmod, chown, chroot, clear, cmp, cp, crond, crontab,
        cryptpw, cut, date, dd, delgroup, deluser, df, diff, dirname, dmesg, dos2unix, du, echo, egrep, env, ether-wake, expr, false, fgrep,
        find, free, ftpget, ftpput, getopt, grep, gunzip, gzip, halt, hdparm, head, hexdump, hostid, hostname, httpd, id, [B][COLOR="#ff0000"]ifconfig[/COLOR][/B], ifdown,
        ifup, inetd, init, insmod, install, ip, kill, killall, klogd, less, ln, logger, login, logname, logread, losetup, ls, lsmod, makedevs,
        md5sum, mdev, mkdir, mkfifo, mknod, mkswap, modprobe, more, mount, mv, nc, netstat, nice, nohup, nslookup, od, passwd, patch, pidof,
        ping, pivot_root, poweroff, printf, ps, pwd, rdate, realpath, [COLOR="#ff0000"][B]reboot[/B][/COLOR], reset, rm, rmdir, rmmod, route, run-parts, sed, setconsole, setlogcons,
        sh, sha1sum, sleep, sort, start-stop-daemon, strings, stty, swapoff, swapon, sync, sysctl, syslogd, tail, tar, tee, telnet, telnetd,
        test, tftp, time, top, touch, tr, traceroute, true, tty, umount, uname, uniq, unix2dos, uptime, usleep, uudecode, uuencode, vconfig,
        vi, wc, wget, which, xargs, yes, zcat
okay, deine Version ist neuer.
Aber was willst Du mir damit sagen?
Updaten?
Wenn ja: WIE (hab keine Fritz)
Busybox hab ich von THE-Construct
Ahhh ;)
Komisch, ich hab grad gemerkt, dass wenn ich
busybox ipconfig
eingebe, dass es dann funktioniert. Das war früher nicht so :verdaech:
Wenn "busybox ifconfig" funktioniert, "ifconfig" aber nicht, dann fehlt einfach der Link von ifconfig auf busybox.
Dass Art und Anzahl der Befehle, von der Version abhängig sind.
Die verfügbaren Befehle sind mehr noch von der Konfiguration als von der Version abhängig. Es gibt zwar immer wieder mal neue Befehle in neueren Versionen, aber die gängigen Befehle gibt es schon länger, und es ist nur die Frage, welche ausgewählt sind und welche nicht.
Und welche Befehle in der Busybox ausgewählt werden und welche nicht, ist auch eine Frage des Speicherplatzes. Und da der Speicherplatz in den Firmwares immer knapper wird, läßt AVM schon mal Befehle, die für nicht notwendig gehalten werden, in der Busybox weg.
Christinakathy
