7170 and GDI printer
vasila
7 Mai 2008
Hello,
My printer HP LaserJet 1000 is a GDI printer, and, according with AVM support i cannot use it in my FB 7170.
This is true ? There is no workaround for this? Any modification ?
Thank you
Best Regards
You can use the "USB-Fernanschluss" Feature. This will forward the USB Port to your PC.
Con: this is no real printserver, only one PC can connect to the printer the same time
Could you explain better this feature?
Thanks in advance
Best regards
The Fernanschluss (Remote Control Unit) is a link between your PC and the USB Port of the Fritzbox. The data transfer is transparent, means your PC "sees" only a USB port but doesnt recognize, that there are a couple of meters network cable between the PC and the USB port. That implies, that the USB port can only be attached by one PC at the same time.
Ok..... I understand the strategy.... However i have one question:
How the PC recognizes the USB as it own hardware ?
Many thanks for your patience
Best Regards
No way without windows
atrora
