7170 external extension
zlotowinfo
5 Nov 2006
anybody know is it possible to enable external extensions on fritzbox 7170?
i use fritz as client in my network, its possible to use only in this network
when i set external IP he does'nt respond
but still not working
1. can login from inside
2. cant login when i change IP to external
3. i can login with CSIPSimple on Android, but works only when i use profile: Fritz!Box
but i wish to use software on computer outside fritz network
there isnt profiles like on csipsimple,
what should be set to login sip extension from outside
Patrick89
