7170: Function of the files in config.export
Fritsy
3 Nov 2008
When i export the configuration of my FritzBox 7170 to a file it contains these files:
ar7.cfg = WAN and LAN configuration data
voip.cfg = VoIP configuration data
wlan.cfg = WLAN configuration data
tr069.cfg= TR069 remote management configuration data
fx_cg = ?
fx_conf = ?
fx_lcr = ?
telefon_misc = ?
phonebook = Content of Advanced Settings -> Telephony -> Telephone Book
calllog = Content of Advanced Settings -> Telephony -> Calls
fonctrl = ?
config = ?
vpn.cfg = VPN configuration data
user.cfg = ?
Is there a way to make the BINFILE's readable?
I would like to know what the function of each file is. Can someone fill in the blanks for me?
Thanks!
Can someone tell me more about these files?
Perhaps it is easier to make these files readable from there original location (/var/flash/). Does anyone know how to do that?
Hi Fritzy,
what's Your real problem? :noidea:
You can see the file contents by typing cat /var/flash/debug.cfg
If You get no response, the file isn't existing, it is a static link only.
If You get "No such file or directory" then there is no file or matching directory.
Joe
These files are encoded:
00000000000000000000000000000000000000000000000006000000060000000600000006000000
00000000000000000000000000000000000000000000000000000000000000008006F02A00000000
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FF
etc. etc.
I want to see what the readable content of these files is.
For example, one of these files contains the dialrules. I want to which.
I need this info to create my own firmware with my own default configuration included but that's another story.
Can someone fill in the blanks for me or make these files readable?
nightdeck
