7270 annexA/annexB?
flemse
14 Mrz 2007
Hi
Is the 7270 annex standard at this time, only one Fritz for both annexA, annexB.
On the download site from avm there are only the language to select, no annex!
I found these product number,
20002403 German
20002436 German (only internet phone, no fixed line)
20002427 English
@flemse:
It depends on the firmware.
In international firmware (latest release v54.04.76_en-de-es-it-fr.image) one may switch between 5 languages and one can select annexA or annexB via the GUI.
Hi
hmmm I just want to know if I bye a 7270 in Germany will it then fit on the DSL line in ex. DK(analog DSL)
My old 7140 is a annexB but I converted to annexA(new bootloader), but it's not so well working on analog DSL line, as the original annexA!
... I just want to know if I bye a 7270 in Germany will it then fit on the DSL line in ex. DK(analog DSL) ...
If you buy a "german" FB7270, it will not work in DK with the factory settings.
So you have to modify it.
The way how to do that depends on the hardware you buy: It is easy in a FB7270v2 and somewhat more sophisticated in a FB7270v3.
You will find all the necessary information in this forum - use the search function.
If you have a 7270 v2, you might try this one here. Since AVM wrote it in the Readme, this firmware should support Annex A and B. Supported languages are English, French, Italian and Spanish.
For the 7270 v3 there's only a german firmware on the AVM server, I'm not 100% sure if the v2 firmware works with v3, but I think so.
v3 firmware 74.04.76
@bjluv:
Yes, you can! See [post=1446606]here[/post]
3cvx
