7270, dnsmasq und lease-time
bailong
7 Mai 2008
ich habe auf meiner Fritzbox dnsmasq laufen, mit einer lease-time von infinite aber sowohl mein ubuntu als auch mein freenas erneuern die IP Adressen im Minutentakt:
Sep  2 07:30:33 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:30:33 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:30:33 apollo dhclient: bound to 10.100.0.101 -- renewal in 119 seconds.
Sep  2 07:30:33 apollo NetworkManager: <info>  DHCP: device eth0 state changed bound -> renew
Sep  2 07:30:33 apollo NetworkManager: <info>    address 10.100.0.101
Sep  2 07:30:33 apollo NetworkManager: <info>    prefix 24 (255.255.255.0)
Sep  2 07:30:33 apollo NetworkManager: <info>    gateway 10.100.0.1
Sep  2 07:30:33 apollo NetworkManager: <info>    hostname 'apollo'
Sep  2 07:30:33 apollo NetworkManager: <info>    nameserver '10.100.0.1'
Sep  2 07:30:33 apollo NetworkManager: <info>    domain name 'fritz.box'
Sep  2 07:32:32 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:32:32 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:32:32 apollo dhclient: bound to 10.100.0.101 -- renewal in 106 seconds.
Sep  2 07:34:18 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:34:18 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:34:18 apollo dhclient: bound to 10.100.0.101 -- renewal in 101 seconds.
Sep  2 07:35:59 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:35:59 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:35:59 apollo dhclient: bound to 10.100.0.101 -- renewal in 95 seconds.
Sep  2 07:37:34 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:37:34 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:37:34 apollo dhclient: bound to 10.100.0.101 -- renewal in 95 seconds.
Sep  2 07:39:09 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 07:39:09 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 07:39:09 apollo dhclient: bound to 10.100.0.101 -- renewal in 85 seconds.
Sep  2 07:40:34 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Hier meine /var/mod/etc/dnsmasq.conf
/var/mod/etc # cat dnsmasq.conf
domain-needed
bogus-priv
log-async=10
dhcp-range=10.100.0.101,10.100.0.149,255.255.255.0,255.255.255.255,infinite
domain=fritz.box
expand-hosts
read-ethers
Warum ignoriert mein ubuntu die infinite lease-time? Viel nerviger ist es beim freenas, da es bei jeder renewal das Interface runter- und wieder hochfährt...
UPDATE: kann ein Admin bitte den typo im Topic ändern? Danke.
Ich hab noch schnell ein sniffer gestartet, anbei das capture file. Offensichtlich vergibt dnsmasq die IP mit einer lease-time von 4 Minuten und einer renewal-time von 2 Minuten.
  • dhcp_dump.pcap.bz2
So, das Problem ist gelöst:
10.100.0.101,10.100.0.149,infinite
erzeugt folgenden Eintrag im Log vom DHCP Client:
Sep  2 17:20:39 apollo dhclient: DHCPREQUEST of 10.100.0.101 on eth0 to 10.100.0.1 port 67
Sep  2 17:20:39 apollo dhclient: DHCPACK of 10.100.0.101 from 10.100.0.1
Sep  2 17:20:39 apollo dhclient: bound to 10.100.0.101 -- renewal in 2147483648 seconds.
Vielleicht sollte man das im Wiki korrigieren, den Eintrag für die Broadcast Adresse scheint er nicht zu mögen:
Im Bereich DHCP Range (eine pro Zeile) werden die Ranges in der Form
[[net:]network-id,]<start-addr>,<end-addr>[[,<netmask>],<broadcast>][,<default lease time>]
eingetragen.
