7270 freetz and Remote Access?
vpe
24 Feb 2006
Hello,
i try 7270 & latest freetz and try AVM Remote Access - after browser read SSL certificate from FBF, then get err and not accessible SSL Remote access and not work normal http access to, until reboot...
How i make wrong please?
I talk about: Permit Access / Remote Access
Here you can enable secure remote administration for your FRITZ!Box.
Remote access is performed using HTTPS and is thus protected by means of a user name and a password.
Enable remote access
no idea? Or nobody use freetz and AVM HTTPS (SSL) Access ???
Without freetz, i never see problem with SSL Access into 7270, 7170...
The replacement of AVM's openssl-libs by freetz leads to reboots of the box when trying to access the box from remote. Make sure the openssl-libs are not replaced either by not choosing packages which replace the openssl-libs or try to build thoses packages statically (can be chosen in menuconfig for a lot of packages). The remote access will work, if the following is NOT set in your .config file
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
Maybe you have to run
make config-clean-deps
after the deselection of those packages.
Details can be found here (unfortunately in German).
Brad
Thx., then i must set
FREETZ_LIB_libcrypto=n
FREETZ_LIB_libssl=n
or
#FREETZ_LIB_libcrypto not set
#FREETZ_LIB_libssl not set
thx...
What is the output of find / -iname 'libcrypto*' ?
root@fritz:/var/mod/root# find / -iname 'libcrypto*'
[COLOR="Red"]/lib[/COLOR]/libcrypto.so
/lib/libcrypto.so.0.9.8
/lib/libcrypto.so.1
[COLOR="Red"]/usr/lib/freetz[/COLOR]/libcrypto.so
/usr/lib/freetz/libcrypto.so.0.9.8
Patrick89
