7270: How i make syslogd and watchdog?
vpe
24 Feb 2006
7270: How i make
(1) syslogd (write log - errors - on some LAN IP address with running syslog daemon) and
(2) watchdog (after lost connection to provider - for example : PPPoE Error - then reboot)?
I not found syslogd inside 7270 .81 last int. firmware :-(
And now i get PPPoE Error 2 times (ATM DSL sync is okay, only reboot solve, in log is only pppoe errors), and i not know why (warm?) after reboot work Okay, but small log buffer inside device is overwriten.
13.07.10 17:08:11 PPPoE error: Timeout.
13.07.10 17:07:58 Internet connection cleared.
13.07.10 17:07:58 PPPoE error: Timeout.
13.07.10 17:07:44 Internet connection cleared.
13.07.10 17:07:44 PPPoE error: Timeout.
13.07.10 17:07:31 Internet connection cleared.
13.07.10 17:07:31 PPPoE error: Timeout.
13.07.10 17:07:17 Internet connection cleared.
13.07.10 17:07:17 PPPoE error: Timeout.
13.07.10 17:07:03 Internet connection cleared.
13.07.10 17:07:03 PPPoE error: Timeout.
Thnx for links for easy solution for (1) and (2), i not have time to compile and space for testing freetz beta, is easier way please?
nobody know?
Some small points:
- No answer doesn't mean, nobody knows the answer.
- Usually there are not so many people willing to build a solution only for you (you know one answer ["freetz"], but someone shall give you a more convient solution). BTW: There is a stable version of freetz available, too.
Enough "complaining" ;-)
You can build a statically linked version of "busybox" containing syslogd and use it on your box.
For you don't like compiling on your own ;-), there is one attached, also e.g. including "cron", which can be used to do your own "watchdog".
Joerg
vapep43913
