7270 SIP/2.0 404 Not Found
toy86
18 Feb 2010
ich habe meine Asterisk installiert und auch eingerichtet. Eingehende Anrufe kommen an, allerdings kann ich nicht raus telefonieren :-(
sip.conf
extentions.conf
[general]
static=yes
writeprotect=yes         ; Ob die Datei von der CLI aus
[default]
include=> 24
include=> 22
include=> 23
[ext-1]
exten=>70037620,1,Dial(SIP/23,1)
exten=>70037620,2,Queue(zentrale,r,,,300)
exten=>70037621,1,Dial(SIP/22,1)
exten=>70037621,2,Queue(zentrale,r,,,300)
exten=> s,1,Queue(zentrale,r,,,300)
[22]
exten=>22,1,Dial(SIP/22)
exten=>22,2,Hangup
[23]
exten=>23,1,Dial(SIP/23)
exten=>23,2,Hangup
exten=>_xxx.,1,Dial(CAPI/@70037620:${EXTEN})
exten=>_xxx.,2,Congestion
[24]
exten=>24,1,Dial(SIP/24)
exten=>24,2,Hangup
exten=>_xxx.,1,Dial,CAPI/@70037621:${EXTEN}
capi.conf
[general]
nationalprefix=0
internationalprefix=00
rxgain=1.0
txgain=1.0
language=de
[ISDN1]
ntmode=no
isdnmode=did
msn=*
incomingmsn=*
defaultcid=70037620
overlapdial=yes
immediate=yes
controller=1
group=1
softdtmf=off
relaxdtmf=off
accountcode=
context=ext-1
bridge=no
devices=2
debug
<--- SIP read from 127.0.0.1:5060 --->
INVITE sip:[email protected]:5061 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK7D7728E3464EBFA0
To: <sip:[email protected]:5061>
Call-ID: [email protected]
CSeq: 26 INVITE
Contact: <sip:[email protected];uniq=8ED0B38A4139F68BBB82F40737B9B>
Max-Forwards: 70
Expires: 120
User-Agent: AVM FRITZ!Box Fon WLAN 7270 54.04.80 (Dec  4 2009)
Supported: 100rel,replaces,timer
Allow-Events: telephone-event,refer
Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH
Content-Type: application/sdp
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Content-Length:   411
v=0
o=user 7719006 7719006 IN IP4 127.0.0.1
s=call
c=IN IP4 127.0.0.1
t=0 0
m=audio 7094 RTP/AVP 9 8 0 2 102 100 99 97 120 121 101
a=sendrecv
a=rtpmap:2 G726-32/8000
a=rtpmap:102 G726-32/8000
a=rtpmap:100 G726-40/8000
a=rtpmap:99 G726-24/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:120 PCMA/16000
a=rtpmap:121 PCMU/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-11
a=rtcp:7095
--- (17 headers 18 lines) ---
Sending to 127.0.0.1 : 5060 (no NAT)
Using INVITE request as basis request - [email protected]
<--- Reliably Transmitting (no NAT) to 127.0.0.1:5060 --->
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK7D7728E3464EBFA0;received=127.0.0.1
To: <sip:[email protected]:5061>;tag=as42664946
CSeq: 26 INVITE
User-Agent: Asterisk PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="5eb41724"
Content-Length: 0
Scheduling destruction of SIP dialog '[email protected]' in 32000 ms (Method: INVITE)
Found user '24'
ACK sip:[email protected]:5061 SIP/2.0
CSeq: 26 ACK
Content-Length: 0
--- (8 headers 0 lines) ---
192*CLI>
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK923C337BF7A78972
CSeq: 27 INVITE
Proxy-Authorization: Digest username="24", realm="asterisk", nonce="5eb41724", uri="sip:[email protected]:5061", response="0dbaeefcd5beb87bc5efd31a5ebaf3bf", algorithm=MD5
Max-Forwards: 70
Expires: 120
Content-Length:   411
v=0
s=call
c=IN IP4 127.0.0.1
t=0 0
a=sendrecv
a=fmtp:97 mode=30
a=fmtp:101 0-11
a=rtcp:7095
--- (18 headers 18 lines) ---
Found user '24'
Found RTP audio format 9
Found RTP audio format 8
Found RTP audio format 0
Found RTP audio format 2
Found RTP audio format 102
Found RTP audio format 100
Found RTP audio format 99
Found RTP audio format 97
Found RTP audio format 120
Found RTP audio format 121
Found RTP audio format 101
Peer audio RTP is at port 127.0.0.1:7094
Found audio description format G726-32 for ID 2
Found audio description format G726-32 for ID 102
Found unknown media description format G726-40 for ID 100
Found unknown media description format G726-24 for ID 99
Found audio description format iLBC for ID 97
Found audio description format PCMA for ID 120
Found audio description format PCMU for ID 121
Found audio description format telephone-event for ID 101
Capabilities: us - 0x3f1fff (g723|gsm|ulaw|alaw|g726|adpcm|slin|lpc10|g729|speex|ilbc|g726aal2|g722|jpeg|png|h261|h263|h263p|h264), peer - audio=0x1c0c (ulaw|alaw|g726|ilbc|g722)/video=0x0 (nothing), combined - 0x1c0c (ulaw|alaw|g726|ilbc|g722)
Non-codec capabilities (dtmf): us - 0x1 (telephone-event), peer - 0x1 (telephone-event), combined - 0x1 (telephone-event)
Looking for 0511123456 in local-sip (domain 127.0.0.1)
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK923C337BF7A78972;received=127.0.0.1
CSeq: 27 INVITE
Supported: replaces
Content-Length: 0
CSeq: 27 ACK
Content-Length: 0
Habe ich einen Fehler gemacht?
Mfg
Toy
was steht denn in der beispiel config? :)
versuchs mal so:
exten => ...,1,Set(CALLERID(all)=XXXXX)
exten => ....,n,Dial(CAPI/ISDN1/${EXTEN},......
Morgen,
ich habe es mal getestet ohne Rufnummerangabe:
[23]
exten=>23,2,Hangup
exten => _XXX.,n,Dial(CAPI/ISDN1/${EXTEN})
Leider stoße ich so auf den selben Fehler...
mfg
toy
das mit den x ist schon ein grosses X in der extensions.conf?
Machs mal nur so, denn du müsstest schon bei 1 anfangen :)
[23]
exten => _X.,1,Dial(CAPI/ISDN1/${EXTEN})
Du hast nämlich prinzipiell 2 ziele beim wählen.
1.) wenn 23 gewählt wird, dann wird die 23 gewählt
exten=>23,2,Hangup
2.) bei allem anderen über diese Regel, die aber nicht mit 1 anfängt und deshalb übergangen wird
kannst du die sip debugs weglassen? was kommt denn als normaler output?
wenn ich
[23]
verwende kommt die selbe Ausgabe wie bei Post 1. Wenn ich debug weg lasse kommt keine Ausgabe.
mfg
toy
beim normalen debug kommt keine ausgabe? hast du den an? im 1. post war war leider nur der "sip debug"
fritz*CLI> sip set debug off
SIP Debugging Disabled
fritz*CLI> core set debug
0        0...     1        1...     2        2...     3        3...     4        4...     5        5...     6        6...     7        7...
8        8...     9        9...     channel  off      atleast
Hast du eigentlich schon asterisk erfahrung, oder ist das die erste?
Guten Morgen,
wenn ich einen core set debug mache kommt keine Ausgabe bei ausgehenden Anrufen... habe von lvl 0-9 alle ausprobiert.
Ich habe eine Fritzbox 7270 und nutze asterisk14.
Ich habe auch alles richtig angeschlossen (Ausgehende und Eingehende Anrufe funktionieren bei der Fritzboxeigenen Telefonverwaltung).
Ja, es ist meine erste Asterisk.
mfg
toy
muss man an der Fritzbox denn auch die MSN's einstellen oder macht das die asterisk komplett selbstständig?
mfg toy
Protonator
