7270 v3 International 74.04.81 firmware
in_the_dark
17 Apr 2010
I posted this following from a previous question I had, but thought it would be best as a new topic. I have the international version of the 7270 v3 FritzBox. I would like to create a Freetz image for it however there is no option to use this version of the firmware (the only option available is the German 74.04.86). I downloaded the image which is included as part of the IPV6 firmware download: http://www.avm.de/de/Service/Service-Portale/Labor/7570_7270_IPv6_en/fritzbox_lab_17599__7270v3.zip.
Can anyone tell me if it's possible to modify the Freetz configuration to use this image .. I have seen something posted on here about incorporating the language files from the international firmware into the German release but haven't not had any success. I'd also like to know if it's possible to create a Recover.exe for this firmware version as it's not available to download from the AVM ftp.
Thank you for your time.
It should work if you select 7270 v2 en in menuconfig. Then rename your v3 firmware file to "FRITZ.Box_Fon_WLAN_7270_16.AnnexB.en-de-es-it-fr.54.04.81.image" and put it to dl/fw or use the override source option in menuconfig if you don't want to rename your file.
Regards
Oliver
Once again, thank you for your help Oliver, your suggestion worked perfectly. I am very much grateful.
