7390 Kein WLAN: ath_dev_attach: unable to attach hardware; HAL status 3
mischmit
16 Mai 2007
Seit kurzem funktioniert WLAN bei meiner 7390 nicht mehr. Ich habe gerade ein neues Image importiert (FRITZ!OS 05.20-freetz-devel-8871). Folgende Einträge im Syslog findet man direkt nach versuchter Aktivierung:
Apr  3 23:36:03 fritz kern.info kernel: [wlan_eeprom] calibration data blocks found = 2
Apr  3 23:36:03 fritz kern.info kernel: [wlan_eeprom] Got calibration data version 255 for instance #1
Apr  3 23:36:03 fritz kern.info kernel: [wlan_eeprom] Using complete eeprom from flash
Apr  3 23:36:03 fritz kern.info kernel: [wlan_eeprom] Got calibration data version 255 for instance #2
Apr  3 23:36:06 fritz kern.info kernel: ath_hal: 0.9.17.1 (AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2316, RF2317, REGOPS_FUNC, WRITE_EEPROM, 11D)
Apr  3 23:36:06 fritz kern.info kernel: ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
Apr  3 23:36:06 fritz kern.info kernel: ath_spectral: Version 2.0.0
Apr  3 23:36:06 fritz kern.info kernel: Copyright (c) 2005-2009 Atheros Communications, Inc. All Rights Reserved
Apr  3 23:36:06 fritz kern.info kernel: SPECTRAL module built on Feb 24 2012 13:42:08
Apr  3 23:36:06 fritz kern.info kernel: ath_dfs: Version 2.0.0
Apr  3 23:36:06 fritz kern.info kernel: Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
Apr  3 23:36:07 fritz kern.info kernel: ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
Apr  3 23:36:11 fritz kern.info kernel: ath_pci: 9.2.0_U7.717 (Atheros/multi-bss)
Apr  3 23:36:11 fritz kern.warn kernel: PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
Apr  3 23:36:11 fritz kern.debug kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
Apr  3 23:36:11 fritz kern.warn kernel: ath_dev_attach: unable to attach hardware; HAL status 3
Apr  3 23:36:11 fritz kern.warn kernel: PCI: Enabling device 0000:00:02.0 (0000 -> 0002)
Apr  3 23:36:11 fritz kern.debug kernel: PCI: Setting latency timer of device 0000:00:02.0 to 64
Sieht das nach einem Hardware-Problem aus oder kann das etwas mit Freetz zu tun haben?
Hier noch das /var/tmp/wland_support.log
WLAND:[00829]:23:36.01:error: unknown symbol: event_control
WLAND:[00829]:23:36.01:error: unknown symbol: night_time_control_auto_update
WLAND:[00829]:23:36.01:error: unknown symbol: feature_wlan_coexistence
WLAND:[00829]:23:36.02:config_mgr_phy_params_fix(97): master_set is 0x00000003 (config #2)
WLAND:[00829]:23:36.02:config_mgr_phy_params_fix(117): master role #2 is not STA(1)
WLAND:[00829]:23:36.02:config_mgr_phy_params_fix(117): master role #1 is not STA(1)
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #9
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #8
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #7
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #6
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #5
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #4
WLAND:[00829]:23:36.02:config_mgr_wps_params_fix(177): parameter 'wps_enable' set to '0' in role #3
WLAND:[00829]:23:36.22:cfg_mgr_changes_apply: apply configuration failed, status 0x80000001
Dann probier doch mal ohne Freetz. Und häng bitte deine .config hier an.
Oliver
Hallo Oliver,
wie gewünscht die .config
Kann ich das Image ohne Freetz einfach "drüberbügeln" oder geht das nur mit Recovery-Image und Neueingabe aller Daten?
Michael
Ich würde dir vorher eine Datensicherung empfehlen. Normalerweise lässt sich ein Image mit gleicher Version ohne Probleme "überspielen".
Oliver
fusionK
