[Gelöst] 7490 & freetz 11069 & openntpd
xsapling
30 Jan 2005
im Einsatz ist eine 7490
Boxtyp7490 AVM-Firmwareversion05.59 SprachedeKernelversion2.6.32.60 (hjortmann@EmbeddedVM) (gcc version 4.6.3 (Buildroot 2011.11) )
Freetz-Versionfreetz-devel-11069
Erstellungsdatum08.10.2013 04:25:16
Ursprünglicher Dateiname7490_05.59-freetz-devel-11069.de_20131008-042516.image
mit folgender Config:
FREETZ_HAVE_DOT_CONFIG=yFREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
FREETZ_TYPE_7490=y
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_FIRMWARE_05_5X=y
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
FREETZ_REMOVE_CHRONYD=y
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_AVM_E2FSPROGS=y
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_EXT4=y
FREETZ_AUTOMOUNT_FAT=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_AUTOMOUNT_REISER_FS=y
FREETZ_AUTOMOUNT_LINUXSWAP=y
FREETZ_PATCH_MAXDEVCOUNT=y
FREETZ_ADD_ETCSERVICES=y
FREETZ_AVMDAEMON_DISABLE_NTP=y
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY=y
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
FREETZ_PACKAGE_DROPBEAR_STATIC=y
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_INETD=y
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
FREETZ_PACKAGE_NANO=y
FREETZ_PACKAGE_NANO_TINY=y
FREETZ_PACKAGE_NANO_MULTIBUFFER=y
FREETZ_PACKAGE_NANO_NANORC=y
FREETZ_PACKAGE_NANO_COLOR_SYNTAX=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_SH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_NANORC=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_C=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_CSS=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_HTML=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PHP=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_TEX=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_PATCH=y
FREETZ_PACKAGE_NANO_SYNTAX_FILE_XML=y
FREETZ_PACKAGE_OPENNTPD=y
FREETZ_PACKAGE_OPENSSH=y
FREETZ_PACKAGE_OPENSSH_sshd=y
FREETZ_PACKAGE_OPENSSH_ssh=y
FREETZ_PACKAGE_OPENSSH_scp=y
FREETZ_PACKAGE_OPENSSH_CLIENTUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_add=y
FREETZ_PACKAGE_OPENSSH_ssh_agent=y
FREETZ_PACKAGE_OPENSSH_KEYUTILS=y
FREETZ_PACKAGE_OPENSSH_ssh_keygen=y
FREETZ_PACKAGE_OPENSSH_ssh_keysign=y
FREETZ_PACKAGE_OPENSSH_ssh_keyscan=y
FREETZ_PACKAGE_OPENSSH_sftp=y
FREETZ_PACKAGE_OPENSSH_sftp_server=y
FREETZ_PACKAGE_OPENSSH_STATIC=y
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
FREETZ_PACKAGE_OPENVPN_USE_V2_CGI=y
FREETZ_PACKAGE_SCREEN=y
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
FREETZ_PACKAGE_WGET_USE_GNUTLS=y
FREETZ_PACKAGE_WGET_STATIC=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_VIRTUALIP_CGI=y
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FIREWALL=y
FREETZ_PACKAGE_OPENVPN_V2_CGI=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
FREETZ_LIB_libncurses=y
FREETZ_SHARE_terminfo=y
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUS256color=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libctlmgr=y
FREETZ_KERNEL_VERSION_2_6_32_60=y
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_VR9=y
FREETZ_KERNEL_LAYOUT="vr9"
FREETZ_MODULES_KVER="2.6.32.60"
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__IPV6_UTILS=y
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
FREETZ_BUSYBOX_PLATFORM_LINUX=y
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
FREETZ_BUSYBOX_PREFIX="./_install"
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_TEST=y
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
FREETZ_BUSYBOX_DF=y
FREETZ_BUSYBOX_DIRNAME=y
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
FREETZ_BUSYBOX_EXPR=y
FREETZ_BUSYBOX_FALSE=y
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NOHUP=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
FREETZ_BUSYBOX_SORT=y
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
FREETZ_BUSYBOX_SYNC=y
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
FREETZ_BUSYBOX_UUDECODE=y
FREETZ_BUSYBOX_WC=y
FREETZ_BUSYBOX_YES=y
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
FREETZ_BUSYBOX_WHICH=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_AWK=y
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
FREETZ_BUSYBOX_USE_BB_CRYPT=y
FREETZ_BUSYBOX_ADDUSER=y
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
FREETZ_BUSYBOX_LOGIN=y
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
FREETZ_BUSYBOX_MKSWAP=y
FREETZ_BUSYBOX_MOUNT=y
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
FREETZ_BUSYBOX_SWAPONOFF=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP=y
FREETZ_BUSYBOX_CROND=y
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
FREETZ_BUSYBOX_MAKEDEVS=y
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
FREETZ_BUSYBOX_BRCTL=y
FREETZ_BUSYBOX_ETHER_WAKE=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_NETSTAT=y
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_ROUTE=y
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_BB_SYSCTL=y
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
FREETZ_LANG_DE=y
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
FREETZ_STYLE="colored"
FREETZ_SKIN_legacy=y
FREETZ_FAVICON_NONE=y
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
FREETZ_TAGGING_STRING="none"
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
FREETZ_DOWNLOAD_TOOLCHAIN=y
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
FREETZ_TARGET_UCLIBC_0_9_32=y
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
FREETZ_TARGET_LFS=y
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
FREETZ_STRIP_BINARIES=y
FREETZ_STRIP_MODULES_FREETZ=y
FREETZ_DL_SITE_USER=""
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="4622c6e00b05f6369ed3d777acb57ad2"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="b3d4da39d502edb1efa35930cd612a8c"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="4f90f19af6555ae164d2614052a332d3"
FREETZ_DL_SITE="@AVM/fritzbox.7490/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_7490.113.05.59.image"
FREETZ_DL_SOURCE_MD5="0edf6e0a84c1695cebdecc8dfc9bf8bb"
FREETZ_AVM_HAS_FW55X=y
FREETZ_AVM_HAS_LANG_DE=y
FREETZ_AVM_UCLIBC_0_9_32=y
FREETZ_AVM_GCC_4_6=y
FREETZ_AVM_HAS_PRINTK=y
FREETZ_AVM_HAS_PTY_SUPPORT=y
FREETZ_AVM_HAS_AURA_USB=y
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE=y
FREETZ_AVM_HAS_USB_HOST=y
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_AHA=y
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7360_05_51=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_05_5X=y
FREETZ_AVM_VERSION_STRING="7360_05.51"
FREETZ_TYPE_PREFIX="7490"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_5X"
Problem an der Sache ist, dass der openntpd nicht arbeiten will, d.h. die Zeit der Box nicht synchronisiert wird.
Das sylog ist meines Erachtens nicht aussagekräftig:
[COLOR=#000000]Jan  1 08:49:02 fritz daemon.info ntpd[4872]: ntp engine exiting[/COLOR]
Jan  1 08:49:02 fritz daemon.crit ntpd[4873]: dispatch_imsg in main: pipe closed
Jan  1 08:49:02 fritz daemon.info ntpd[4873]: Terminating
Jan  1 08:49:04 fritz daemon.info ntpd[6958]: listening on 0.0.0.0
[COLOR=#000000]Jan  1 08:49:04 fritz daemon.info ntpd[6958]: ntp engine ready[/COLOR]
Ich habe bereits im syslogd das Loglevel auf 8 erhöht, ohne dass ich weitere Angaben zum Nichtfunktionieren von Openntpd erhalte. Gibt es eine Möglichkeit, von openntpd mehr Ausgaben über dessen Funktionieren bzw. Nichtfunktionieren zu erhalten?
Kann man den ntpd vielleicht per Hand mit Debug-Option aufrufen?
Oliver
mein Problem besteht darin versucht zu haben über eine normale ssh-Verbindung den ntp-udp-Port zu leiten. Das funktioniert wohl so nicht ohne Weiteres.
Da ich die hier gegebene Firewall nicht ändern kann und diese den ntp-Port blockiert suche ich nach einer Möglichkeit, durch die Firewall hindurch die ntpd-Abragen zu schleusen.
Hat jemand einen Ansatz?
Die Variante mit opnvpn scheitert bei mir, da wegen des Startdatum 1970 die Zertificate als ungültig angesehen werden. Ein nach dem Start durchgeführtes date auf ein Datum neueren Datums (so dass Openvpn die Zertifikate nun doch benutzen kann) führt dazu, dass der Volumenzähler zurückgesetzt wird. Ist also auch nicht die brauchbare Variante.
Erstens startet die Box nicht mit 1970, und zweitens kannst Du Zertifikate erstellen, die auch für das Datum auf der Box gültig sind.
Du kannst aber auch über http das aktuelle Datum von einer Webseite holen.
Meine Box startet mit 01.01.2000, es ist aber auch keine 7490.
Zumindest Apache liefert in der Standard-Einstellung das Datum mit.
wget -S -O /dev/null http://web.de/ 2>&1 | grep Date
geblockter Port war die Ursache. Openntpd funktioniert jetzt über eine openvpn-Verbindung.
Bei Ntpd könnte man wohl abweichende Ports angeben für den Fall, dass die Standart-Ports gesperrt sind. Könnte das Paket evtl zusätzlich angeboten werden?
Welches Paket meinst du jetzt?
Problem an der Sache ist, ......, d.h. die Zeit der Box nicht synchronisiert wird.
Meine 7490 läuft 1A inkl. Zeitsync (benutzt Firmware: 113.05.59 rev26609 / Freetz: devel-11105M )
onlinechanged.log
1970-01-01 01:00:41 [1376]: [online] sleeping
2013-10-23 10:29:27 [1376]: [online] approved
2013-10-23 10:29:27 [1376]: [online] executing /etc/onlinechanged/webdav_net
2013-10-23 10:29:28 [1376]: [online] finished
2013-10-23 10:29:58 [3283]: [offline] approved
2013-10-23 10:29:58 [3283]: [offline] executing /etc/onlinechanged/webdav_net
2013-10-23 10:29:59 [3283]: [offline] finished
2013-10-23 10:32:10 [4707]: [online] approved
2013-10-23 10:32:10 [4707]: [online] executing /etc/onlinechanged/webdav_net
2013-10-23 10:32:11 [4707]: [online] finished
vapep43913
