7590 in bootloop: I can recover it with the avm program, but still bootloop.
saronno
22 Jan 2025
I bought this 7590 on ebay as faulty just for fun. As described by the seller, it is actually in bootloop.
So, first thing, I try to use the recovery exe from avm ... and everything was ok. But it still is in a bootloop.
Anyway I soldered the uart pins and so this is the log:
Detected PXB4583el V1.2-2000
.[piglet] Suceeded
(AVM) EVA Revision: 1.3258
(C) Copyright 2005 AVM Date: Mar 10 2017 Time: 12:11:34 (1) 3 0x0-0x46409
[NAND:] 512MB TOSHIBA 4096 Pagesize 256k Blocksize 2048 Blocks
[SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz
#Loading compressed kernel to 0x852852B0
...........................................................................................................................................Device Tree Blob for SubRevision 4 not found.
Using Device Tree Blob of SubRevision 0
Switching to Bootcore Console
[ 0.000000][ T0] Linux version 4.9.325 ([email protected]) (gcc version 8.4.0 (Buildroot 2020.02.1-g3ef93f8b) ) #1 2024-12-05
[ 0.000000][ T0] avm_check_isa_features: isa_level 0x00000031
[ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001
[ 0.000000][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[ 0.000000][ T0] SoC: GRX500 rev 1.2
[ 0.000000][ T0] bootconsole [early0] enabled
[ 0.000000][ T0] CPU0 revision is: 00019074 (MIPS 4KEc)
[ 0.000000][ T0] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec)
[ 0.000000][ T0] Determined physical RAM map:
[ 0.000000][ T0] memory: 02000000 @ 0e000000 (usable)
[ 0.000000][ T0] memory: 00001be8 @ 0e7bc030 (reserved)
[ 0.000000][ T0] memory: 00001000 @ 3dfb0000 (reserved)
[ 0.000000][ T0] memory: 00040000 @ 0dfc0000 (reserved)
[ 0.000000][ T0] Initial ramdisk at: 0x8e000000 (4194304 bytes)
[ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004
[ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes.
[ 0.000000][ T0] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes
[ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000000c0005d638b
[ 0.000000][ T0] Zone ranges:
[ 0.000000][ T0] Normal [mem 0x000000000e000000-0x000000000fffffff]
[ 0.000000][ T0] Movable zone start for each node
[ 0.000000][ T0] Early memory node ranges
[ 0.000000][ T0] node 0: [mem 0x000000000e000000-0x000000000fffffff]
[ 0.000000][ T0] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff]
[ 0.000000][ T0] On node 0 totalpages: 8192
[ 0.000000][ T0] free_area_init_node: node 0, pgdat 8e7bb1c4, node_mem_map 8f005a00
[ 0.000000][ T0] Normal zone: 64 pages used for memmap
[ 0.000000][ T0] Normal zone: 0 pages reserved
[ 0.000000][ T0] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000][ T0] [fw-info] Version 08.02 buildnr=117975 buildtype=1
[ 0.000000][ T0] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000][ T0] pcpu-alloc: [0] 0
[ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8
[ 0.000000][ T0] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000][ T0] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000][ T0] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000][ T0] Memory: 23752K/32768K available (2931K kernel code, 461K rwdata, 680K rodata, 208K init, 262K bss, 9016K reserved, 0K cma-reserved)
[ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000][ T0] NR_IRQS:527
[ 0.000000][ T0] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f
[ 0.000000][ T0] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000
[ 0.000000][ T0] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000
[ 0.000000][ T0] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f
[ 0.000000][ T0] CPU Clock: 300MHz
[ 0.000000][ T0] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns
[ 0.000020][ T0] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns
[ 0.016975][ T0] : grx500_bootcore_console_init: call register
[ 0.028759][ T0] console [ttyLTQ0] enabled
[ 0.041314][ T0] bootconsole [early0] disabled
[ 0.054916][ T0] bootconsole [early0] disabled
[ 0.064267][ T0] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528)
[ 0.107014][ T0] pid_max: default: 32768 minimum: 301
[ 0.113259][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.120409][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.134867][ T1] Performance counters: No available PMU.
[ 0.143900][ T1] devtmpfs: initialized
[ 0.153273][ T1] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff]
[ 0.159688][ T1] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff]
[ 0.166690][ T1] ngi: Unattached: [0x60000000, 0x9fffffff]
[ 0.172392][ T1] ngi: Unattached: [0x40000000, 0x5fffffff]
[ 0.178832][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.189167][ T1] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.196272][ T1] pinctrl core: initialized pinctrl subsystem
[ 0.204993][ T1] NET: Registered protocol family 16
[ 0.227465][ T1] irq: no irq domain found for /interrupt-controller@0x14900140 !
[ 0.327138][ T1] clocksource: Switched to clocksource MIPS
[ 0.355557][ T1] NET: Registered protocol family 2
[ 0.361100][ T1] IP idents hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.370212][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.377908][ T1] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.384845][ T1] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.392395][ T1] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.398895][ T1] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.406326][ T1] NET: Registered protocol family 1
[ 0.415459][ T1] Unpacking initramfs...
[ 1.155461][ T1] Freeing initrd memory: 4096K
[ 1.162561][ T1] No memory allocated for crashlog
[ 1.175491][ T1] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 1.253448][ T1] Serial: grx500_bootcore driver init
[ 1.267464][ T1] NET: Registered protocol family 10
[ 1.285139][ T1] NET: Registered protocol family 17
[ 1.298724][ T1] Serial: grx500_bootcore driver startup
[ 1.304201][ T1] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008
[ 1.312950][ T1] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003
[ 1.322710][ T1] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003
[ 1.332125][ T1] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000
[ 1.345077][ T1] Freeing unused kernel memory: 208K
[ 1.350127][ T1] This architecture does not have kernel memory protection.
[ 1.562387][ T195] eip123_hw: module license 'Proprietary' taints kernel.
[ 1.569278][ T195] Disabling lock debugging due to kernel taint
[ 1.580569][ T195] eip123: no symbol version for eip123_hw_asset_derive
[ 1.589035][ T195] eip123 1e000000.eip123: Detected hardware version 2.2.2
[ 1.595993][ T195] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256
[ 1.604594][ T195] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000
[ 1.612107][ T195] eip123 1e000000.eip123: Linked mailbox number 1
[ 1.643208][ T195] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0
[ 1.879156][ T195] eip123 1e000000.eip123: eip123_hw init successful
[ 1.939181][ T195] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c
[ 1.948291][ T195] eip123 1e000000.eip123: Could not find rootkey in OTP
[ 1.983313][ T198] random: crng init done
[ 1.988234][ T110] shm-rng-seed shm-rng-seed@3dfb0000: Added 4088 random bytes to the shared memory area
[ 3.670938][ T263] eip123 1e000000.eip123: Unlinked mailboxes
^H▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒H▒H▒H▒▒ݥэ▒▒▒▒▒to Interaptiv Console
[ 0.000000][ T0] shm-rng-seed-mem@3dfb0000: Added 4088 random bytes to the system pool
[ 0.000000][ T0] OF: fdt:[0x39da0000, 0x3b083850) is not contained in the RAM region at [0x20000000, 0x2e000000)
[ 0.000000][ T0] Linux version 4.9.325 ([email protected]) (gcc version 8.4.0 (Buildroot 2020.02.1-g3ef93f8b) ) #1 SMP 2024-12-05
[ 0.000000][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030
[ 0.000000][ T0] CPU0 revision is: 0001a120 (MIPS interAptiv (multi))
[ 0.000000][ T0] Enhanced Virtual Addressing (EVA Legacy 512MB) activated
[ 0.000000][ T0] MIPS: machine is AVM7590 (GRX550, HW226) Main model
[ 0.000000][ T0] Coherence Manager IOCU detected
[ 0.000000][ T0] Hardware DMA cache coherency disabled
[ 0.000000][ T0] OF: reserved mem: initialized node shm-rng-seed-mem@3dfb0000, compatible id avm,shm-rng-seed-early
[ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000
[ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000
[ 0.000000][ T0] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200
[ 0.000000][ T0] memory: 10000000 @ 30000000 (usable)
[ 0.000000][ T0] memory: 0e000000 @ 20000000 (usable)
[ 0.000000][ T0] memory: 0000cf74 @ 3a9cc038 (reserved)
[ 0.000000][ T0] memory: 00040000 @ 2dfc0000 (reserved)
[ 0.000000][ T0] memory: 00400000 @ 20100000 (reserved)
[ 0.000000][ T0] memory: 00030000 @ 20010000 (reserved)
[ 0.000000][ T0] memory: 00001200 @ 20000000 (reserved)
[ 0.000000][ T0] Kernel relocated by 0x198a0000
[ 0.000000][ T0] .text @ 0x99da0000
[ 0.000000][ T0] .data @ 0x9a663dfc
[ 0.000000][ T0] .bss @ 0x9abb0000
[ 0.000000][ T0] Initrd not found or empty - disabling initrd
[ 0.000000][ T0] cma: Reserved 64 MiB at 0x24000000
[ 0.000000][ T0] SMPCMP: initialized the EVA stub code: 400@0x28029480
[ 0.000000][ T0] SMPCMP: CPU0: cmp_smp_setup
[ 0.000000][ T0] VPE topology {2,2} total 4
[ 0.000000][ T0] Detected 3 available secondary CPU(s)
[ 0.000000][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[ 0.000000][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.000000][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[ 0.000000][ T0] DMA [mem 0x0000000020000000-0x0000000027ffffff]
[ 0.000000][ T0] Normal [mem 0x0000000028000000-0x000000003fffffff]
[ 0.000000][ T0] node 0: [mem 0x0000000020000000-0x000000002dffffff]
[ 0.000000][ T0] node 0: [mem 0x0000000030000000-0x000000003fffffff]
[ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff]
[ 0.000000][ T0] [module-mem] Use 0x3c59d000-0x3d0d5fff (mapped at 9c59d000-9d0d5fff) for 94 modules
[ 0.000000][ T0] percpu: Embedded 12 pages/cpu s18096 r8192 d22864 u49152
[ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121728
[ 0.000000][ T0] Kernel command line: console=ttyLTQ0,115200 pcmlink.abmode=0x8103 Piglet_noemif.piglet_dectmode=0x110 Piglet_noemif.piglet_bitfile=/lib/modules/bitfile.bit audit=1 slub_debug=fl
[ 0.000000][ T0] audit: enabled (after initialization)
[ 0.000000][ T0] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000][ T0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000][ T0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000][ T0] Writing ErrCtl register=00000000
[ 0.000000][ T0] Readback ErrCtl register=00000000
[ 0.000000][ T0] Memory: 385192K/491520K available (8750K kernel code, 1860K rwdata, 1884K rodata, 1680K init, 4942K bss, 40792K reserved, 65536K cma-reserved)
[ 0.000000][ T0] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000][ T0] Hierarchical RCU implementation.
[ 0.000000][ T0] EIC is off
[ 0.000000][ T0] VINT is on
[ 0.000000][ T0] CPU Clock: 1000000000Hz mips_hpt_frequency 500000000Hz
[ 0.000000][ T0] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns
[ 0.010148][ T0] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696)
[ 0.046803][ T0] pid_max: default: 32768 minimum: 301
[ 0.052296][ T0] Security Framework initialized
[ 0.057078][ T0] AppArmor: AppArmor initialized
[ 0.061970][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.069290][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.078836][ T1] CCA is coherent, multi-core is fine
[ 0.084493][ T1] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0
[ 0.090733][ T1] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9
GOT IPI to launch from CPU 1
GOT IPI to launch from CPU 2
GOT IPI to launch from CPU 3
[ 0.109220][ T0] avm_check_isa_features: isa_level 0x00000031
[ 0.109266][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[ 0.109271][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[ 0.109294][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[ 0.109302][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.109309][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.109321][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.109326][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[ 0.109524][ T0] CPU1 revision is: 0001a120 (MIPS interAptiv (multi))
[ 0.139595][ T0] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1
[ 0.142037][ T0] avm_check_isa_features: isa_level 0x00000031
[ 0.142073][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[ 0.142077][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[ 0.142096][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[ 0.142103][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.142108][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.142119][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.142124][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[ 0.142265][ T0] CPU2 revision is: 0001a120 (MIPS interAptiv (multi))
[ 0.169872][ T0] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0
[ 0.172350][ T0] avm_check_isa_features: isa_level 0x00000031
[ 0.172386][ T0] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[ 0.172390][ T0] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[ 0.172408][ T0] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[ 0.172415][ T0] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.172419][ T0] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.172430][ T0] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[ 0.172434][ T0] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[ 0.172571][ T0] CPU3 revision is: 0001a120 (MIPS interAptiv (multi))
[ 0.200172][ T0] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1
[ 0.200434][ T1] Brought up 4 CPUs
[ 0.470618][ T1] avm_yield_setup: YIELD_PCMFRAME_ID : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15
[ 0.480246][ T1] avm_yield_setup: YIELD_PCMLINK_ID : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12
[ 0.489881][ T1] avm_yield_setup: YIELD_MONITOR_IPI0_ID : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14
[ 0.499516][ T1] avm_yield_setup: YIELD_PROFILE_IPI0_ID : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13
[ 0.509153][ T1] avm_yield_setup: YIELD_GPTC_ID : id=0x0005000b: cpu=0 tc=5 prio=3 signal=11
[ 0.519320][ T3] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1
[ 0.526460][ T29] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2
[ 0.533613][ T29] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3
[ 0.540719][ T29] [0][yield_context_init] cpu=0 tc=5 mask=0800 tc_prio=3
[ 0.547730][ T1] avm_yield_setup: YIELD_MONITOR_IPI1_ID : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14
[ 0.557179][ T1] avm_yield_setup: YIELD_PROFILE_IPI1_ID : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13
[ 0.567212][ T21] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1
[ 0.575085][ T1] devtmpfs: initialized
[ 0.593807][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.604422][ T1] futex hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.616120][ T1] pinctrl core: initialized pinctrl subsystem
[ 0.623550][ T1] NET: Registered protocol family 16
[ 0.633896][ T1] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 29 irq_base 30
[ 0.645781][ T1] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64
[ 0.656007][ T1] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101
[ 0.666873][ T1] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16
[ 0.675319][ T1] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118
[ 0.686668][ T1] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32
[ 0.695623][ T1] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151
[ 0.706524][ T1] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16
[ 0.714913][ T1] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168
[ 0.725632][ T1] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12
[ 0.740472][ T1] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 218 irq_base 219
[ 0.749209][ T1] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16
[ 0.757871][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff
[ 0.769550][ T1] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f
[ 0.781662][ T1] intel-pinctrl 16c80000.pinctrl: Total 14 groups, 12 functions
[ 0.790104][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000
[ 0.798092][ T1] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100
[ 0.813983][ T1] gic_timer_probe
[ 0.817482][ T1] gic_timer_probe: irq=287 freq=1000000000
[ 0.858776][ T1] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288) alloced
[ 0.868868][ T1] Reboot Status is: Soft-Reboot
[ 0.873648][ T1] Unable to get node cqm for prx300-cqm
[ 0.878969][ T1] add_cqm_dev(#152): parse_dts fail for prx300-cqm
[ 0.885565][ T1] No rcu reset for cbm
[ 0.889383][ T1] No syscon phandle specified for wan mux
[ 0.895030][ T1] Invalid args in ltq_dqm_ports
[ 0.899797][ T1] Invalid args in ltq_eqm_ports
[ 0.975022][ T1] [cbm] { cbm_xrx500_probe : 5697 }reserving 18874368 bytes @ 84000000 for CBM
[ 1.014802][ T1] [cbm] { cbm_xrx500_probe : 5707 }reserving 8388608 bytes @ 85200000 for CBM
[ 1.023435][ T1] [cbm] { cbm_xrx500_probe : 5722 }94 irq
[ 1.029154][ T1] [cbm] { cbm_xrx500_probe : 5745 }2
[ 1.034299][ T1] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 0Hz=0MHZ
[ 1.041406][ T1] [drv_tmu_ll] { get_cbm_clock : 7608 }Wrong cbm clock
[ 1.048179][ T1] Initializing TMU with Base Address=be700000: ...
[ 1.057426][ T1] TMU Initialization Done
[ 1.061448][ T1] 0x84000000 0x1200000 0x800
[ 1.065959][ T1] 0x84000000 0x1200000
[ 1.069933][ T1] 0x85200000 0x800000 0x2000
[ 1.074461][ T1] 0x85200000 0x800000
[ 1.078684][ T1] [cbm] { init_fsqm_buf_std : 1173 }init fsqm std successfully
[ 1.085944][ T1] [cbm] { init_fsqm_buf_jumbo : 1213 }init fsqm jbo successfully
[ 1.093548][ T1] [cbm] { init_fsqm : 1236 }fsqm init successfully
[ 1.099974][ T1] [cbm] { init_cbm_basic : 1271 }PHY ADDR STD 0x24000000
[ 1.106917][ T1] [cbm] { init_cbm_basic : 1272 }PHY ADDR JBO 0x25200000
[ 1.114101][ T1] [cbm] { init_cbm_basic : 1290 }init basic CBM successfully
[ 1.121156][ T1] [cbm] { cbm_hw_init : 2206 }CBM HW init
[ 1.126915][ T1] [cbm] { setup_DMA_p2p : 5102 }setup_DMA_p2p executed
[ 1.133571][ T1] [cbm] { reserved_ports_highest : 5161 }2 2 19 35
[ 1.139991][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2
[ 1.145661][ T1] [cbm] { assign_port_from_DT : 654 }0x0 2
[ 1.151369][ T1] [cbm] { assign_port_from_DT : 654 }0x20 2
[ 1.157369][ T1] [cbm] { cbm_add_to_list : 450 }1
[ 1.162222][ T1] [cbm] { reserved_ports_highest : 5161 }1 1 18 34
[ 1.168633][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1
[ 1.174287][ T1] [cbm] { assign_port_from_DT : 654 }0x80 1
[ 1.180095][ T1] [cbm] { reserved_ports_highest : 5161 }3 3 20 36
[ 1.186516][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3
[ 1.192167][ T1] [cbm] { assign_port_from_DT : 654 }0x2000000 3
[ 1.198409][ T1] [cbm] { cbm_add_to_list : 450 }1
[ 1.203449][ T1] [cbm] { reserved_ports_highest : 5161 }6 6 0 16
[ 1.209780][ T1] [cbm] { dma_port_enable : 4670 }6 0x4
[ 1.215258][ T1] [cbm] { reserved_ports_highest : 5161 }7 7 1 17
[ 1.221584][ T1] [cbm] { dma_port_enable : 4670 }7 0x4
[ 1.227062][ T1] [cbm] { reserved_ports_highest : 5161 }8 8 2 18
[ 1.233395][ T1] [cbm] { dma_port_enable : 4670 }8 0x4
[ 1.238874][ T1] [cbm] { reserved_ports_highest : 5161 }9 9 3 19
[ 1.245198][ T1] [cbm] { dma_port_enable : 4670 }9 0x4
[ 1.250673][ T1] [cbm] { reserved_ports_highest : 5161 }10 10 4 20
[ 1.257173][ T1] [cbm] { dma_port_enable : 4670 }10 0x4
[ 1.262738][ T1] [cbm] { reserved_ports_highest : 5161 }11 11 5 21
[ 1.269239][ T1] [cbm] { dma_port_enable : 4670 }11 0x4
[ 1.274803][ T1] [cbm] { reserved_ports_highest : 5161 }12 12 6 22
[ 1.281305][ T1] [cbm] { dma_port_enable : 4670 }12 0x4
[ 1.286869][ T1] [cbm] { reserved_ports_highest : 5161 }13 13 7 23
[ 1.293371][ T1] [cbm] { dma_port_enable : 4670 }13 0x4
[ 1.298934][ T1] [cbm] { reserved_ports_highest : 5161 }14 14 8 24
[ 1.305436][ T1] [cbm] { dma_port_enable : 4670 }14 0x4
[ 1.311000][ T1] [cbm] { reserved_ports_highest : 5161 }15 15 9 25
[ 1.317506][ T1] [cbm] { dma_port_enable : 4670 }15 0x4
[ 1.323072][ T1] [cbm] { reserved_ports_highest : 5161 }16 16 10 26
[ 1.329658][ T1] [cbm] { dma_port_enable : 4670 }16 0x4
[ 1.335219][ T1] [cbm] { reserved_ports_highest : 5161 }17 17 11 27
[ 1.341806][ T1] [cbm] { dma_port_enable : 4670 }17 0x4
[ 1.347370][ T1] [cbm] { reserved_ports_highest : 5161 }18 18 -16 0
[ 1.353959][ T1] [cbm] { dma_port_enable : 4670 }18 0x4
[ 1.359539][ T1] [cbm] { reserved_ports_highest : 5161 }19 19 12 28
[ 1.366111][ T1] [cbm] { dma_port_enable : 4670 }19 0x4
[ 1.371675][ T1] [cbm] { reserved_ports_highest : 5161 }20 20 13 29
[ 1.378263][ T1] [cbm] { dma_port_enable : 4670 }20 0x4
[ 1.383827][ T1] [cbm] { init_special_ports : 5168 }20
[ 1.389289][ T1] [cbm] { cbm_add_to_list : 450 }1
[ 1.394321][ T1] [cbm] { reserved_ports_highest : 5161 }21 21 14 30
[ 1.400923][ T1] [cbm] { dma_port_enable : 4670 }21 0x4
[ 1.406488][ T1] [cbm] { init_special_ports : 5168 }21
[ 1.411944][ T1] [cbm] { cbm_add_to_list : 450 }1
[ 1.416977][ T1] [cbm] { reserved_ports_highest : 5161 }22 22 25 41
[ 1.423574][ T1] [cbm] { dma_port_enable : 4670 }22 0x4
[ 1.429139][ T1] [cbm] { reserved_ports_highest : 5161 }23 23 15 31
[ 1.435727][ T1] [cbm] { init_cbm_dqm_ldma_port : 1476 }23
[ 1.441552][ T1] [cbm] { reserved_ports_highest : 5161 }5 5 21 37
[ 1.447966][ T1] [cbm] { init_cbm_dqm_scpu_port : 1457 }5
[ 1.453875][ T1] [cbm] { reserved_ports_highest : 5161 }4 4 16 32
[ 1.460117][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }4
[ 1.465768][ T1] [cbm] { assign_port_from_DT : 654 }0x18 4
[ 1.471577][ T1] [cbm] { reserved_ports_highest : 5161 }24 24 22 38
[ 1.478171][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }24
[ 1.483911][ T1] [cbm] { assign_port_from_DT : 654 }0x8 24
[ 1.489718][ T1] [cbm] { reserved_ports_highest : 5161 }25 25 23 39
[ 1.496313][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }25
[ 1.502051][ T1] [cbm] { assign_port_from_DT : 654 }0x8 25
[ 1.507861][ T1] [cbm] { reserved_ports_highest : 5161 }26 26 24 40
[ 1.514454][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }26
[ 1.520194][ T1] [cbm] { assign_port_from_DT : 654 }0x8 26
[ 1.526004][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }0
[ 1.531643][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }1
[ 1.537284][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }2
[ 1.542926][ T1] [cbm] { init_cbm_eqm_cpu_port : 1297 }3
[ 1.548569][ T1] [cbm] { dma_port_enable : 4670 }5 0x1
[ 1.554046][ T1] [cbm] { dma_port_enable : 4670 }5 0x2
[ 1.559507][ T1] [cbm] { dma_port_enable : 4670 }6 0x1
[ 1.564977][ T1] [cbm] { dma_port_enable : 4670 }6 0x2
[ 1.570443][ T1] [cbm] { dma_port_enable : 4670 }7 0x1
[ 1.575914][ T1] [cbm] { dma_port_enable : 4670 }7 0x2
[ 1.581387][ T1] [cbm] { dma_port_enable : 4670 }8 0x1
[ 1.586851][ T1] [cbm] { dma_port_enable : 4670 }8 0x2
[ 1.592318][ T1] [cbm] { dma_toe_port_enable : 4697 }9 0x1
[ 1.598136][ T1] [cbm] { dma_vrx318_port_enable : 4709 }15 0x1
[ 1.604307][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }0
[ 1.609939][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }1
[ 1.615579][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }2
[ 1.621223][ T1] [cbm] { init_cbm_dqm_cpu_port : 1437 }3
[ 1.626866][ T1] Load spreader init successfully
[ 1.631968][ T1] [cbm] { cbm_xrx500_probe : 5801 }CBM Clock: 0Hz
[ 1.638150][ T1] [cbm] { cbm_xrx500_probe : 5803 }EQM delay Enabled
[ 1.644749][ T1] [cbm] { igp_delay_set : 4782 }port0 delay16
[ 1.650736][ T1] [cbm] { igp_delay_set : 4782 }port1 delay16
[ 1.656726][ T1] [cbm] { igp_delay_set : 4782 }port2 delay16
[ 1.662713][ T1] [cbm] { igp_delay_set : 4782 }port3 delay16
[ 1.668704][ T1] [cbm] { igp_delay_set : 4782 }port4 delay16
[ 1.674692][ T1] [cbm] { igp_delay_set : 4782 }port5 delay16
[ 1.680683][ T1] [cbm] { igp_delay_set : 4782 }port6 delay16
[ 1.686671][ T1] [cbm] { igp_delay_set : 4782 }port7 delay16
[ 1.692662][ T1] [cbm] { igp_delay_set : 4782 }port8 delay16
[ 1.698649][ T1] [cbm] { igp_delay_set : 4782 }port9 delay16
[ 1.704641][ T1] [cbm] { igp_delay_set : 4782 }port10 delay16
[ 1.710715][ T1] [cbm] { igp_delay_set : 4782 }port11 delay16
[ 1.716793][ T1] [cbm] { igp_delay_set : 4782 }port12 delay16
[ 1.722867][ T1] [cbm] { igp_delay_set : 4782 }port13 delay16
[ 1.728945][ T1] [cbm] { igp_delay_set : 4782 }port14 delay16
[ 1.735020][ T1] [cbm] { igp_delay_set : 4782 }port15 delay16
[ 1.741101][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x2 2 0 30
[ 1.747713][ T1] [cbm] { enqueue_dma_port_init : 4581 }5 0x1 2 14 0
[ 1.754297][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x2 2 0 31
[ 1.760893][ T1] [cbm] { enqueue_dma_port_init : 4581 }6 0x1 2 15 0
[ 1.767491][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x2 1 0 6
[ 1.774001][ T1] [cbm] { enqueue_dma_port_init : 4581 }7 0x1 1 0 0
[ 1.780511][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x2 1 0 11
[ 1.787107][ T1] [cbm] { enqueue_dma_port_init : 4581 }8 0x1 1 5 0
[ 1.793656][ T1] [cbm] { cbm_xrx500_probe : 5850 }CBM: Init Done !!
[ 1.794611][ T1] pstore: using zlib compression
[ 1.805918][ T1] pstore: Registered ramoops as persistent store backend
[ 1.812791][ T1] ramoops: attached 0x400000@0x20100000, ecc: 0/0
[ 1.856668][ T1] SCSI subsystem initialized
[ 1.861537][ T1] usbcore: registered new interface driver usbfs
[ 1.867843][ T1] usbcore: registered new interface driver hub
[ 1.873818][ T1] usbcore: registered new device driver usb
[ 1.880250][ T1] mp8864 0-0068: MP8864 probe started.
[ 1.890526][ T1] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xe5
[ 1.898828][ T1] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL)
[ 1.905448][ T1] try to register spd_mon driver
[ 1.905685][ T1] spdmon 16080110.speedm: base address: 0xb6080110
[ 1.916853][ T1] spdmon 16080110.speedm: PHY base address: 0x16080110
[ 1.923908][ T1] spdmon 16080110.speedm: spd_mon driver : init done !!
[ 1.935174][ T1] spd_mon driver registered
[ 1.940678][ T1] AVM PA for Linux version 4.9.325 ([email protected]) (gcc version 8.4.0 (Buildroot 2020.02.1-g3ef93f8b) ) #1 SMP 2024-12-05
[ 1.940678][ T1] (early init)
[ 1.958104][ T1] NET: Registered protocol family 8
[ 1.963072][ T1] NET: Registered protocol family 20
[ 1.968759][ T1] clocksource: Switched to clocksource gptc
[ 1.999302][ T1] AppArmor: AppArmor Filesystem Enabled
[ 2.007784][ T1] NET: Registered protocol family 2
[ 2.012969][ T1] IP idents hash table entries: 8192 (order: 4, 65536 bytes)
[ 2.041205][ T1] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 2.048898][ T1] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 2.056091][ T1] TCP: Hash tables configured (established 4096 bind 4096)
[ 2.063241][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 2.069755][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 2.077101][ T1] NET: Registered protocol family 1
[ 2.083795][ T1] yield_probe: cpu 0 irq 275
[ 2.088327][ T1] yield_probe: cpu 1 irq 276
[ 2.093100][ T1] yield_probe: cpu 2 irq 277
[ 2.097480][ T1] yield_probe: cpu 3 irq 278
[ 2.102197][ T1] yield_probe: interrupts set up
[ 2.109129][ T1] audit: initializing netlink subsys (enabled)
[ 2.115150][ T1] audit: type=2000 audit(1.448:1): initialized
[ 2.121392][ T1] No memory allocated for crashlog
[ 2.126767][ T1] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 2.158652][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.165068][ T1] ANTFS Module: Version 2.54
[ 2.169794][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 2.182553][ T1] fuse init (API version 7.26)
[ 2.196601][ T1] io scheduler noop registered
[ 2.201098][ T1] io scheduler deadline registered (default)
[ 2.207432][ T1] bthelper_probe: core 0 initialized
[ 2.212415][ T1] bthelper_probe: core 1 initialized
[ 2.219698][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success!
[ 2.228245][ T1] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success!
[ 2.236637][ T1] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success!
[ 2.245135][ T1] 1a400000.phy supply vbus not found, using dummy regulator
[ 2.252497][ T1] 1a600000.phy supply vbus not found, using dummy regulator
[ 2.368775][ T1] OF: PCI: host bridge /pcie@18900000 ranges:
[ 2.374601][ T1] OF: PCI: MEM 0xb8000000..0xbaffffff -> 0xb8000000
[ 2.381242][ T1] OF: PCI: IO 0xbb800000..0xbb80ffff -> 0xbb800000
[ 2.390274][ T1] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled
[ 2.531762][ T1] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00
[ 2.538694][ T1] pci_bus 0000:00: root bus resource [bus 00-08]
[ 2.544907][ T1] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff]
[ 2.552542][ T1] pci_bus 0000:00: root bus resource [io 0xbb800000-0xbb80ffff]
[ 2.560621][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.569750][ T1] pci 0000:00:00.0: PCI bridge to [bus 01-08]
[ 2.575781][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff]
[ 2.583125][ T1] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref]
[ 2.591101][ T1] pci 0000:00:00.0: BAR 7: assigned [io 0xbb800000-0xbb800fff]
[ 2.598654][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit]
[ 2.606733][ T1] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.612447][ T1] pci 0000:00:00.0: bridge window [io 0xbb800000-0xbb800fff]
[ 2.619999][ T1] pci 0000:00:00.0: bridge window [mem 0xb8000000-0xb81fffff]
[ 2.627550][ T1] pci 0000:00:00.0: bridge window [mem 0xb8200000-0xb82fffff pref]
[ 2.635716][ T1] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
[ 2.642612][ T1] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done
[ 2.756776][ T1] OF: PCI: host bridge /pcie@18400000 ranges:
[ 2.762572][ T1] OF: PCI: MEM 0xb4000000..0xb6ffffff -> 0xb4000000
[ 2.769230][ T1] OF: PCI: IO 0xb7800000..0xb780ffff -> 0xb7800000
[ 2.777037][ T1] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2!
[ 2.919731][ T1] intel-pcie 18400000.pcie: PCI host bridge to bus 0001:00
[ 2.926674][ T1] pci_bus 0001:00: root bus resource [bus 00-08]
[ 2.932881][ T1] pci_bus 0001:00: root bus resource [mem 0xb4000000-0xb6ffffff]
[ 2.940515][ T1] pci_bus 0001:00: root bus resource [io 0xb7800000-0xb780ffff]
[ 2.948597][ T1] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.957782][ T1] pci 0001:00:00.0: PCI bridge to [bus 01-08]
[ 2.963870][ T1] pci 0001:00:00.0: BAR 8: assigned [mem 0xb4000000-0xb41fffff]
[ 2.971212][ T1] pci 0001:00:00.0: BAR 9: assigned [mem 0xb4200000-0xb42fffff pref]
[ 2.979186][ T1] pci 0001:00:00.0: BAR 7: assigned [io 0xb7800000-0xb7800fff]
[ 2.986739][ T1] pci 0001:01:00.0: BAR 0: assigned [mem 0xb4000000-0xb41fffff 64bit]
[ 2.994819][ T1] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.000534][ T1] pci 0001:00:00.0: bridge window [io 0xb7800000-0xb7800fff]
[ 3.008086][ T1] pci 0001:00:00.0: bridge window [mem 0xb4000000-0xb41fffff]
[ 3.015636][ T1] pci 0001:00:00.0: bridge window [mem 0xb4200000-0xb42fffff pref]
[ 3.023778][ T1] pcieport 0001:00:00.0: enabling device (0000 -> 0003)
[ 3.030711][ T1] intel-pcie 18400000.pcie: Intel AXI PCIe Root Complex Port 1 Init Done
[ 3.144770][ T1] OF: PCI: host bridge /pcie@18e00000 ranges:
[ 3.150570][ T1] OF: PCI: MEM 0xbc000000..0xbeffffff -> 0xbc000000
[ 3.157229][ T1] OF: PCI: IO 0xbf800000..0xbf80ffff -> 0xbf800000
[ 3.165037][ T1] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 3!
[ 3.295095][ T1] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00
[ 3.302030][ T1] pci_bus 0002:00: root bus resource [bus 00-08]
[ 3.308240][ T1] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff]
[ 3.315877][ T1] pci_bus 0002:00: root bus resource [io 0xbf800000-0xbf80ffff]
[ 3.323965][ T1] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.333187][ T1] pci 0002:00:00.0: PCI bridge to [bus 01-08]
[ 3.339322][ T1] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff]
[ 3.346670][ T1] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref]
[ 3.354642][ T1] pci 0002:00:00.0: BAR 7: assigned [io 0xbf800000-0xbf800fff]
[ 3.362196][ T1] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff]
[ 3.369746][ T1] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 3.375468][ T1] pci 0002:00:00.0: bridge window [io 0xbf800000-0xbf800fff]
[ 3.383021][ T1] pci 0002:00:00.0: bridge window [mem 0xbc000000-0xbc7fffff]
[ 3.390572][ T1] pci 0002:00:00.0: bridge window [mem 0xbc800000-0xbc8fffff pref]
[ 3.398713][ T1] pcieport 0002:00:00.0: enabling device (0000 -> 0003)
[ 3.405657][ T1] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done
[ 3.415396][ T1] [mips_tc_init] dma_zalloc_coherent dev->name=(null) sizeof(struct mips_tc_sg_mem)=1680 shared_phy_mem=2380b000
[ 3.427017][ T1] [mips_tc_init] dma_zalloc_coherent shared_vir_uncached_mem=a380b000 shared_vir_cached_mem=8380b000 shared_working_vir_mem=8380b000
[ 3.440797][ T1] =MIPS TC Shared memory: a380b000 8380b000 8380b000 | Data: a3810000
[ 3.448759][ T1] UMT initialize success on processor: 0 !
[ 3.454373][ T1] HW MCPY driver: Version: 1.1.0, Init Done!
[ 3.461479][ T1] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc
[ 3.471189][ T1] console [ttyLTQ0] enabled
[ 3.479791][ T1] bootconsole [early0] disabled
[ 3.489790][ T1] 16700000.serial: ttyLTQ1 at MMIO 0x16700000 (irq = 213, base_baud = 0) is a lantiq,asc
[ 3.499607][ T29] random: crng init done
[ 3.502409][ T1] avm_net_trace: Up and running.
[ 3.507621][ T1] [avm_power]avm_power_pm_qos_init
[ 3.512504][ T1] [loadcontrol] set auto - scale=1
[ 3.516970][ T1] [avm] configured: watchdog event debug
[ 3.516975][ T1]
[ 3.525215][ T1] Register push button event to receive the set_factory_kernel event
[ 3.533393][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0)
[ 3.541124][ T1] [grx:watchdog] start on cpu0
[ 3.544557][ C1] [grx:watchdog] start on cpu1
[ 3.549139][ C2] [grx:watchdog] start on cpu2
[ 3.553744][ C3] [grx:watchdog] start on cpu3
[ 3.560184][ T1] brd: module loaded
[ 3.563740][ T1] zram: Added device: zram0
[ 3.568699][ T1] nand: device found, Manufacturer ID: 0x98, Chip ID: 0xdc
[ 3.574375][ T1] nand: Toshiba NAND 512MiB 3,3V 8-bit
[ 3.579665][ T1] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 128
[ 3.588013][ T1] try_avm_ecc_fixup: AVM ecc fixup is not yet implemented - skipping check
[ 3.596433][ T1] Scanning device for bad blocks
[ 3.980983][ T1] Bad eraseblock 1536 at 0x000018000000
[ 3.985060][ T1] Bad eraseblock 1537 at 0x000018040000
[ 4.115961][ T1] 5 fixed-partitions partitions found on MTD device 17c00000.nand-parts
[ 4.122676][ T1] Creating 5 MTD partitions on "17c00000.nand-parts":
[ 4.129286][ T1] 0x000000500000-0x000000d00000 : "kernel"
[ 4.136984][ T1] 0x000000000000-0x000000100000 : "urlader"
[ 4.143088][ T1] 0x000000100000-0x000000500000 : "nand-tffs"
[ 4.149506][ T1] [TFFS3_Init] Called.
[ 4.151964][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand
[ 4.159301][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x
[ 4.164999][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2
[ 4.310364][ T1] [TFFS3-NAND] Initialisation successful, 16/16/16 NAND blocks active, fill rate 6%
[ 4.318151][ T1] [TFFS_Cache] Allocate segement buffer cache (size=4072)
[ 4.327500][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[ 4.334434][ T1] Adam2 environment variables API installed.
[ 4.341123][ T1] 0x000000d00000-0x000001500000 : "reserved-kernel"
[ 4.348297][ T1] 0x000001500000-0x000020000000 : "ubi"
[ 4.369122][ T1] lro_sram_membase_res0 from DT: a2013000
[ 4.373621][ T1] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000
[ 4.381505][ T1] TOE Init Done !!
[ 5.033369][ T1] i2c /dev entries driver
[ 5.038144][ T1] ltq_thermal 16000000.ssx4:ts@080000: ltq_thermal_probe: is done
[ 5.049157][ T1] AVM PA 2.161.1.1-release_smart24p1-smart24p1 for Linux Linux version 4.9.325 ([email protected]) (gcc version 8.4.0 (Buildroot 2020.02.1-g3ef93f8b) ) #1 SMP 2024-12-05
[ 5.049157][ T1] (late init)
[ 5.068629][ T1] Mirror/redirect action on
[ 5.072522][ T1] u32 classifier
[ 5.075858][ T1] Performance counters on
[ 5.080368][ T1] input device check on
[ 5.084723][ T1] Actions configured
[ 5.089005][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 5.095889][ T1] Initializing XFRM netlink socket
[ 5.099980][ T1] IPsec XFRM device driver
[ 5.105933][ T1] NET: Registered protocol family 10
[ 5.112183][ T1] NET: Registered protocol family 17
[ 5.116019][ T1] NET: Registered protocol family 15
[ 5.121364][ T1] Bridge flood ratelimiter registered
[ 5.126276][ T1] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.139865][ T1] lec:lane_module_init: lec.c: initialized
[ 5.145485][ T1] mpoa:atm_mpoa_init: mpc.c: initialized
[ 5.150991][ T1] KOAM is loaded successfully.
[ 5.155582][ T1] l2tp_core: L2TP core driver, V2.0
[ 5.160581][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 5.167111][ T1] l2tp_netlink: L2TP netlink interface
[ 5.172223][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 5.178742][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 5.186126][ T1] 8021q: 802.1Q VLAN Support v1.8
[ 5.192669][ T1] audit: type=1400 audit(4.524:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0"
[ 5.203607][ T1] AppArmor: AppArmor sha1 policy hashing enabled
[ 5.214026][ T1] ubi0: attaching mtd4
[ 5.591977][ T1] ubi0: scanning is finished
[ 5.628051][ T1] ubi0: attached mtd4 (name "ubi", size 491 MiB)
[ 5.632825][ T1] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 5.640340][ T1] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024
[ 5.647805][ T1] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096
[ 5.655445][ T1] ubi0: good PEBs: 1962, bad PEBs: 2, corrupted PEBs: 0
[ 5.662215][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 5.670118][ T1] ubi0: max/mean erase counter: 22/16, WL threshold: 4096, image sequence number: 1667008040
[ 5.680109][ T1] ubi0: available PEBs: 0, total reserved PEBs: 1962, PEBs reserved for bad PEB handling: 38
[ 5.690112][ T704] ubi0: background thread "ubi_bgt0d" started, PID 704
[ 5.698373][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.703982][ T1] [announce_root] filesystem (/dev/mtdblock5) will be used as root device
[ 5.714054][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.721438][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.745476][ T1] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 5.756342][ T1] devtmpfs: mounted
[ 5.758765][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.765526][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.772453][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.779400][ T1] Could not find Env 'linux_fs_start' in the device tree
[ 5.792288][ T1] Freeing unused kernel: 1680k freed
[ 5.796086][ T1] This architecture does not have kernel memory protection.
[ 7.221066][ T738] eip123_hw: loading out-of-tree module taints kernel.
[ 7.226399][ T738] eip123_hw: module license 'Proprietary' taints kernel.
[ 7.233199][ T738] Disabling lock debugging due to kernel taint
[ 7.239765][ T738] [module-mem] give 0x5000 bytes at 9c59f000 to module 'eip123_hw' (0xb32000 bytes left)
[ 7.277055][ T738] [module-mem] give 0x2000 bytes at 9c5a4000 to module 'eip123' (0xb30000 bytes left)
[ 7.285255][ T738] eip123: no symbol version for eip123_hw_asset_derive
[ 7.292783][ T738] eip123 1e000000.eip123: Detected hardware version 2.2.2
[ 7.298689][ T738] eip123 1e000000.eip123: my_id=3 master_id=0 num_mailboxes=4 mailbox_size=256
[ 7.307442][ T738] eip123 1e000000.eip123: Linked mailbox number 1
[ 7.340793][ T738] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=3 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0
[ 7.380780][ T738] eip123 1e000000.eip123: Device responded with error_src=0x2 error=0x2 opcode=0x11
[ 7.688856][ T738] eip123 1e000000.eip123: eip123_hw init successful
[ 7.748855][ T738] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c
[ 7.756711][ T738] eip123 1e000000.eip123: Could not find rootkey in OTP
[ 7.824574][ T746] TFFS Name Table O
[ 9.801720][ T0] [0]system-load 52% loadavg 0.16 0.3 0.1 - pgstat: sum=113102 free=100380 slab=2436 alloc=1137/s fault=312/s ai_sys:0.40/s 0x9c5a06bc endian_convert_array+0x30/0x3c [eip12 (sleep 1)
[ 11.394592][ T812] [module-mem] module 'hui' reserved size 180224 is to great for demand size 172032 - waste 8192 (module_alloc_waste=8192)
[ 11.405879][ T812] [module-mem] give 0x2a000 bytes at 9c5a6000 to module 'hui' (0xb06000 bytes left)
[ 11.421838][ T812] [hui] Initialize hardware user interface
[ 11.430460][ T812] [avm_connect][state_machine_init] starting event worker thread
[ 11.660008][ T853] [avm_debug] redirecting kernel-messages
[ 60.788948][ T1891] Kernel panic - not syncing:
[ 60.788948][ T1891] No answer on upper layer Control channel! PCMLINK probably dead!
[ 60.801133][ T34] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 60.809330][ C1] stop_cpu_hook cpu1 - stopped status=1100fc00
[ 60.809372][ C2] stop_cpu_hook cpu2 - stopped status=1100fc00
[ 60.809395][ C3] stop_cpu_hook cpu3 - stopped status=1100fc00
[ 60.809532][ T1891] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(1)UP(60)UTC(60)FW(08.02)HW(226)HWS(4)BV(1.3258)BN(117975)FS(08.02)BT(1)BD(0)
[ 60.840621][ T1891] Kernel relocated by 0x198a0000
[ 60.845104][ T1891] .text @ 0x99da0000
[ 60.848922][ T1891] .data @ 0x9a663dfc
[ 60.852742][ T1891] .bss @ 0x9abb0000
[ 61.000250][ T1891] Rebooting in 1 seconds..
Anything unusual?
Thanks in advance.
In a bootloop, the reason(s) for the constant reboots is usually listed near the end.
I see alot things which probably should not be there.
While I suspect the former owner did some tinkering with it already ("linux_fs_start" should be there, either "0" or "1"), the message in bold seems to report a hardware defect.
linux_fs_start is not set while using the recovery program (which writes a new TFFS image) - it gets set again at the first update afterwards.
Press ENTER on the serial console next time, to continue logging after avm_debug redirected the console output - your log has a large hole between second 11 and second 60. Then you will see further messages regarding the (obvious) problem with the PCMLINK driver - it seems, that the Xilinx FPGA has a malfunction (it's used for telephony functions in FRITZ!OS).
Do you suspect it changed the booloader? Because, I use recovery exe from avm to restore the firmware 8.02.
A thing I notice were errors in the nand
Bad blocks are normal with NAND flash - they will be skipped automatically.
This is the missing part:
[ 11.800129][ T852] [avm_debug] redirecting kernel-messages
Jan 1 1970 00:00:12 ar7cfgctl[970]: [ERROR] load_config(ar7): file empty - factory default loaded
starting pid 973, tty '/dev/ttyLTQ0': '-/bin/sh'
BusyBox v1.36.1 () built-in shell (ash)
Jan 1 1970 01:00:12 ar7cfgctl[980]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 00:00:12 ar7cfgctl[1033]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 00:00:12 ar7cfgctl[1037]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 01:00:12 ar7cfgctl[1046]: [ERROR] load_config(ar7): file empty - factory default loaded
P-Defaults: and action...
P-Defaults: ...done.
[Supervisor] Info: tffs.service exit success
[Supervisor] Info: start rekey.service
Jan 1 1970 00:00:15 firmwarecfg[1118]: [ERROR] Warning: clogger_freeonly: default logger 'firmwareupdate' gone
firmwarecfg config_rekey: nop
[Supervisor] Info: rekey.service exit success
[Supervisor] Info: start environment.service
Jan 1 1970 00:00:15 ar7cfgctl[1122]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 00:00:15 ar7cfgctl[1169]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 00:00:15 ar7cfgctl[1173]: [ERROR] load_config(ar7): file empty - factory default loaded
Jan 1 1970 01:00:15 ar7cfgctl[1182]: [ERROR] load_config(ar7): file empty - factory default loaded
[Supervisor] Info: environment.service exit success
[Supervisor] Info: start watchdog.service
[ 16.708004][ T1187] AVM_WATCHDOG: System Init Ueberwachung 120 Sekunden
[Supervisor] Info: watchdog.service exit success
[Supervisor] Info: start udev.service
[Supervisor] Info: start udevadm.service
[ 17.117463][ T1188] udevd[1188]: starting version 3.2.11
[ 17.184820][ T1188] udevd[1188]: specified group 'tty' unknown
[ 17.185435][ T1188] udevd[1188]: specified group 'dialout' unknown
[ 17.185725][ T1188] udevd[1188]: specified group 'kmem' unknown
[ 17.185991][ T1188] udevd[1188]: specified group 'input' unknown
[ 17.186272][ T1188] udevd[1188]: specified group 'video' unknown
[ 17.186662][ T1188] udevd[1188]: specified group 'audio' unknown
[ 17.187119][ T1188] udevd[1188]: specified group 'lp' unknown
[ 17.187477][ T1188] udevd[1188]: specified group 'disk' unknown
[ 17.187738][ T1188] udevd[1188]: specified group 'cdrom' unknown
[ 17.196177][ T1188] udevd[1188]: starting eudev-3.2.11
[ 17.513884][ T1333] [module-mem] module 'vrx518' reserved size 28672 is to great for demand size 24576 - waste 4096 (module_alloc_waste=12288)
[ 17.513919][ T1333] [module-mem] give 0x6000 bytes at 9717a000 to module 'vrx518' (0xb00000 bytes left)
[ 17.516125][ T1333] vrx518: Intel(R) SmartPHY DSL(VRX518) PCIe EP/ACA Driver - version 2.1.0-k
[ 17.516147][ T1333] vrx518: Copyright (c) 2016 Intel Corporation.
[ 17.516379][ T1333] vrx518 0002:01:00.0: no of_node; not parsing pinctrl DT
[ 17.516503][ T1333] vrx518 0002:01:00.0: enabling device (0000 -> 0002)
[ 17.564633][ T1334] [module-mem] module 'xrx500_phy_fw' reserved size 12288 is to great for demand size 8192 - waste 4096 (module_alloc_waste=16384)
[ 17.564668][ T1334] [module-mem] give 0x2000 bytes at 97180000 to module 'xrx500_phy_fw' (0xafe000 bytes left)
[ 17.567079][ T1326] [module-mem] module 'cpunet' reserved size 16384 is to great for demand size 12288 - waste 4096 (module_alloc_waste=20480)
[ 17.567118][ T1326] [module-mem] give 0x3000 bytes at 97182000 to module 'cpunet' (0xafb000 bytes left)
[ 17.567306][ T1334] phy-xrx500 1c003c00.phy-xrx500: requesting ltq_fw_PHY11G_IP_xRx5xx_A21.bin
[ 17.570441][ T1320] [module-mem] Module 'xrx500_phy_fw' already allocated
[ 17.570525][ T1326] cpunet 1f107400.cpunet: slots=16 mtu=8192 mailbox_size=0x4c mempool_size=0x20000
[ 17.570738][ T1326] cpunet 1f107400.cpunet: Initialized mailbox: rx=0xbf201000 tx=0xbf201100
[ 17.570945][ T1326] cpunet 1f107400.cpunet: Initialized mempool: rx=0x8dfc0000 tx=0x8dfe0000 min_align=64
[ 17.571134][ T1326] cpunet 1f107400.cpunet: hw init successful
[ 17.601409][ T1322] [module-mem] module 'eip97' reserved size 65536 is to great for demand size 61440 - waste 4096 (module_alloc_waste=24576)
[ 17.601436][ T1322] [module-mem] give 0xf000 bytes at 97185000 to module 'eip97' (0xaec000 bytes left)
[ 17.650547][ T1334] phy-xrx500 1c003c00.phy-xrx500: booting GPHY0 firmware for GRX500
[ 17.650846][ T1334] phy-xrx500 1c003c00.phy-xrx500: booting GPHY1 firmware for GRX500
[ 17.651130][ T1334] phy-xrx500 1c003c00.phy-xrx500: booting GPHY2 firmware for GRX500
[ 17.651211][ T1334] phy-xrx500 1c003c00.phy-xrx500: booting GPHY3 firmware for GRX500
[ 17.651481][ T1334] phy-xrx500 1c003c00.phy-xrx500: booting GPHY4 firmware for GRX500
[ 17.781430][ T1334] [module-mem] module 'ltq_eth_drv_xrx500' reserved size 40960 is to great for demand size 36864 - waste 4096 (module_alloc_waste=28672)
[ 17.781456][ T1334] [module-mem] give 0x9000 bytes at 97194000 to module 'ltq_eth_drv_xrx500' (0xae3000 bytes left)
[ 17.783314][ T1334] PMAC_EG_CFG_SET for GSW-L
[ 17.783491][ T1334] PMAC_IG_CFG_SET for GSW-L
[ 17.783545][ T1334] PMAC_EG_CFG_SET for GSW-R
[ 17.786666][ T1334] PMAC_IG_CFG_SET for GSW-R
[ 17.786905][ T1334]
GSW PMAC Init Done!!!
[ 17.786978][ T1334] Property intel,extra-subif not exist for if eth3 0
[ 17.787407][ T1334] dp_sub_proc_install ok
[ 17.787915][ T1334] datapath_coc: enter dp_coc_cpufreq_init
[ 17.788694][ T1334] datapath_coc: Register DP to CPUFREQ successfully.
[ 17.788712][ T1334] [cbm] { dp_port_alloc : 3243 }flags 0x2
[ 17.788736][ T1334] [cbm] { cbm_add_to_list : 450 }2
[ 17.788755][ T1334] [cbm] { dp_port_alloc : 3392 }disabling q 17 port 7
[ 17.788770][ T1334] [cbm] { dp_port_alloc : 3398 }first time LOOKUP prgrm
[ 17.789088][ T1334] [cbm] { dp_port_alloc : 3403 }1024
[ 17.789311][ T1334] xrx500_of_iface: rx csum offload is enabled !
[ 17.789345][ T1334] trying to connect: eth3 to device: 0:02 with irq: 295
[ 17.911040][ T1334] eth3: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:02, irq=295)
[ 17.918188][ T1334] [cbm] { dp_enable : 3739 }ep=2 tmu_port=7 queue=17 sid=1
[ 17.918203][ T1334] [cbm] { dequeue_dma_port_init : 4636 }7 0x0 2 2
[ 17.918230][ T1334] [cbm] { dequeue_dma_port_init : 4636 }13 0x0 2 10
[ 17.918268][ T1334] [cbm] { dp_enable : 3805 }enable queue 17
[ 17.918276][ T1334] [cbm] { dp_enable : 3806 }flag 1 refcnt 1024
[ 17.920151][ T1334] Property intel,extra-subif not exist for if eth2 0
[ 17.920372][ T1334] [cbm] { dp_port_alloc : 3243 }flags 0x2
[ 17.920417][ T1334] [cbm] { cbm_add_to_list : 450 }2
[ 17.920438][ T1334] [cbm] { dp_port_alloc : 3392 }disabling q 18 port 8
[ 17.920457][ T1334] [cbm] { dp_port_alloc : 3398 }first time LOOKUP prgrm
[ 17.920876][ T1334] [cbm] { dp_port_alloc : 3403 }1024
[ 17.921122][ T1334] xrx500_of_iface: rx csum offload is enabled !
[ 17.921162][ T1334] trying to connect: eth2 to device: 0:03 with irq: 296
[ 18.043069][ T1334] eth2: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:03, irq=296)
[ 18.050217][ T1334] [cbm] { dp_enable : 3739 }ep=3 tmu_port=8 queue=18 sid=2
[ 18.050232][ T1334] [cbm] { dequeue_dma_port_init : 4636 }8 0x0 2 3
[ 18.050259][ T1334] [cbm] { dequeue_dma_port_init : 4636 }14 0x0 2 11
[ 18.050298][ T1334] [cbm] { dp_enable : 3805 }enable queue 18
[ 18.050306][ T1334] [cbm] { dp_enable : 3806 }flag 1 refcnt 1024
[ 18.051915][ T1334] Property intel,extra-subif not exist for if eth1 0
[ 18.051995][ T1334] [cbm] { dp_port_alloc : 3243 }flags 0x2
[ 18.052016][ T1334] [cbm] { cbm_add_to_list : 450 }2
[ 18.052033][ T1334] [cbm] { dp_port_alloc : 3392 }disabling q 19 port 9
[ 18.052049][ T1334] [cbm] { dp_port_alloc : 3398 }first time LOOKUP prgrm
[ 18.052682][ T1334] [cbm] { dp_port_alloc : 3403 }1024
[ 18.053002][ T1334] xrx500_of_iface: rx csum offload is enabled !
[ 18.053053][ T1334] trying to connect: eth1 to device: 0:04 with irq: 297
[ 18.175039][ T1334] eth1: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:04, irq=297)
[ 18.182191][ T1334] [cbm] { dp_enable : 3739 }ep=4 tmu_port=9 queue=19 sid=3
[ 18.182206][ T1334] [cbm] { dequeue_dma_port_init : 4636 }9 0x0 2 4
[ 18.182233][ T1334] [cbm] { dequeue_dma_port_init : 4636 }15 0x0 2 12
[ 18.182271][ T1334] [cbm] { dp_enable : 3805 }enable queue 19
[ 18.182279][ T1334] [cbm] { dp_enable : 3806 }flag 1 refcnt 1024
[ 18.184202][ T1334] Property intel,extra-subif not exist for if eth0 0
[ 18.184410][ T1334] [cbm] { dp_port_alloc : 3243 }flags 0x2
[ 18.184434][ T1334] [cbm] { cbm_add_to_list : 450 }2
[ 18.184454][ T1334] [cbm] { dp_port_alloc : 3392 }disabling q 20 port 10
[ 18.184473][ T1334] [cbm] { dp_port_alloc : 3398 }first time LOOKUP prgrm
[ 18.184890][ T1334] [cbm] { dp_port_alloc : 3403 }1024
[ 18.185135][ T1334] xrx500_of_iface: rx csum offload is enabled !
[ 18.185175][ T1334] trying to connect: eth0 to device: 0:05 with irq: 298
[ 18.307039][ T1334] eth0: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:05, irq=298)
[ 18.314191][ T1334] [cbm] { dp_enable : 3739 }ep=5 tmu_port=10 queue=20 sid=4
[ 18.314206][ T1334] [cbm] { dequeue_dma_port_init : 4636 }10 0x0 2 5
[ 18.314234][ T1334] [cbm] { dequeue_dma_port_init : 4636 }16 0x0 2 13
[ 18.314271][ T1334] [cbm] { dp_enable : 3805 }enable queue 20
[ 18.314280][ T1334] [cbm] { dp_enable : 3806 }flag 1 refcnt 1024
[ 18.316183][ T1334] Property intel,extra-subif not exist for if wan 0
[ 18.316411][ T1334] [cbm] { dp_port_alloc : 3243 }flags 0x4
[ 18.316435][ T1334] [cbm] { cbm_add_to_list : 450 }1
[ 18.316455][ T1334] [cbm] { dp_port_alloc : 3392 }disabling q 28 port 19
[ 18.316473][ T1334] [cbm] { dp_port_alloc : 3398 }first time LOOKUP prgrm
[ 18.316892][ T1334] [cbm] { dp_port_alloc : 3403 }1024
[ 18.317155][ T1334] xrx500_of_iface: rx csum offload is enabled !
[ 18.317197][ T1334] trying to connect: wan to device: 1:01 with irq: 299
[ 19.036620][ T1334] xrx500-eth 1e000000.ssx0:eth@a00000 wan (uninitialized): Unable to connect phydev
[ 19.036664][ T1334] connect phy of port 1 failed
[ 19.036749][ T1334] [cbm] { dp_enable : 3739 }ep=15 tmu_port=19 queue=28 sid=12
[ 19.036783][ T1334] [cbm] { dequeue_dma_port_init : 4636 }19 0x0 1 15
[ 19.036892][ T1334] [cbm] { dp_enable : 3805 }enable queue 28
[ 19.036916][ T1334] [cbm] { dp_enable : 3806 }flag 1 refcnt 1024
[ 19.041911][ T1334] Lantiq ethernet driver for XRX500 init.
[Supervisor] Info: udevadm.service exit success
[Supervisor] Info: start capi-config.service
[Supervisor] Info: start modules-load.service
[Supervisor] Info: start piglet.service
[ 19.349574][ T1627] [module-mem] module 'Piglet_noemif' reserved size 49152 is to great for demand size 45056 - waste 4096 (module_alloc_waste=32768)
[ 19.349605][ T1627] [module-mem] give 0xb000 bytes at 9719d000 to module 'Piglet_noemif' (0xad8000 bytes left)
[ 19.353056][ T1627] Could not find Env 'kernel_args' in the device tree
[ 19.353107][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_piglet_noemif_data 6
[ 19.353116][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_piglet_noemif_done 7
[ 19.353124][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_piglet_noemif_clk 5
[ 19.353131][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_piglet_noemif_prog 4
[ 19.353144][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_dect_reset 3
[ 19.353150][ T1627] use_hw_config_to_set_gpios: hw_config: gpio_avm_dect_rd 0
[ 19.353158][ T1627] [piglet]use default-settings (6 gpios from hw_config)
[Supervisor] Info: capi-config.service exit success
[ 19.378461][ T555] thermal thermal_zone0: failed to read out thermal zone (-5)
[ 19.384106][ T1630] [module-mem] module 'directconnect_datapath' reserved size 73728 is to great for demand size 69632 - waste 4096 (module_alloc_waste=36864)
[ 19.384138][ T1630] [module-mem] give 0x11000 bytes at 971a8000 to module 'directconnect_datapath' (0xac7000 bytes left)
[ 19.413361][ T1636] [module-mem] module 'dc_mode_hw' reserved size 36864 is to great for demand size 32768 - waste 4096 (module_alloc_waste=40960)
[ 19.413392][ T1636] [module-mem] give 0x8000 bytes at 971b9000 to module 'dc_mode_hw' (0xabf000 bytes left)
[ 19.447695][ T1640] [module-mem] give 0x2000 bytes at 971c1000 to module 'cprocfsmod' (0xabd000 bytes left)
[ 19.448790][ T1640] cprocfs: loaded
[ 19.479664][ T1640] [module-mem] give 0x2000 bytes at 971c3000 to module 'cchardev' (0xabb000 bytes left)
[ 19.480892][ T1640] cchardevice: loaded
[ 19.503703][ T1627] [piglet]patch_dectfw: patch_adress: a0 max_len: 53 with Version 1 Len: 17
[ 19.503741][ T1627] [piglet]patch_dectfw: RFPI tag found 032f843840
[ 19.503755][ T1627] [piglet]get_tag_value: tag 9 not found -> ignore
[ 19.503763][ T1627] [piglet]patch_dectfw: dectmode 10
[ 19.504174][ T1627] [piglet]patch_dectfw: c099b000, totallen = 55302(d806) crc=0x9
[ 19.504329][ T1627] [piglet]slow: dect_loader-bootmode
[ 19.509098][ T1640] [module-mem] give 0x3000 bytes at 971c5000 to module 'kskbtrace' (0xab8000 bytes left)
[ 19.510769][ T1640] cchardevice: device_create(kskbtracepoint): 243,0
[ 19.511498][ T1640] kskbtracepoint: loaded
[ 20.068945][ T0] [0]system-load 32% loadavg 0.36 0.8 0.3 - task runtime:13% max:modprobe 1% pgstat: sum=113102 free=94876 slab=3190 alloc=2430/s fault=2383/s (sleep 1)
[ 20.176743][ T0] [3]system-load 28% loadavg 0.36 0.8 0.3 - task runtime:49% max:modprobe 25% pgstat: sum=113102 free=94861 slab=3191 alloc=3570/s fault=2717/s (sleep 1)
[ 20.305063][ T1627] [1]system-load 37% loadavg 0.36 0.8 0.3 - task runtime:49% max:modprobe 24% pgstat: sum=113102 free=94711 slab=3193 alloc=3663/s fault=2771/s (sleep 3)
[ 20.408581][ T0] [2]system-load 32% loadavg 0.36 0.8 0.3 - task runtime:49% max:modprobe 24% pgstat: sum=113102 free=94677 slab=3195 alloc=3365/s fault=2538/s (sleep 3)
[ 20.843385][ T1640] [module-mem] module 'kdsldmod' reserved size 2240512 is to great for demand size 2224128 - waste 16384 (module_alloc_waste=57344)
[ 20.843411][ T1640] [module-mem] give 0x21f000 bytes at 971c8000 to module 'kdsldmod' (0x899000 bytes left)
[ 20.891598][ T1627] *
[ 20.912612][ T1640] kdsld: init start (sizeof(struct sk_buff) = 464)
[ 20.912640][ T1640] kdsld[2]: Initialisation of debughandles ...
[ 20.912711][ T1640] kdsld[2]: Initialisation of debughandles [OK]
[ 20.912717][ T1640] kdsld[2]: Initialisation of cmemstack ...
[ 20.912723][ T1640] kdsld[2]: Initialisation of cmemstack [OK]
[ 20.912728][ T1640] kdsld[2]: Initialisation of global ...
[ 20.913341][ T1640] kdsld[2]: Initialisation of global [OK]
[ 20.913346][ T1640] kdsld[2]: Initialisation of procfs ...
[ 20.913389][ T1640] kdsld[2]: Initialisation of procfs [OK]
[ 20.913394][ T1640] kdsld[2]: Initialisation of ptype ...
[ 20.913416][ T1640] kdsld[2]: Initialisation of ptype [OK]
[ 20.913422][ T1640] kdsld[2]: Initialisation of kmod_debugctl ...
[ 20.913439][ T1640] kdsld[2]: Initialisation of kmod_debugctl [OK]
[ 20.913444][ T1640] kdsld[2]: Initialisation of cenv ...
[ 20.913449][ T1640] kdsld[2]: Initialisation of cenv [OK]
[ 20.913455][ T1640] kdsld[2]: Initialisation of ctimer ...
[ 20.913917][ T1640] kdsld[2]: Initialisation of ctimer [OK]
[ 20.913929][ T1640] kdsld[2]: Initialisation of prefixtab ...
[ 20.913971][ T1640] kdsld[2]: Initialisation of prefixtab [OK]
[ 20.913977][ T1640] kdsld[2]: Initialisation of avmsgc ...
[ 20.914215][ T1640] kdsld[2]: Initialisation of avmsgc [OK]
[ 20.914223][ T1640] kdsld[2]: Initialisation of avmcounter ...
[ 20.914684][ T1640] kdsld[2]: Initialisation of avmcounter [OK]
[ 20.914696][ T1640] kdsld[2]: Initialisation of dsld_setup ...
[ 20.914713][ T1640] kdsld[2]: Initialisation of dsld_setup [OK]
[ 20.914719][ T1640] kdsld[2]: Initialisation of adsl_net ...
[ 20.916634][ T1640] kdsld[2]: Initialisation of adsl_net [OK]
[ 20.916656][ T1640] kdsld[2]: Initialisation of ppptty_net ...
[ 20.918717][ T1640] kdsld[2]: Initialisation of ppptty_net [OK]
[ 20.918740][ T1640] kdsld[2]: Initialisation of ingress_shaping ...
[ 20.920583][ T1640] kdsld[2]: Initialisation of ingress_shaping [OK]
[ 20.920606][ T1640] kdsld[2]: Initialisation of pppdp ...
[ 20.951467][ T1640] kdsld[2]: Initialisation of pppdp [OK]
[ 20.951493][ T1640] kdsld[2]: Initialisation of kmodcmddev ...
[ 20.951560][ T1640] kdsld[2]: Initialisation of kmodcmddev [OK]
[ 20.951568][ T1640] kdsld[2]: Initialisation of kdsldev ...
[ 20.951774][ T1640] cchardevice: device_create(kdsld): 242,0
[ 20.952321][ T1640] kdsld[2]: Initialisation of kdsldev [OK]
[ 20.952339][ T1640] kdsld[2]: Initialisation of kavmcounterddev ...
[ 20.952457][ T1640] cchardevice: device_create(kavmcounterd): 241,0
[ 20.952790][ T1640] kdsld[2]: Initialisation of kavmcounterddev [OK]
[ 20.952808][ T1640] kdsld[2]: Initialisation of kvpnd ...
[ 20.952910][ T1640] cchardevice: device_create(kvpnd): 240,0
[ 20.953210][ T1640] kdsld[2]: Initialisation of kvpnd [OK]
[ 20.953226][ T1640] kdsld[2]: Initialisation of klatd ...
[ 20.953354][ T1640] cchardevice: device_create(klatd%d): 239,0
[ 20.953687][ T1640] cchardevice: device_create(klatd%d): 239,1
[ 20.954266][ T1640] kdsld[2]: Initialisation of klatd [OK]
[ 20.954285][ T1640] kdsld[2]: Initialisation of kdsluserdev ...
[ 20.954312][ T1640] kdsld[2]: Initialisation of kdsluserdev [OK]
[ 20.954321][ T1640] kdsld[2]: Initialisation of kdslmiscdev ...
[ 20.954334][ T1640] kdsld[2]: Initialisation of kdslmiscdev [OK]
[ 20.954341][ T1640] kdsld[2]: Initialisation of packettrace ...
[ 20.954508][ T1640] cchardevice: device_create(kdsldptrace%d): 236,0
[ 20.954902][ T1640] cchardevice: device_create(kdsldptrace%d): 236,1
[ 20.955206][ T1640] cchardevice: device_create(kdsldptrace%d): 236,2
[ 20.955540][ T1640] cchardevice: device_create(kdsldptrace%d): 236,3
[ 20.955845][ T1640] cchardevice: device_create(kdsldptrace%d): 236,4
[ 20.956340][ T1640] cchardevice: device_create(kdsldptrace%d): 236,5
[ 20.956756][ T1640] cchardevice: device_create(kdsldptrace%d): 236,6
[ 20.957067][ T1640] cchardevice: device_create(kdsldptrace%d): 236,7
[ 20.957362][ T1640] cchardevice: device_create(kdsldptrace%d): 236,8
[ 20.957645][ T1640] cchardevice: device_create(kdsldptrace%d): 236,9
[ 20.957958][ T1640] cchardevice: device_create(kdsldptrace%d): 236,10
[ 20.958271][ T1640] cchardevice: device_create(kdsldptrace%d): 236,11
[ 20.958537][ T1640] cchardevice: device_create(kdsldptrace%d): 236,12
[ 20.958891][ T1640] cchardevice: device_create(kdsldptrace%d): 236,13
[ 20.959141][ T1640] cchardevice: device_create(kdsldptrace%d): 236,14
[ 20.959399][ T1640] cchardevice: device_create(kdsldptrace%d): 236,15
[ 20.959658][ T1640] cchardevice: device_create(kdsldptrace%d): 236,16
[ 20.959870][ T1640] cchardevice: device_create(kdsldptrace%d): 236,17
[ 20.960058][ T1640] cchardevice: device_create(kdsldptrace%d): 236,18
[ 20.960505][ T1640] cchardevice: device_create(kdsldptrace%d): 236,19
[ 20.960826][ T1640] cchardevice: device_create(kdsldptrace%d): 236,20
[ 20.961148][ T1640] cchardevice: device_create(kdsldptrace%d): 236,21
[ 20.961449][ T1640] cchardevice: device_create(kdsldptrace%d): 236,22
[ 20.961820][ T1640] cchardevice: device_create(kdsldptrace%d): 236,23
[ 20.962167][ T1640] cchardevice: device_create(kdsldptrace%d): 236,24
[ 20.962563][ T1640] cchardevice: device_create(kdsldptrace%d): 236,25
[ 20.962913][ T1640] cchardevice: device_create(kdsldptrace%d): 236,26
[ 20.963301][ T1640] cchardevice: device_create(kdsldptrace%d): 236,27
[ 20.963610][ T1640] cchardevice: device_create(kdsldptrace%d): 236,28
[ 20.963883][ T1640] cchardevice: device_create(kdsldptrace%d): 236,29
[ 20.964162][ T1640] cchardevice: device_create(kdsldptrace%d): 236,30
[ 20.964663][ T1640] cchardevice: device_create(kdsldptrace%d): 236,31
[ 20.964975][ T1640] cchardevice: device_create(kdsldptrace%d): 236,32
[ 20.965423][ T1640] kdsld[2]: Initialisation of packettrace [OK]
[ 20.965439][ T1640] kdsld[2]: Initialisation of nqos ...
[ 20.966505][ T1640] cchardevice: device_create(knqos): 235,0
[ 20.968992][ T1640] cchardevice: device_create(avmtrackd): 234,0
[ 20.969386][ T1640] CHRDEV "avmtrackdquery" major number 233 goes below the dynamic allocation range
[ 20.969491][ T1640] cchardevice: device_create(avmtrackdquery): 233,0
[ 20.970065][ T1640] kdsld[2]: Initialisation of nqos [OK]
[ 20.970081][ T1640] kdsld[2]: Initialisation of http_filter ...
[ 20.970095][ T1640] CHRDEV "userman_url" major number 232 goes below the dynamic allocation range
[ 20.970238][ T1640] cchardevice: device_create(userman_url): 232,0
[ 20.970646][ T1640] url_dev_register device userman_url registered
[ 20.970667][ T1640] kdsld[2]: Initialisation of http_filter [OK]
[ 20.970677][ T1640] kdsld[2]: Initialisation of atmvcchook ...
[ 20.970688][ T1640] kdsld[2]: Initialisation of atmvcchook [OK]
[ 20.970694][ T1640] kdsld[2]: Initialisation of timer ...
[ 20.970719][ T1640] kdsld[2]: Initialisation of timer [OK]
[ 20.970727][ T1640] kdsld[2]: Initialisation of netdevice_notifier ...
[ 20.970809][ T1640] kdsld[2]: Initialisation of netdevice_notifier [OK]
[ 20.970818][ T1640] kdsld[2]: Initialisation of ttychannel_ldisc ...
[ 20.970828][ T1640] kdsld[2]: ttychannel: ldisc 8 registered
[ 20.970836][ T1640] kdsld[2]: Initialisation of ttychannel_ldisc [OK]
[ 20.970842][ T1640] kdsld[2]: Initialisation of guestflt ...
[ 20.970992][ T1640] kdsld[2]: Initialisation of guestflt [OK]
[ 20.971002][ T1640] kdsld[2]: Initialisation of bridgeflt ...
[ 20.971015][ T1640] CHRDEV "bridgeflt" major number 231 goes below the dynamic allocation range
[ 20.971134][ T1640] cchardevice: device_create(bridgeflt): 231,0
[ 20.971539][ T1640] kdsld[2]: Initialisation of bridgeflt [OK]
[ 20.971554][ T1640] kdsld[2]: Initialisation of krextd ...
[ 20.971564][ T1640] kdsld[2]: Initialisation of krextd:debughandles ...
[ 20.971599][ T1640] kdsld[2]: Initialisation of krextd:debughandles [OK]
[ 20.971607][ T1640] kdsld[2]: Initialisation of krextd:global ...
[ 20.971627][ T1640] kdsld[2]: Initialisation of krextd:global [OK]
[ 20.971635][ T1640] kdsld[2]: Initialisation of krextd:memcache ...
[ 20.973670][ T1640] kdsld[2]: Initialisation of krextd:memcache [OK]
[ 20.973696][ T1640] kdsld[2]: Initialisation of krextd:igmpcompr ...
[ 20.973720][ T1640] kdsld[2]: Initialisation of krextd:igmpcompr [OK]
[ 20.973728][ T1640] kdsld[2]: Initialisation of krextd:krextdev ...
[ 20.973759][ T1640] CHRDEV "krextd" major number 230 goes below the dynamic allocation range
[ 20.973891][ T1640] cchardevice: device_create(krextd): 230,0
[ 20.974303][ T1640] kdsld[2]: Initialisation of krextd:krextdev [OK]
[ 20.974319][ T1640] kdsld[2]: Initialisation of krextd:krextdev_wland ...
[ 20.974361][ T1640] CHRDEV "krextd_wlan" major number 229 goes below the dynamic allocation range
[ 20.975567][ T1640] cchardevice: device_create(krextd_wlan): 229,0
[ 20.975976][ T1640] kdsld[2]: Initialisation of krextd:krextdev_wland [OK]
[ 20.975991][ T1640] kdsld[2]: Initialisation of krextd:netdevice_notifier ...
[ 20.976071][ T1640] kdsld[2]: Initialisation of krextd:netdevice_notifier [OK]
[ 20.976081][ T1640] kdsld[2]: Initialisation of krextd:krextdprocfs ...
[ 20.976340][ T1640] kdsld[2]: Initialisation of krextd:krextdprocfs [OK]
[ 20.976352][ T1640] kdsld[2]: Initialisation of krextd:krextdtimer ...
[ 20.976378][ T1640] kdsld[2]: Initialisation of krextd:krextdtimer [OK]
[ 20.976389][ T1640] kdsld[2]: Initialisation of krextd [OK]
[ 20.976397][ T1640] kdsld[2]: Initialisation of kdsldprocfs ...
[ 20.976463][ T1640] kdsld[2]: Initialisation of kdsldprocfs [OK]
[ 20.976472][ T1640] kdsld[2]: Initialisation of pcp ...
[ 20.977623][ T1640] kdsld[2]: Initialisation of pcp [OK]
[ 20.977642][ T1640] kdsld[2]: Initialisation [OK]
[ 20.980488][ T1627] *
[ 21.021011][ T1777] [module-mem] module 'kspeedtest' reserved size 20480 is to great for demand size 16384 - waste 4096 (module_alloc_waste=61440)
[ 21.021035][ T1777] [module-mem] give 0x4000 bytes at 973e7000 to module 'kspeedtest' (0x895000 bytes left)
[ 21.022336][ T1777] kspeedtest: kspeedtest_init: second timer started
[ 21.022486][ T1777] kspeedtest: Starting default task on discard port 9
[ 21.022589][ T1777] kspeedtest: listening on port 9
[ 21.022594][ T1777] kspeedtest: kspeedtest_init done
[ 21.069373][ T1627] *
[ 21.070400][ T1781] [module-mem] give 0x1000 bytes at 973eb000 to module 'offload_util' (0x894000 bytes left)
[ 21.072388][ T1781] [module-mem] module 'ktestdrive' reserved size 8192 is to great for demand size 4096 - waste 4096 (module_alloc_waste=65536)
[ 21.072413][ T1781] [module-mem] give 0x1000 bytes at 973ec000 to module 'ktestdrive' (0x893000 bytes left)
[ 21.100114][ T1781] [module-mem] module 'offload_dp' reserved size 53248 is to great for demand size 45056 - waste 8192 (module_alloc_waste=73728)
[ 21.100138][ T1781] [module-mem] give 0xb000 bytes at 973ed000 to module 'offload_dp' (0x888000 bytes left)
[ 21.102548][ T1781] [cbm] { dp_port_alloc : 3243 }flags 0x20
[ 21.102578][ T1781] [cbm] { cbm_add_to_list : 450 }1
[ 21.102671][ T1781] [cbm] { dp_enable : 3739 }ep=7 tmu_port=2 queue=35 sid=19
[ 21.102678][ T1781] [cbm] { dp_enable : 3771 }egp_type 0x20
[ 21.103026][ T1781] [cbm] { dequeue_dma_port_init : 4636 }21 0x0 1 6
[ 21.103060][ T1781] [cbm] { dequeue_dma_port_init : 4636 }20 0x0 1 5
[ 21.103114][ T1781] [cbm] { dp_enable : 3805 }enable queue 35
[ 21.103120][ T1781] [cbm] { dp_enable : 3806 }flag 1 refcnt 1488
[ 21.158262][ T1627] *
[ 21.159212][ T1787] [module-mem] module 'offload_pa' reserved size 122880 is to great for demand size 118784 - waste 4096 (module_alloc_waste=77824)
[ 21.159230][ T1787] [module-mem] give 0x1d000 bytes at 973f8000 to module 'offload_pa' (0x86b000 bytes left)
[ 21.188436][ T1791] [module-mem] give 0x3000 bytes at 97415000 to module 'offload_qos' (0x868000 bytes left)
[ 21.234605][ T1793] [module-mem] give 0x3000 bytes at 97418000 to module 'sch_hw' (0x865000 bytes left)
[ 21.247140][ T1627] *
[ 21.259826][ T1794] [module-mem] give 0x3000 bytes at 9741b000 to module 'sch_llq' (0x862000 bytes left)
[Supervisor] Info: modules-load.service exit success
net.ipv4.tcp_min_snd_mss = 536
mkdir: can't create directory '/dev/switch_api': File exists
[Supervisor] Info: start devnodes.service
[Supervisor] Info: start sysctl.service
[Supervisor] Info: devnodes.service exit success
[Supervisor] Info: start grx.service
[ 21.274171][ T1796] [module-mem] give 0x3000 bytes at 9741e000 to module 'sch_tbf' (0x85f000 bytes left)
[ 21.320146][ T1801] [module-mem] module 'net_upstream_drv' reserved size 16384 is to great for demand size 12288 - waste 4096 (module_alloc_waste=81920)
[ 21.320170][ T1801] [module-mem] give 0x3000 bytes at 97421000 to module 'net_upstream_drv' (0x85c000 bytes left)
[ 21.321287][ T1801] CHRDEV "net_us" major number 228 goes below the dynamic allocation range
[ 21.321429][ T1801] cchardevice: device_create(net_us): 228,0
[ 21.321891][ T1801] net_upstream: AVM net_upstream driver: init done
[ 21.336029][ T1627] ***
[ 21.600629][ T1825] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[ 21.602683][ T1627] *
[ 21.607119][ T1826] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[ 21.614202][ T1827] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[ 21.620733][ T1828] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
mknod: /dev/switch_api/0: File exists
mknod: /dev/switch_api/1: File exists
net.ipv4.tcp_min_tso_segs = 100
[Supervisor] Info: grx.service exit success
[Supervisor] Info: start apparmor.service
[Supervisor] Info: start filesystem.service
vm.laptop_mode = 2
vm.dirty_expire_centisecs = 100
vm.dirty_writeback_centisecs = 100
net.ipv4.ip_forward = 0
net.ipv6.conf.all.forwarding = 0
net.ipv4.conf.all.rp_filter = 1
net.ipv4.conf.default.rp_filter = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.all.autoconf = 0
net.ipv6.conf.default.autoconf = 0
kernel.panic_on_oops = 1
vm.panic_on_oom = 2
[Supervisor] Info: sysctl.service exit success
0+1 records in
0+1 records out
[Supervisor] Info: apparmor.service exit success
[ 21.691569][ T1627] *****
[ 22.050125][ T1838] audit: type=1400 audit(21.388:3): apparmor="STATUS" operation="profile_load" name="/sbin/nqcs" pid=1838 comm="dd"
[ 22.052196][ T1843] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 1843
[ 22.135999][ T1627] **
[ 22.293816][ T29] xrx500-eth 1e000000.ssx0:eth@a00000 eth3: Link is Up - 10Mbps/Full - flow control off
[ 22.313767][ T1627] *
[ 22.319920][ T1841] UBIFS (ubi0:3): recovery needed
[ 22.402657][ T1627] ***
[ 22.625460][ T1841] UBIFS (ubi0:3): recovery completed
[ 22.625601][ T1841] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "avm_userdata"
[ 22.625612][ T1841] UBIFS (ubi0:3): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 22.625625][ T1841] UBIFS (ubi0:3): FS size: 397651968 bytes (379 MiB, 1541 LEBs), journal size 19869696 bytes (18 MiB, 77 LEBs)
[ 22.625631][ T1841] UBIFS (ubi0:3): reserved for root: 4952683 bytes (4836 KiB)
[ 22.625643][ T1841] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID 5B5C14EA-1A97-449F-9884-F431B6483D42, small LPT model
[INFO] /dev/ubi0_3 mounted at /var/media/ftp
[Supervisor] Info: filesystem.service exit success
[Supervisor] Info: start default-files.service
TAM: create directory /data/tam
ermittle die aktuelle TTY
[ 22.669320][ T1627] **
[ 22.797829][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=2920 mW
[ 22.797878][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=5 div=1 offset=0 NormP=2500 mW -> SumNormP=5420 mW
[ 22.797891][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate=500 act_rate=0 mul=5 div=1 offset=0 NormP=2500 mW -> SumNormP=7920 mW
[ 22.797905][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=130 div=10 offset=100 NormP=1400 mW -> SumNormP=9320 mW
[ 22.797917][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=9726 mW
[ 22.797929][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=9726 mW
[ 22.797943][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=54 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=11226 mW
[ 22.797965][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1000 NormP=1000 mW -> SumNormP=12226 mW
[ 22.797979][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=2000 NormP=2000 mW -> SumNormP=14226 mW
[ 22.797991][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=14326 mW
[ 22.798003][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=14426 mW
[ 22.798018][ T1858] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=2817 act_rate=268435456 mul=1 div=1 offset=50 NormP=2867 mW -> SumNormP=17293 mW
[Supervisor] Info: default-files.service exit success
[Supervisor] Info: start config.service
tty is "/dev/ttyLTQ0"
Serielles Terminal
disable start/stop characters and flowcontrol
Jan 1 1970 01:00:22 ar7cfgctl[1865]: [ERROR] load_config(ar7): file empty - factory default loaded
[Supervisor] Info: config.service exit success
# [ 22.847089][ T1627] *****
[ 23.244522][ T1627] [piglet]dect_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[ 25.264526][ T1627] [piglet]bitfile '/lib/modules/bitfile.bit'
[ 25.264578][ T1627] [piglet]try to preload in progress-context: /lib/modules/bitfile.bit
[ 27.830121][ T1647] thermal thermal_zone0: failed to read out thermal zone (-5)
[ 28.534025][ T1627] [piglet] bitfile 340697 bytes in 3268 ms done
[ 28.634246][ T1627] [piglet]TDM: FS: 5 Hz CLK: 5 Hz
[Supervisor] Info: piglet.service exit success
[Supervisor] Info: start capi.service
[ 28.817777][ T1873] [module-mem] module 'pcmlink' reserved size 483328 is to great for demand size 475136 - waste 8192 (module_alloc_waste=90112)
[ 28.817804][ T1873] [module-mem] give 0x74000 bytes at 97424000 to module 'pcmlink' (0x7e8000 bytes left)
[ 28.827180][ T1873] Could not find Env 'kernel_args' in the device tree
[ 29.296853][ T1875] [module-mem] module 'isdn_fbox_fon5' reserved size 1404928 is to great for demand size 1396736 - waste 8192 (module_alloc_waste=98304)
[ 29.296885][ T1875] [module-mem] give 0x155000 bytes at 97498000 to module 'isdn_fbox_fon5' (0x693000 bytes left)
[ 29.329631][ T1875] [capi_oslib]avm_stack_attach: cpu3
[ 29.335299][ T555] [avm_power]_avm_power_pm_qos_latency: set latency to 199 us
[ 29.335368][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 28 (io-28) for avm-gpio:gpio_avm_pcmlink_fsc
[ 29.335386][ T1879] intel-pinctrl 16c80000.pinctrl: set mux group name: tdmfsc, pin num: 1
[ 29.335419][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 31 (io-31) for avm-gpio:gpio_avm_pcmlink_dcl
[ 29.335431][ T1879] intel-pinctrl 16c80000.pinctrl: set mux group name: tdmdcl, pin num: 1
[ 29.336351][ T1879] tdm_get_irqdata(0): irq 273 flags 1028
[ 29.336382][ T1879] tdm_get_irqdata(1): irq 274 flags 1025
[ 30.376452][ T1879] Rx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 30.376494][ T1879] Tx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 30.376511][ T1879] FATAL ERROR (state checkslot)
[ 30.376653][ T1879] Fast-Irqs: 0 Irqs: 0 (triggered: 0)
b6500000:PCM_CTRLR 00004000 b6500004:PCM_CTRLX 00000000
b6500008:PCM_STATR 00000000 b650000c:PCM_STATX ffffffff
b6500010:PCM_FREQ(0x0) dis DCL: 0
b6500014:PCM_CFG(0000c101) en DS=1 PCMXO=1 DCK=0 XS=0 RS=0 ND=0 SF=0 PCMRO=1
b6500018:PCM_EN 7fff b650001c:PCM_TEST 0000
b6500020:PCM_MODE 7fff b6500024:PCM_STAT 0000001f
[ 30.376686][ T1879] [00] b6500028 CFG: 00000000 RH 0 RTS: 00 XH 0 XTS 00
[ 30.376720][ T1879] [01] b650002c CFG: 00020002 RH 0 RTS: 02 XH 0 XTS 02
[ 30.376754][ T1879] [02] b6500030 CFG: 00040004 RH 0 RTS: 04 XH 0 XTS 04
[ 30.376788][ T1879] [03] b6500034 CFG: 00060006 RH 0 RTS: 06 XH 0 XTS 06
[ 30.376823][ T1879] [04] b6500038 CFG: 00080008 RH 0 RTS: 08 XH 0 XTS 08
[ 30.376857][ T1879] [05] b650003c CFG: 000a000a RH 0 RTS: 0a XH 0 XTS 0a
[ 30.376890][ T1879] [06] b6500040 CFG: 000c000c RH 0 RTS: 0c XH 0 XTS 0c
[ 30.376922][ T1879] [07] b6500044 CFG: 000e000e RH 0 RTS: 0e XH 0 XTS 0e
[ 30.376957][ T1879] [08] b6500048 CFG: 00100010 RH 0 RTS: 10 XH 0 XTS 10
[ 30.376992][ T1879] [09] b650004c CFG: 00120012 RH 0 RTS: 12 XH 0 XTS 12
[ 30.377029][ T1879] [10] b6500050 CFG: 00140014 RH 0 RTS: 14 XH 0 XTS 14
[ 30.377065][ T1879] [11] b6500054 CFG: 00160016 RH 0 RTS: 16 XH 0 XTS 16
[ 30.377100][ T1879] [12] b6500058 CFG: 00180018 RH 0 RTS: 18 XH 0 XTS 18
[ 30.377136][ T1879] [13] b650005c CFG: 001a001a RH 0 RTS: 1a XH 0 XTS 1a
[ 30.377171][ T1879] [14] b6500060 CFG: 001c001c RH 0 RTS: 1c XH 0 XTS 1c
[ 30.377234][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[0] 9ec21040 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 30.377297][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[1] 9ec21400 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 30.380111][ T1879] Cycle-Freq: 200 MHz
[ 30.380142][ T1879] [cpu=0 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fcfff08 gp=9fcfc000) from 16136 bytes
[ 30.380166][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 30.380193][ T1879] [cpu=0 tc=3]yield: mask=0x1000 trigger=0 stack-used=80(stack-start=9fd0ff08 gp=9fd0c000) from 16136 bytes
[ 30.380438][ T1879] [12]handler: 0x97434170 ltdm_yield+0x0/0x58 [pcmlink] enable=1 count=0 unhandled=0
[ 30.380476][ T1879] [cpu=0 tc=4]yield: mask=0x8000 trigger=0 stack-used=80(stack-start=9fd17f08 gp=9fd14000) from 16136 bytes
[ 30.380510][ T1879] [15]handler: 0x974344f4 ltdm_yield_fastframeyield+0x0/0x28 [pcmlink] enable=1 count=0 unhandled=0
[ 30.380545][ T1879] [cpu=0 tc=5]yield: mask=0x800 trigger=673289 stack-used=304(stack-start=9fd27f08 gp=9fd24000) from 16136 bytes
[ 30.380637][ T1879] [11]handler: 0x926a6be8 yield_handler+0x0/0x50 enable=1 count=673290 unhandled=0
[ 30.380666][ T1879] cycle-stat: [ 673291]consumption: min= 144 max= 2810 avg= 250
[ 30.380697][ T1879] cycle-stat: [ 673291]trigger : min= 6414 max= 9586 avg= 8000
[ 30.380728][ T1879] [cpu=2 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fd07f08 gp=9fd04000) from 16136 bytes
[ 30.380760][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 30.381169][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 28 (io-28) for gpiochip0:508
[ 30.381400][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 31 (io-31) for gpiochip0:511
[ 30.481866][ T1879] [xr9tdm_checkhw]TDM: FS: 5 Hz CLK: 5 Hz
[ 30.529161][ T0] [3]system-load 48% loadavg 0.54 0.13 0.4 - task runtime:3% max:modprobe 0% pgstat: sum=113102 free=93841 slab=3893 alloc=807/s fault=483/s (sleep 1)
[ 30.652981][ T0] [1]system-load 30% loadavg 0.54 0.13 0.4 - task runtime:2% max:kworker/3:1H 0% pgstat: sum=113102 free=93841 slab=3893 alloc=771/s fault=474/s (sleep 3)
[ 40.776448][ T1879] Rx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 40.776497][ T1879] Tx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 40.776515][ T1879] FATAL ERROR (state checkslot)
[ 40.776657][ T1879] Fast-Irqs: 0 Irqs: 0 (triggered: 0)
[ 40.776692][ T1879] [00] b6500028 CFG: 00000000 RH 0 RTS: 00 XH 0 XTS 00
[ 40.776726][ T1879] [01] b650002c CFG: 00020002 RH 0 RTS: 02 XH 0 XTS 02
[ 40.776761][ T1879] [02] b6500030 CFG: 00040004 RH 0 RTS: 04 XH 0 XTS 04
[ 40.776795][ T1879] [03] b6500034 CFG: 00060006 RH 0 RTS: 06 XH 0 XTS 06
[ 40.776828][ T1879] [04] b6500038 CFG: 00080008 RH 0 RTS: 08 XH 0 XTS 08
[ 40.776861][ T1879] [05] b650003c CFG: 000a000a RH 0 RTS: 0a XH 0 XTS 0a
[ 40.776895][ T1879] [06] b6500040 CFG: 000c000c RH 0 RTS: 0c XH 0 XTS 0c
[ 40.776929][ T1879] [07] b6500044 CFG: 000e000e RH 0 RTS: 0e XH 0 XTS 0e
[ 40.776964][ T1879] [08] b6500048 CFG: 00100010 RH 0 RTS: 10 XH 0 XTS 10
[ 40.776998][ T1879] [09] b650004c CFG: 00120012 RH 0 RTS: 12 XH 0 XTS 12
[ 40.777035][ T1879] [10] b6500050 CFG: 00140014 RH 0 RTS: 14 XH 0 XTS 14
[ 40.777068][ T1879] [11] b6500054 CFG: 00160016 RH 0 RTS: 16 XH 0 XTS 16
[ 40.777103][ T1879] [12] b6500058 CFG: 00180018 RH 0 RTS: 18 XH 0 XTS 18
[ 40.777138][ T1879] [13] b650005c CFG: 001a001a RH 0 RTS: 1a XH 0 XTS 1a
[ 40.777173][ T1879] [14] b6500060 CFG: 001c001c RH 0 RTS: 1c XH 0 XTS 1c
[ 40.777238][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[0] 9ec21040 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 40.777299][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[1] 9ec21400 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 40.780092][ T1879] Cycle-Freq: 200 MHz
[ 40.780123][ T1879] [cpu=0 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fcfff08 gp=9fcfc000) from 16136 bytes
[ 40.780146][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 40.780173][ T1879] [cpu=0 tc=3]yield: mask=0x1000 trigger=0 stack-used=80(stack-start=9fd0ff08 gp=9fd0c000) from 16136 bytes
[ 40.780198][ T1879] [12]handler: 0x97434170 ltdm_yield+0x0/0x58 [pcmlink] enable=1 count=0 unhandled=0
[ 40.780441][ T1879] [cpu=0 tc=4]yield: mask=0x8000 trigger=0 stack-used=80(stack-start=9fd17f08 gp=9fd14000) from 16136 bytes
[ 40.780539][ T1879] [15]handler: 0x974344f4 ltdm_yield_fastframeyield+0x0/0x28 [pcmlink] enable=1 count=0 unhandled=0
[ 40.780574][ T1879] [cpu=0 tc=5]yield: mask=0x800 trigger=933256 stack-used=304(stack-start=9fd27f08 gp=9fd24000) from 16136 bytes
[ 40.780604][ T1879] [11]handler: 0x926a6be8 yield_handler+0x0/0x50 enable=1 count=933257 unhandled=0
[ 40.780633][ T1879] cycle-stat: [ 259967]consumption: min= 293 max= 1062 avg= 438
[ 40.780661][ T1879] cycle-stat: [ 259967]trigger : min= 7514 max= 8476 avg= 8001
[ 40.780697][ T1879] [cpu=2 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fd07f08 gp=9fd04000) from 16136 bytes
[ 40.780734][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 40.781141][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 28 (io-28) for gpiochip0:508
[ 40.781366][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 31 (io-31) for gpiochip0:511
[ 40.881650][ T1879] [xr9tdm_checkhw]TDM: FS: 5 Hz CLK: 5 Hz
[ 50.800314][ C3] start slab_allocator-trace now (use cat /proc/slab_allocators)
[ 51.176435][ T1879] Rx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 51.176471][ T1879] Tx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 51.176489][ T1879] FATAL ERROR (state checkslot)
[ 51.176630][ T1879] Fast-Irqs: 0 Irqs: 0 (triggered: 0)
[ 51.176665][ T1879] [00] b6500028 CFG: 00000000 RH 0 RTS: 00 XH 0 XTS 00
[ 51.176700][ T1879] [01] b650002c CFG: 00020002 RH 0 RTS: 02 XH 0 XTS 02
[ 51.176733][ T1879] [02] b6500030 CFG: 00040004 RH 0 RTS: 04 XH 0 XTS 04
[ 51.176765][ T1879] [03] b6500034 CFG: 00060006 RH 0 RTS: 06 XH 0 XTS 06
[ 51.176799][ T1879] [04] b6500038 CFG: 00080008 RH 0 RTS: 08 XH 0 XTS 08
[ 51.176833][ T1879] [05] b650003c CFG: 000a000a RH 0 RTS: 0a XH 0 XTS 0a
[ 51.176868][ T1879] [06] b6500040 CFG: 000c000c RH 0 RTS: 0c XH 0 XTS 0c
[ 51.176902][ T1879] [07] b6500044 CFG: 000e000e RH 0 RTS: 0e XH 0 XTS 0e
[ 51.176937][ T1879] [08] b6500048 CFG: 00100010 RH 0 RTS: 10 XH 0 XTS 10
[ 51.176972][ T1879] [09] b650004c CFG: 00120012 RH 0 RTS: 12 XH 0 XTS 12
[ 51.177006][ T1879] [10] b6500050 CFG: 00140014 RH 0 RTS: 14 XH 0 XTS 14
[ 51.177041][ T1879] [11] b6500054 CFG: 00160016 RH 0 RTS: 16 XH 0 XTS 16
[ 51.177076][ T1879] [12] b6500058 CFG: 00180018 RH 0 RTS: 18 XH 0 XTS 18
[ 51.177111][ T1879] [13] b650005c CFG: 001a001a RH 0 RTS: 1a XH 0 XTS 1a
[ 51.177146][ T1879] [14] b6500060 CFG: 001c001c RH 0 RTS: 1c XH 0 XTS 1c
[ 51.177211][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[0] 9ec21040 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 51.177271][ T1879] FATAL ERROR (state checkslot) SLOT-RX-DATA[1] 9ec21400 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 51.180023][ T1879] Cycle-Freq: 200 MHz
[ 51.180054][ T1879] [cpu=0 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fcfff08 gp=9fcfc000) from 16136 bytes
[ 51.180077][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 51.180104][ T1879] [cpu=0 tc=3]yield: mask=0x1000 trigger=0 stack-used=80(stack-start=9fd0ff08 gp=9fd0c000) from 16136 bytes
[ 51.180126][ T1879] [12]handler: 0x97434170 ltdm_yield+0x0/0x58 [pcmlink] enable=1 count=0 unhandled=0
[ 51.180154][ T1879] [cpu=0 tc=4]yield: mask=0x8000 trigger=0 stack-used=80(stack-start=9fd17f08 gp=9fd14000) from 16136 bytes
[ 51.180180][ T1879] [15]handler: 0x974344f4 ltdm_yield_fastframeyield+0x0/0x28 [pcmlink] enable=1 count=0 unhandled=0
[ 51.180405][ T1879] [cpu=0 tc=5]yield: mask=0x800 trigger=1193222 stack-used=304(stack-start=9fd27f08 gp=9fd24000) from 16136 bytes
[ 51.180446][ T1879] [11]handler: 0x926a6be8 yield_handler+0x0/0x50 enable=1 count=1193223 unhandled=0
[ 51.180544][ T1879] cycle-stat: [ 259966]consumption: min= 293 max= 1060 avg= 438
[ 51.180574][ T1879] cycle-stat: [ 259965]trigger : min= 7722 max= 8286 avg= 8001
[ 51.180605][ T1879] [cpu=2 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fd07f08 gp=9fd04000) from 16136 bytes
[ 51.180637][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 51.181038][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 28 (io-28) for gpiochip0:508
[ 51.181264][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 31 (io-31) for gpiochip0:511
[ 51.281590][ T1879] [xr9tdm_checkhw]TDM: FS: 5 Hz CLK: 5 Hz
[ 60.848452][ T1879] Rx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 60.848494][ T1879] Tx: 0x0 -> 0x0 (TranspModeMask: 0x0 MuteMask: 0x0)
[ 60.848511][ T1879] PANIC:
[ 60.848649][ T1879] Fast-Irqs: 0 Irqs: 0 (triggered: 0)
[ 60.848685][ T1879] [00] b6500028 CFG: 00000000 RH 0 RTS: 00 XH 0 XTS 00
[ 60.848719][ T1879] [01] b650002c CFG: 00020002 RH 0 RTS: 02 XH 0 XTS 02
[ 60.848753][ T1879] [02] b6500030 CFG: 00040004 RH 0 RTS: 04 XH 0 XTS 04
[ 60.848787][ T1879] [03] b6500034 CFG: 00060006 RH 0 RTS: 06 XH 0 XTS 06
[ 60.848821][ T1879] [04] b6500038 CFG: 00080008 RH 0 RTS: 08 XH 0 XTS 08
[ 60.848853][ T1879] [05] b650003c CFG: 000a000a RH 0 RTS: 0a XH 0 XTS 0a
[ 60.848887][ T1879] [06] b6500040 CFG: 000c000c RH 0 RTS: 0c XH 0 XTS 0c
[ 60.848921][ T1879] [07] b6500044 CFG: 000e000e RH 0 RTS: 0e XH 0 XTS 0e
[ 60.848956][ T1879] [08] b6500048 CFG: 00100010 RH 0 RTS: 10 XH 0 XTS 10
[ 60.848991][ T1879] [09] b650004c CFG: 00120012 RH 0 RTS: 12 XH 0 XTS 12
[ 60.849028][ T1879] [10] b6500050 CFG: 00140014 RH 0 RTS: 14 XH 0 XTS 14
[ 60.849063][ T1879] [11] b6500054 CFG: 00160016 RH 0 RTS: 16 XH 0 XTS 16
[ 60.849097][ T1879] [12] b6500058 CFG: 00180018 RH 0 RTS: 18 XH 0 XTS 18
[ 60.849132][ T1879] [13] b650005c CFG: 001a001a RH 0 RTS: 1a XH 0 XTS 1a
[ 60.849167][ T1879] [14] b6500060 CFG: 001c001c RH 0 RTS: 1c XH 0 XTS 1c
[ 60.849230][ T1879] PANIC: SLOT-RX-DATA[0] 9ec21040 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 60.849289][ T1879] PANIC: SLOT-RX-DATA[1] 9ec21400 : 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
[ 60.852038][ T1879] Cycle-Freq: 200 MHz
[ 60.852069][ T1879] [cpu=0 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fcfff08 gp=9fcfc000) from 16136 bytes
[ 60.852092][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 60.852119][ T1879] [cpu=0 tc=3]yield: mask=0x1000 trigger=0 stack-used=80(stack-start=9fd0ff08 gp=9fd0c000) from 16136 bytes
[ 60.852144][ T1879] [12]handler: 0x97434170 ltdm_yield+0x0/0x58 [pcmlink] enable=1 count=0 unhandled=0
[ 60.852168][ T1879] [cpu=0 tc=4]yield: mask=0x8000 trigger=0 stack-used=80(stack-start=9fd17f08 gp=9fd14000) from 16136 bytes
[ 60.852196][ T1879] [15]handler: 0x974344f4 ltdm_yield_fastframeyield+0x0/0x28 [pcmlink] enable=1 count=0 unhandled=0
[ 60.852463][ T1879] [cpu=0 tc=5]yield: mask=0x800 trigger=1434992 stack-used=304(stack-start=9fd27f08 gp=9fd24000) from 16136 bytes
[ 60.852563][ T1879] [11]handler: 0x926a6be8 yield_handler+0x0/0x50 enable=1 count=1434993 unhandled=0
[ 60.852594][ T1879] cycle-stat: [ 241770]consumption: min= 293 max= 911 avg= 439
[ 60.852625][ T1879] cycle-stat: [ 241771]trigger : min= 7700 max= 8304 avg= 8000
[ 60.852655][ T1879] [cpu=2 tc=2]yield: mask=0x6000 trigger=0 stack-used=80(stack-start=9fd07f08 gp=9fd04000) from 16136 bytes
[ 60.852688][ T1879] [14]handler: 0x92aa1d94 monitor_ipi_yield_context+0x0/0x1f8 enable=1 count=0 unhandled=0
[ 60.853078][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 28 (io-28) for gpiochip0:508
[ 60.853296][ T1879] intel-pinctrl 16c80000.pinctrl: request pin 31 (io-31) for gpiochip0:511
[ 60.953709][ T1879] [xr9tdm_checkhw]TDM: FS: 5 Hz CLK: 5 Hz
[ 60.960528][ T1647] get_ul_manager: error: ll_handle= (null)
[ 60.960554][ T1647] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 60.980541][ T1647] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 61.920551][ T1647] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 61.940543][ T1647] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 61.960550][ T1647] [pcmlink_ul]pcmlink_ul_dsp[ 61.968402][ T1879] Kernel panic - not syncing:
[ 61.968402][ T1879] No answer on upper layer Control channel! PCMLINK probably dead!
[ 61.980559][ T1647] [pcmlink_ul]pcmlink_ul_dspfwversion_pcmrouter: no register
[ 61.989210][ C1] stop_cpu_hook cpu1 - stopped status=1100fc00
[ 61.989252][ C2] stop_cpu_hook cpu2 - stopped status=1100fc00
[ 61.989275][ C3] stop_cpu_hook cpu3 - stopped status=1100fc00
[ 61.989409][ T1879] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(1)UP(61)UTC(61)FW(08.02)HW(226)HWS(4)BV(1.3258)BN(117975)FS(08.02)BT(1)BD(0)
[ 62.020490][ T1879] Kernel relocated by 0x12190000
[ 62.024981][ T1879] .text @ 0x92690000
[ 62.028801][ T1879] .data @ 0x92f53dfc
[ 62.032620][ T1879] .bss @ 0x934a0000
[ 62.185361][ T1879] Rebooting in 1 seconds..
Second part.
As you can see in the log, the driver starts 4 attempts to initialize and gives up after the fourth attempt failed, too. The FPGA does not work as expected - the only option would be a customized firmware without telephony functions and then it's still not sure, that the rest of the system will work.
Any other attempt to fix it (by replacing the component) is IMHO a case of (further) wasted money - replacing the FPGA (it's a BGA chip AFAIK) is much more challenging (even if you could get the required spare parts) than replacing some voltage regulators.
I check the board with the thermal camera. The telephony chip, dialog sc14446 has a specific point getting hot. This is a good sign it's faulty. I have a lot of experience with boards of various type (gpu, motherboard, etc ..) ... when a corner is much hotter of the rest of the chip, there is damage.
So, maybe, I should try to find the psu for that chip and disabling it. Alternatively, I can desoldering the chip.
Good luck.
you are on the right way - PCMLINK error is caused by defective SC14446;
you should also check transistor on other side for s/c and DCDC-stepup output stage controlled by SC14446 - if Resistor labeled "R200" between
Source of Fet and GND is o/c and FET is s/c, SC14446 will die again after replacing;
you find FET and R near coil labeled "151" on bottom side
R200 is 0 ohm (should be 20 ohm, right?) FET seems ok. The chip sc14446 has a very small hole (I missed without the scope), so it's dead 100%.
Behind the chip there are four 0 ohm resistors ... they jump the 3,3v to various part of the chip. Once removed, you have very low resistance on the chip side of the resistors.
But the question is ... can the board boot up without power to sc14446? It seems this is not the case. You have the power led, but it doesn't boot ...
I don't care if telephony doesn't work.
R200 is 0,2 Ohm (20 Ohm would be 20R0)
with standard-FW you will get bootloop always..
replacing SC14446 is possible - take it out from another Box, reballing is not neccessary
Yeah, my fault ... r200 is 0,2 so the value I saw was the right one.
Anyway, at the moment, without the four 0 ohm resistors behind sc14446 chip, it does nothing. You get only the power led, no console, no ethernet ...
I actually thought disabling the chip would be enough. I could replace the chip, not an issue, but I don't know if I would find it at low price from another board (if I remember correctly, 7490 has the same chip).
So, it seems I need a modded firmware if I don't replace the chip ... but anyway, any idea why I have not bootloop without the four 0 ohm resistor? I check with a bench psu, they were connected to sc14446, so I don't understant why the rest of the board is affected ...
i don't know, whats wrong - normally the FBox should boot with bootloop;
but i did not try this before
if you need SC14446, i can sent/sell one to you
thanks but, at the moment, I don't think about replacing the chip because I don't trust the rest of the board. LAN2 has, for example, not the right impedance (should be 75 ohm but it's 23). This boards need to be checked very carefully before thinking of replacing that chip.
I am able to access busybox for some seconds before system reboot itself .... maybe it's possible to remove the dect kernel module with rmmod.
I checked the fs of 8.02 image ... would it be enough to remove the 2 dect kernel modules from the directory ?
Removing the chip is not enough.
./bin/supportdata.dect
./etc/default.Fritz_Box_HW226/1und1/dect_eeprom
./etc/default.Fritz_Box_HW226/1und1/upnp/devicedectlist.lua
./etc/default.Fritz_Box_HW226/1und1/upnp/x_dectSCPD.xml
./etc/default.Fritz_Box_HW226/avm/dect_eeprom
./etc/default.Fritz_Box_HW226/avm/upnp/devicedectlist.lua
./etc/default.Fritz_Box_HW226/avm/upnp/x_dectSCPD.xml
./etc/default.Fritz_Box_HW226/avme/dect_eeprom
./etc/default.Fritz_Box_HW226/avme/upnp/devicedectlist.lua
./etc/default.Fritz_Box_HW226/avme/upnp/x_dectSCPD.xml
./lib/modules/4.9.325/avm_dect
./lib/modules/4.9.325/avm_dect/avm_dect.ko
./lib/modules/4.9.325/dect_io
./lib/modules/4.9.325/dect_io/dect_io.ko
./lib/modules/dectfw_firstlevel_441.hex
./lib/modules/dectfw_secondlevel_441.hex
./lib/modules/dectfw_secondlevel_441p2test.hex
./sbin/start_dect_update.sh
./usr/bin/dect_bg_image_conversion.sh
./usr/bin/dect_doorline_image_conversion.sh
./usr/bin/dect_manager
./usr/bin/dect_ringtone_conversion.sh
./usr/share/aha/libdectule.so
./usr/share/aha/libdectule.so.1
./usr/share/aha/libdectule.so.1.0.0
./usr/share/configd/dectmediadefault.xml
./usr/share/ctlmgr/libdect.so
./usr/share/moved/libmove_dect_d.so
./usr/share/moved/libmove_dect_s.so
Probably not. There will still be lots of dependencies or calls in other modules, not to mention the whole UI which wants to display things coming from DECT.
I don't know how Freetz and later modifications work, if they just remove the unwanted stuff or if they also modify other parts. My understanding is "yes, that has to be done too."
Probably, the only solution is a freetz-ng custom image.
Just checking menuconfig, there seems to be a patch for removing DECT ...
I tried: I compiled an image with remove DECT patch .... still crashing, still bootloop.
[   23.579993] cchardevice: device_create(kdsldptrace%d): 236,21
[   23.585810] cchardevice: device_create(kdsldptrace%d): 236,22
[   23.591492] cchardevice: device_create(kdsldptrace%d): 236,23
[   23.597176] cchardevice: device_create(kdsldptrace%d): 236,24
[   23.602900] cchardevice: device_create(kdsldptrace%d): 236,25
[   23.608635] cchardevice: device_create(kdsldptrace%d): 236,26
[   23.614365] cchardevice: device_create(kdsldptrace%d): 236,27
[   23.620161] cchardevice: device_create(kdsldptrace%d): 236,28
[   23.625805] cchardevice: device_create(kdsldptrace%d): 236,29
[   23.631617] cchardevice: device_create(kdsldptrace%d): 236,30
[   23.637348] cchardevice: device_create(kdsldptrace%d): 236,31
[   23.643023] cchardevice: device_create(kdsldptrace%d): 236,32
[   23.648802] kdsld[1]: Initialisation of packettrace [OK]
[   23.653694] kdsld[1]: Initialisation of nqos ...
[   23.658517] cchardevice: device_create(knqos): 235,0
[   23.665837] cchardevice: device_create(avmtrackd): 234,0
[   23.670175] CHRDEV "avmtrackdquery" major number 233 goes below the dynamic allocation range
[   23.678356] cchardevice: device_create(avmtrackdquery): 233,0
[   23.684535] kdsld[1]: Initialisation of nqos [OK]
[   23.688619] kdsld[1]: Initialisation of http_filter ...
[   23.693774] CHRDEV "userman_url" major number 232 goes below the dynamic allocation range
[   23.702129] cchardevice: device_create(userman_url): 232,0
[   23.707769] url_dev_register device userman_url registerd
[   23.712803] kdsld[1]: Initialisation of http_filter [OK]
[   23.718070] kdsld[1]: Initialisation of atmvcchook ...
[   23.723192] kdsld[1]: Initialisation of atmvcchook [OK]
[   23.728399] kdsld[1]: Initialisation of timer ...
[   23.733104] kdsld[1]: Initialisation of timer [OK]
[   23.737861] kdsld[1]: Initialisation of netdevice_notifier ...
[   23.743774] kdsld[1]: Initialisation of netdevice_notifier [OK]
[   23.749598] kdsld[1]: Initialisation of ttychannel_ldisc ...
[   23.755226] kdsld[1]: ttychannel: ldisc 8 registered
[   23.760201] kdsld[1]: Initialisation of ttychannel_ldisc [OK]
[   23.765897] kdsld[1]: Initialisation of guestflt ...
[   23.770994] kdsld[1]: Initialisation of guestflt [OK]
[   23.775883] kdsld[1]: Initialisation of bridgeflt ...
[   23.780921] CHRDEV "bridgeflt" major number 231 goes below the dynamic allocation range
[   23.789096] cchardevice: device_create(bridgeflt): 231,0
[   23.794677] kdsld[1]: Initialisation of bridgeflt [OK]
[   23.799368] kdsld[1]: Initialisation of krextd ...
[   23.804102] kdsld[1]: Initialisation of krextd:debughandles ...
[   23.810032] kdsld[1]: Initialisation of krextd:debughandles [OK]
[   23.815989] kdsld[1]: Initialisation of krextd:global ...
[   23.821381] kdsld[1]: Initialisation of krextd:global [OK]
[   23.826840] kdsld[1]: Initialisation of krextd:memcache ...
[   23.834267] kdsld[1]: Initialisation of krextd:memcache [OK]
[   23.838555] kdsld[1]: Initialisation of krextd:igmpcompr ...
[   23.844163] kdsld[1]: Initialisation of krextd:igmpcompr [OK]
[   23.849862] kdsld[1]: Initialisation of krextd:krextdev ...
[   23.855475] CHRDEV "krextd" major number 230 goes below the dynamic allocation range
[   23.863305] cchardevice: device_create(krextd): 230,0
[   23.868628] kdsld[1]: Initialisation of krextd:krextdev [OK]
[   23.873849] kdsld[1]: Initialisation of krextd:krextdev_wland ...
[   23.879943] CHRDEV "krextd_wlan" major number 229 goes below the dynamic allocation range
[   23.888274] cchardevice: device_create(krextd_wlan): 229,0
[   23.893929] kdsld[1]: Initialisation of krextd:krextdev_wland [OK]
[   23.899752] kdsld[1]: Initialisation of krextd:netdevice_notifier ...
[   23.906194] kdsld[1]: Initialisation of krextd:netdevice_notifier [OK]
[   23.912626] kdsld[1]: Initialisation of krextd:krextdprocfs ...
[   23.918677] kdsld[1]: Initialisation of krextd:krextdprocfs [OK]
[   23.924519] kdsld[1]: Initialisation of krextd:krextdtimer ...
[   23.930346] kdsld[1]: Initialisation of krextd:krextdtimer [OK]
[   23.936237] kdsld[1]: Initialisation of krextd [OK]
[   23.941097] kdsld[1]: Initialisation of kdsldprocfs ...
[   23.946359] kdsld[1]: Initialisation of kdsldprocfs [OK]
[   23.951600] kdsld[1]: Initialisation of pcp ...
[   23.957030] kdsld[1]: Initialisation of pcp [OK]
[   23.960749] kdsld[1]: Initialisation [OK]
[   24.015179] [module-mem] module 'kspeedtest' reserved size 20480 is to great for demand size 16384 - waste 4096 (module_alloc_waste=73728)
[   24.026203] [module-mem] give 0x4000 bytes at 9f1ba000 to module 'kspeedtest' (0x899000 bytes left)
[   24.036844] kspeedtest: kspeedtest_init: second timer started
[   24.041359] kspeedtest: Starting default task on discard port 9
[   24.047231] kspeedtest: listening on port 9
[   24.051303] kspeedtest: kspeedtest_init done
[   24.085104] [module-mem] give 0x1000 bytes at 9f1be000 to module 'offload_util' (0x898000 bytes left)
[   24.112305] [module-mem] module 'ktestdrive' reserved size 8192 is to great for demand size 4096 - waste 4096 (module_alloc_waste=77824)
[   24.123137] [module-mem] give 0x1000 bytes at 9f1bf000 to module 'ktestdrive' (0x897000 bytes left)
[   24.167359] [module-mem] module 'offload_dp' reserved size 49152 is to great for demand size 45056 - waste 4096 (module_alloc_waste=81920)
[   24.178378] [module-mem] give 0xb000 bytes at 9f1c0000 to module 'offload_dp' (0x88c000 bytes left)
[   24.190569] [cbm] { dp_port_alloc : 3215 }flags 0x20
[   24.194119] [cbm] { cbm_add_to_list : 438 }1
[   24.198487] [cbm] { dp_enable : 3711 }ep=7 tmu_port=2 queue=35 sid=19
[   24.204767] [cbm] { dp_enable : 3743 }egp_type 0x20
[   24.210046] [cbm] { dequeue_dma_port_init : 4608 }21 0x0 1 6
[   24.215289] [cbm] { dequeue_dma_port_init : 4608 }20 0x0 1 5
[   24.220950] [cbm] { dp_enable : 3777 }enable queue 35
[   24.225930] [cbm] { dp_enable : 3778 }flag 1 refcnt 1488
[   24.233919] [module-mem] give 0x3000 bytes at 9f1cb000 to module 'offload_qos' (0x889000 bytes left)
[   24.317340] [module-mem] module 'offload_pa' reserved size 114688 is to great for demand size 110592 - waste 4096 (module_alloc_waste=86016)
[   24.328520] [module-mem] give 0x1b000 bytes at 9f1ce000 to module 'offload_pa' (0x86e000 bytes left)
[   24.356583] [module-mem] give 0x3000 bytes at 9f1e9000 to module 'sch_hw' (0x86b000 bytes left)
[   24.394837] [module-mem] give 0x3000 bytes at 9f1ec000 to module 'sch_llq' (0x868000 bytes left)
[   24.416586] [module-mem] give 0x3000 bytes at 9f1ef000 to module 'sch_tbf' (0x865000 bytes left)
[   24.871673] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[   24.883286] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[   24.896042] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[   24.908905] sch_hw: adjust excessive latency to ~5ms (687500 Bytes)
[   24.997521] audit: type=1400 audit(24.492:3): apparmor="STATUS" operation="profile_load" name="/sbin/nqcs" pid=2178 comm="dd"
0+1 records in
0+1 records out
[   25.016415] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 2181
[   25.279896] UBIFS (ubi0:3): recovery needed
[   25.586324] UBIFS (ubi0:3): recovery completed
[   25.589511] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "avm_userdata"
[   25.597269] UBIFS (ubi0:3): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[   25.607149] UBIFS (ubi0:3): FS size: 397651968 bytes (379 MiB, 1541 LEBs), journal size 19869696 bytes (18 MiB, 77 LEBs)
[   25.617995] UBIFS (ubi0:3): reserved for root: 4952683 bytes (4836 KiB)
[   25.624597] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID A837573E-338C-42AC-A44D-FD3D54C1F743, small LPT model
[   25.813815] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=2920 mW
[   25.827068] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=5 div=1 offset=0 NormP=2500 mW -> SumNormP=5420 mW
[   25.841368] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate=500 act_rate=0 mul=5 div=1 offset=0 NormP=2500 mW -> SumNormP=7920 mW
[   25.855791] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=130 div=10 offset=100 NormP=1400 mW -> SumNormP=9320 mW
[   25.870160] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=9726 mW
[   25.884559] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=9726 mW
[   25.898720] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=52 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=11226 mW
[   25.913319] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1000 NormP=1000 mW -> SumNormP=12226 mW
[   25.928147] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=2000 NormP=2000 mW -> SumNormP=14226 mW
[   25.943282] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=14326 mW
[   25.957402] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=14426 mW
[   25.971553] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=2817 act_rate=268435456 mul=1 div=1 offset=50 NormP=2867 mW -> SumNormP=17293 mW
[Supervisor] Info: start debug.service
vm.laptop_mode = 2
vm.panic_on_oom = 2
kernel.printk = 4
net.ipv4.ip_fo[   26.061892] sysrq: Changing Loglevel
[   26.065254] sysrq: Loglevel set to 4
rward = 1
net.[   26.073863]
[   26.073863] [avm_debug] redirecting kernel-messages (/dev/debug)
[Supervisor] Info: debug.service exit success
ar7cfgctl[2206]: load_config(ar7): file empty - factory default loaded
~ # [   53.819221][1]set_reboot_status: NMI-Watchdog-Reset(NMI)  - NMI(1) PANIC(1)SUM(2)UP(53)UTC(53)FW(07.57)HW(226)HWS(4)BV(1.3258)BN(107893)FS(07.57)BT(1)BD(0)
[   53.831683][0]stop_cpu_hook cpu0 - stopped status=1100fc00
[   53.831693][2]stop_cpu_hook cpu2 - stopped status=1100fc00
[   53.831698][3]stop_cpu_hook cpu3 - stopped status=1100fc00
[   53.831701][1]shared interrupts:
[   53.851330][1] 57( 16)  1   IRQ  (0x0) POS EDGE       ENABLED        MIPS GIC     64                   IPI call               1213
[   53.863012][1] 61( 20)  1   IRQ  (0x0) POS EDGE       ENABLED        MIPS GIC     68                   IPI resched            2246
[   53.874753][1]118( 10)  1   IRQ  (0x1) POS EDGE       ENABLED   PEND MIPS GIC     125                  gptc_event1            8393
[   53.886649] CPU1 NMI taken (err)epc=0x93493e18 __udelay+0x48/0x58 [#1]:
[   53.893041] CPU: 1 PID: 1956 Comm: modprobe Tainted: P           O    4.9.325 #1
[   53.900411] task: 9d082e60 task.stack: 9d948000
[   53.904921] $ 0   : 00000000 93e80004 00122f78 00106256
[   53.910128] $ 4   : 00000001 ac778000 000b09b7 0001435c
[   53.915337] $ 8   : 00000100 00000000 93b2c280 00000134
[   53.920545] $12   : 9fa69dd8 00006c00 00000000 003d0900
[   53.925754] $16   : 00000001 bf2001c0 9efa0000 ffffffff
[   53.930962] $20   : 0000000a 00000009 9efa0000 9efa0000
[   53.936171] $24   : 00000000 934e1b2c
[   53.941379] $28   : 9d948000 9d94ba90 b6700000 9ef980e8
[   53.946589] Hi    : 000b09b7
[   53.949454] Lo    : af250000
[   53.952319] ac1Hi: 00000000 ac1Lo: 00000000
[   53.956486] ac2Hi: 00000000 ac2Lo: 00000000
[   53.960653] ac3Hi: 00000000 ac3Lo: 00000000
[   53.964818] dspcontrol: 00000000
[   53.968030] Status: 1108fc03 KERNEL EXL IE
[   53.972199] Cause : d0800000 exc_code:0
[   53.976113] epc   : 93493e18 0x93493e18 __udelay+0x48/0x58
[   53.981580] errepc: 93493e18 0x93493e18 __udelay+0x48/0x58
[   53.987164] ra    : 9ef980e8 0x9ef980e8 dect_loader+0x122c/0x2054 [Piglet_noemif]
[   53.994508] Tainted: P           O
[   53.998155] PrId  : 0001a120 (MIPS interAptiv (multi))
[   54.003536] Classified pointer on registers:
[   54.007530]  $12 : 9fa69dd8 [page: type:alloc]
[   54.012100]  $18 : 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.020192]  $22 : 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.028289]  $23 : 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.036480]  $25 : 934e1b2c shim_gpiod_ctrl+0x0/0x11c
[   54.041510]  $28 : 9d948000 [threadinfo(modprobe): 9d948000+0x0]
[   54.047469]  $29 : 9d94ba90 [stack(modprobe): 9d948000+0x3a90]
[   54.053350]  $31 : 9ef980e8 dect_loader+0x122c/0x2054 [Piglet_noemif]
[   54.059699] Modules linked in: sch_tbf sch_llq sch_hw(PO) offload_pa(O) offload_qos(O) offload_dp(O) ktestdrive(O) offload_util(O) kspeedtest(O) kdsldmod(PO) eth_oam_handler(PO) kskbtrace(O) cchardev(O) cprocfsmod(O) dc_mode_hw(O) directconnect_datapath(O) Piglet_noemif(PO+) ltq_eth_drv_xrx500 eip97(O) xrx500_phy_fw vrx518(O) nls_utf8 vfat fat cpunet(O) hui(O) eip123(O) eip123_hw(PO)
[   54.093648] Process modprobe (pid: 1956, threadinfo=9d948000, task=9d082e60, tls=772beee8)
[   54.101888] Stack : 9d94bb48 9ef9d3d0 00002580 ffff00fe 9ef9f4f4 9efa0000 938fd874 9356eb1c
[   54.110220]         9ef9a9cc 0000ce63 931287a0 9ef9657c c09d1000 0000000a 00000000 00000002
[   54.118554]         00000001 00000000 ffffffff 00000001 9ef9dbf4 9ef9dc10 00000000 9efa0000
[   54.126887]         00000001 931b5a04 9efa0000 93b30000 00000000 9efa0000 9ef9dbf4 9ef9dbfc
[   54.135221]         9d94bb48 00000139 0000031b 000000d5 00000000 9ef95e3c 00000001 00000000
[   54.143555]         ...
[   54.145997] Classified pointer on stack:
[   54.149895] 9d94bb48 [stack(modprobe): 9d948000+0x3b48]
[   54.155111] 9ef9d3d0 [module-alloc: 0x9ef9d3d0 (Piglet_noemif + 0x83d0) size: 45056]
[   54.162884] 9ef9f4f4 [module-alloc: 0x9ef9f4f4 (Piglet_noemif + 0xa4f4) size: 45056]
[   54.170570] 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.178127] 938fd874 schedule+0x0/0xac
[   54.181854] 9356eb1c avm_prom_get_config_internal_alloc+0x118/0x294
[   54.188142] 9ef9a9cc log_piglet+0x0/0x1e0 [Piglet_noemif]
[   54.193525] 931287a0 jiffies_to_msecs+0x0/0x8
[   54.197860] 9ef9657c ihex2bin+0x68c/0xb58 [Piglet_noemif]
[   54.203254] c09d1000 [vmalloc : size:204800 start:c09d1000+0x0 alloced by:0x9ef95f54 ihex2bin+0x64/0xb58 [Piglet_noemif]]
[   54.214187] 9ef9dbf4 [module-alloc: 0x9ef9dbf4 (Piglet_noemif + 0x8bf4) size: 45056]
[   54.221866] 9ef9dc10 [module-alloc: 0x9ef9dc10 (Piglet_noemif + 0x8c10) size: 45056]
[   54.229620] 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.237161] 931b5a04 printk+0x0/0x58
[   54.240708] 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.248286] 9efa0000 dc_dp_get_peripheral_config+0x0/0x5c [directconnect_datapath]
[   54.255808] 9ef9dbf4 [module-alloc: 0x9ef9dbf4 (Piglet_noemif + 0x8bf4) size: 45056]
[   54.263533] 9ef9dbfc [module-alloc: 0x9ef9dbfc (Piglet_noemif + 0x8bfc) size: 45056]
[   54.271386] 9ef95e3c get_bufaddr_from_dectaddr+0x78/0x12c [Piglet_noemif]
[   54.278127] c0a6f000 [vmalloc : size:204800 start:c0a6f000+0x0 alloced by:0x9ef95f54 ihex2bin+0x64/0xb58 [Piglet_noemif]]
[   54.289005] 9ef96ebc dect_loader+0x0/0x2054 [Piglet_noemif]
[   54.294620] c09d1000 [vmalloc : size:204800 start:c09d1000+0x0 alloced by:0x9ef95f54 ihex2bin+0x64/0xb58 [Piglet_noemif]]
[   54.305462] 9ef9f4f4 [module-alloc: 0x9ef9f4f4 (Piglet_noemif + 0xa4f4) size: 45056]
[   54.313206] Call Trace:
[   54.315621] [<93493e18>] 0x93493e18 __udelay+0x48/0x58
[   54.320793] [<9ef980e8>] 0x9ef980e8 dect_loader+0x122c/0x2054 [Piglet_noemif]
[   54.327939] [<9ef99378>] 0x9ef99378 dect_file_process+0x468/0xd2c [Piglet_noemif]
[   54.335405] [<9ef9afb0>] 0x9ef9afb0 piglet_loader_thread+0xe8/0x5e8 [Piglet_noemif]
[   54.343046] [<c09c6264>] 0xc09c6264 init_module+0x264/0x2d0 [Piglet_noemif]
[   54.349952] [<9308097c>] 0x9308097c do_one_initcall+0x5c/0x1c0
[   54.355731] [<9314e7f4>] 0x9314e7f4 do_init_module+0x68/0x224
[   54.361456] [<93150e54>] 0x93150e54 load_module+0x14ac/0x1690
[   54.367185] [<93151370>] 0x93151370 SyS_finit_module+0xfc/0x138
[   54.373100] [<930979a0>] 0x930979a0 syscall_common+0x34/0x54
[   54.378724] Code: 70441802  00661021  00000000 <1440ffff> 2442ffff  03e00008  00000000  8f83000c  000310c0
[   54.388441]
[   54.389930] ---- CPU_ID=0 CORE0 TC0 ----- (LINUX)
[   54.394611] Status:  1100fc00 KERNEL
[   54.398259] current: swapper/0 (pid: 0, threadinfo=93b10000, task=93b2f280, sp=93b13e48 tls=0x00000000)
[   54.407626] Call Trace:
[   54.410075] [<930886fc>] 0x930886fc r4k_wait_irqoff+0x20/0x40
[   54.415812] [<9310a89c>] 0x9310a89c cpu_startup_entry+0x148/0x19c
[   54.421878] [<93cdfca8>] 0x93cdfca8 start_kernel+0x51c/0x55c
[   54.427518] ---- CORE0 TC2 ----- (YIELD-Thread)
[   54.432027] current: CPU0-YIELD-TC2 (pid: 0, threadinfo=9fcfc000, task=9fcf8620, sp=9fcffec0 tls=0x00000000)
[   54.441828] Call Trace:[   54.444086]
[   54.445628] Unhandled kernel unaligned access[#2]:
[   54.450344] CPU: 1 PID: 1956 Comm: modprobe Tainted: P      D    O    4.9.325 #1
[   54.457718] task: 9d082e60 task.stack: 9d948000
[   54.462228] $ 0   : 00000000 00000000 00000000 d7a1097a
[   54.467437] $ 4   : d7a1097a 00000000 00000b6c 9354f3ec
[   54.472645] $ 8   : 00000000 00000000 00000001 00000001
[   54.477854] $12   : 00000000 93e88cbd 00000000 00000502
[   54.483062] $16   : 9fcffec0 93a1b930 93b30000 93ab0000
[   54.488271] $20   : 00000000 9fcffec4 93ea0000 93ea0000
[   54.493479] $24   : 00000000 00000000
[   54.498688] $28   : 9d948000 9d94b648 93eb0000 9308d7dc
[   54.503897] Hi    : 0000002c
[   54.506762] Lo    : 66666718
[   54.509627] ac1Hi: 00000000 ac1Lo: 00000000
[   54.513795] ac2Hi: 00000000 ac2Lo: 00000000
[   54.517961] ac3Hi: 00000000 ac3Lo: 00000000
[   54.522127] dspcontrol: 00000000
[   54.525339] Status: 1100fc02 KERNEL EXL
[   54.529247] Cause : 40800810 exc_code:4 AdEL
[   54.533499] BadVA : 9fcffec0
[   54.536380] epc   : 9308d8d0 0x9308d8d0 show_backtrace+0x194/0x1c4
[   54.542536] errepc: 93493e18 0x93493e18 __udelay+0x48/0x58
[   54.548005] ra    : 9308d7dc 0x9308d7dc show_backtrace+0xa0/0x1c4
[   54.554073] Tainted: P      D    O
[   54.557720] PrId  : 0001a120 (MIPS interAptiv (multi))
[   54.562969] Classified pointer on registers:
[   54.567096]  $ 7 : 9354f3ec lqasc_console_putchar+0x0/0x2c
[   54.572732]  $16 : 9fcffec0 [page O3[7]: type:alloc]
[   54.577565]  $21 : 9fcffec4 [page O3[7]: type:alloc]
[   54.582516]  $28 : 9d948000 [threadinfo(modprobe): 9d948000+0x0]
[   54.588457]  $29 : 9d94b648 [stack(modprobe): 9d948000+0x3648]
[   54.594276]  $31 : 9308d7dc show_backtrace+0xa0/0x1c4
[   54.599298] Modules linked in: sch_tbf sch_llq sch_hw(PO) offload_pa(O) offload_qos(O) offload_dp(O) ktestdrive(O) offload_util(O) kspeedtest(O) kdsldmod(PO) eth_oam_handler(PO) kskbtrace(O) cchardev(O) cprocfsmod(O) dc_mode_hw(O) directconnect_datapath(O) Piglet_noemif(PO+) ltq_eth_drv_xrx500 eip97(O) xrx500_phy_fw vrx518(O) nls_utf8 vfat fat cpunet(O) hui(O) eip123(O) eip123_hw(PO)
[   54.633247] Process modprobe (pid: 1956, threadinfo=9d948000, task=9d082e60, tls=772beee8)
[   54.641487] Stack : 9d94b65c 00000000 00000b6a 9354f3ec 93a5ffc4 9fcffec0 deadbeef d7a1097a
[   54.649820]         93b30000 93b30000 00000000 93ea0000 00000002 93ea6930 9d94b790 934920d0
[   54.658154]         93e86c98 9fcf895c 00000000 9fcfc000 9fcf8620 9fcffec0 00000008 00000000
[   54.666487]         00000000 93ea6930 93a5ff7c 93e82558 93a5ff30 93970000 93a60000 9fcfc000
[   54.674821]         9fcf8620 00000000 93a5fe60 00000000 00000034 93e90000 00000000 93e890ba
[   54.683155]         ...
[   54.685593] Classified pointer on stack:
[   54.689494] 9d94b65c [stack(modprobe): 9d948000+0x365c]
[   54.694755] 9354f3ec lqasc_console_putchar+0x0/0x2c
[   54.699594] 9fcffec0 [page O3[7]: type:alloc]
[   54.703945] 9d94b790 [stack(modprobe): 9d948000+0x3790]
[   54.709121] 934920d0 arch_trigger_all_cpu_backtrace+0x3b4/0x430
[   54.715046] 9fcf895c [page O3[0]: type:alloc]
[   54.719404] 9fcfc000 [page O3[4]: type:alloc]
[   54.723724] 9fcf8620 [page O3[0]: type:alloc]
[   54.728064] 9fcffec0 [page O3[7]: type:alloc]
[   54.732478] 9fcfc000 [page O3[4]: type:alloc]
[   54.736745] 9fcf8620 [page O3[0]: type:alloc]
[   54.741169] 80000000 [page: type:alloc]
[   54.744886] 9d94b810 [stack(modprobe): 9d948000+0x3810]
[   54.750094] 9d94b810 [stack(modprobe): 9d948000+0x3810]
[   54.755315] Call Trace:
[   54.757736] [<9308d8d0>] 0x9308d8d0 show_backtrace+0x194/0x1c4
[   54.763553] [<934920d0>] 0x934920d0 arch_trigger_all_cpu_backtrace+0x3b4/0x430
[   54.770766] [<93577904>] 0x93577904 die_notifier+0x148/0x198
[   54.776410] [<930df75c>] 0x930df75c notifier_call_chain+0x6c/0xb0
[   54.782476] [<930df874>] 0x930df874 __atomic_notifier_call_chain+0x24/0x3c
[   54.789334] [<930e01a0>] 0x930e01a0 notify_die+0x50/0x80
[   54.794629] [<9308daec>] 0x9308daec die+0x4c/0x12c
[   54.799417] [<9357f578>] 0x9357f578 nmi_notify_last+0x78/0x84
[   54.805132] [<930df75c>] 0x930df75c notifier_call_chain+0x6c/0xb0
[   54.811209] [<930df984>] 0x930df984 raw_notifier_call_chain+0x14/0x20
[   54.817636] [<9308f638>] 0x9308f638 nmi_exception_handler+0x74/0xa8
[   54.823882] [<93086b18>] 0x93086b18 nmi_handler+0x14c/0x154
[   54.829435] Code: 0cc2d764  00000000  02801025 <7e10002f> 1000ffcb  00000000  0cc36e59  02002025  10400004
[   54.839149]
[   54.840633] ---[ end trace f8acf022e1cf0989 ]---
[   54.870985] Kernel panic - not syncing: Fatal exception in interrupt
[   54.875966] Kernel relocated by 0x12b80000
[   54.879942]  .text @ 0x93080000
[   54.883067]  .data @ 0x9393c8f0
[   54.886192]  .bss  @ 0x93e80000
[   54.914940] Rebooting in 1 seconds..
Mmmm .... it seems to be still there ...
[   46.571063] [<986c80e8>] 0x986c80e8 dect_loader+0x122c/0x2054 [Piglet_noemif]
[   46.578213] [<986c9378>] 0x986c9378 dect_file_process+0x468/0xd2c [Piglet_noemif]
Different problem (reset by watchdog) - and you still have to start the console session (where output will be redirected back to serial console - look into etc/profile.d/profile.sh) after the redirection message from avm_debug driver:
Rich (BBCode):
to see the reason for triggering this watchdog.
If I had to guess ... the FPGA loader driver (that's the Piglet_noemif.ko driver) tries to detect the DECT chipset, before an attempt to load the DECT firmware (no matter, whether it exists or not) is started, but can't contact the DECT chipset, because it's not powered anymore - timeout and the watchdog for loading the FPGA firmware gets triggered. You should get the complete log output first - to check the (real) reason for triggering.
Then you should disable EVERY telephony support - now the FPGA firmware shouldn't be loaded anymore. The modprobe command for Piglet_noemif.ko (in etc/init.d/S11-piglet) is only removed, if the whole telephony support is removed, too: https://github.com/Freetz-NG/freetz...9/patches/scripts/330-remove_telephony.sh#L40
Reaktionen: saronno
to use that patch I need to mod the .config file manually. There is no trace of that patch in menuconfig ...
PS: It doesn't work, the patch is not applied even if I add FREETZ_REMOVE_TELEPHONY=y
sophiabrown73
