access to debug.cfg in 7050 04.26 EN
skizzo3000
14 Jul 2006
HI,
i tried to copy debug.cfg in /var/tmp with this command:
cat /var/flash/debug.cfg > /var/tmp/mydebug.cfg
but mydebug.cfg is empty because this command gets an error:
BusyBox v1.2.1 (2006.08.06-16:28+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
/ # cd var/flash
/var/flash # cat /var/flash/debug.cfg > /var/tmp/mydebug.cfg
cat: /var/flash/debug.cfg: No such file or directory
/var/flash # ls
ar7.cfg        fx_cg          fx_moh         telefon_misc   wlan.cfg
calllog        fx_conf        multid.leases  tr069.cfg
debug.cfg      fx_def         net.update     voip.cfg
ds_mod         fx_lcr         stat.cfg       vpn.cfg
/var/flash #
why ?????
for files *.cfg is the same !
Thanks Sk3
Because the files don't exist. Even if they are listed.
Greets, Oliver
Just write one and stream it to debug.cfg:
cat /var/tmp/mydebug.cfg > /var/flash/debug.cfg
After that your lines of code will work and you can stream it out again later if you wish to add some code (don't forget to write it back after the changes):
holh-66
