AICCU doesn't assign IPv6 address to sixxs interface 7270v3
RomMon
29 Aug 2011
With the later trunk revisions (11058 or before, at least up to 11440) my 7270v3 isn't able to setup a IPv6 over IPv4 tunnel using AICCU.
The sixxs interface doesn't get an IPv6 address assigned, not even a link-local.
I only tried this with 11058 and 11440 (at this moment). It was working fine with freetz-1.2.
The ifconfig output also gives a strange line for the wifi interface (wifi0), see further below for complete output:
Interrupt:80 Memory:c2200000-c2210000
On my 7390 it is working fine using trunk revision 11466, using the same config.
While starting AICCU get the expected messages:
logread -f
Dec 28 20:17:32 fritz local7.info syslog: Succesfully retrieved tunnel information for <tunnel-id>
Dec 28 20:17:32 fritz local7.info syslog: AICCU running as PID 4677
Dec 28 20:17:32 fritz local7.info syslog: [AYIYA-start] : Anything in Anything (draft-02)
Dec 28 20:17:32 fritz local7.info syslog: [AYIYA-tun->tundev] : (Socket to TUN) started
Dec 28 20:17:33 fritz kern.warn kernel: [0]system-load 1  86 tasks:2 % curr:service(0 %) max:service(0 %, pid:4633), rea
dytorun: 2, pgfault 1020/s (max 1 avg 1.0)
root@fritz:/var/mod/root# ip -f inet6 addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
4: lan: <BROADCAST,MULTICAST,UP,LOWER_UP200> mtu 1500
    inet6 fe80::a:b:c:d/64 scope link
5: guest: <BROADCAST,MULTICAST,UP,LOWER_UP200> mtu 1500
root@fritz:/var/mod/root# ip -f inet6 route
fe80::/64 dev cpmac0  metric 256
fe80::/64 dev eth0  metric 256
fe80::/64 dev wifi0  metric 256
fe80::/64 dev ath0  metric 256
fe80::/64 dev lan  metric 256
fe80::/64 dev guest  metric 256
fe80::/64 dev sixxs  metric 256
ff00::/8 dev cpmac0  metric 256
ff00::/8 dev eth0  metric 256
ff00::/8 dev wifi0  metric 256
ff00::/8 dev ath0  metric 256
ff00::/8 dev lan  metric 256
ff00::/8 dev guest  metric 256
ff00::/8 dev sixxs  metric 256
unreachable default dev lo  metric -1  error -128
root@fritz:/var/mod/root# ifconfig
adsl      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:2000  Metric:1
          RX packets:1703 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1877 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:32
          RX bytes:284737 (278.0 KiB)  TX bytes:224893 (219.6 KiB)
ath0      Link encap:Ethernet  HWaddr 00:aa:bb:cc:ddC:ee
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:2290  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:477 errors:0 dropped:291 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:77840 (76.0 KiB)
cpmac0    Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2718 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2711 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:327397 (319.7 KiB)  TX bytes:631718 (616.9 KiB)
dsl       Link encap:Point-to-Point Protocol
          inet addr:192.168.178.1  P-t-P:192.168.178.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:1421 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1606 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:214609 (209.5 KiB)  TX bytes:156381 (152.7 KiB)
eth0      Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:128
guest     Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          inet addr:192.168.179.1  Bcast:192.168.179.255  Mask:255.255.255.0
          inet6 addr: fe80::224:feff:fefa:a344/64 Scope:Link
          TX packets:21 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:1626 (1.5 KiB)
lan       Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          inet addr:192.168.178.1  Bcast:192.168.178.255  Mask:255.255.255.0
          inet6 addr: fe80::a:b:c:d/64 Scope:Link
          RX packets:2713 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2718 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:288799 (282.0 KiB)  TX bytes:632262 (617.4 KiB)
lan:0     Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          inet addr:169.254.1.1  Bcast:169.254.255.255  Mask:255.255.0.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:321 errors:0 dropped:0 overruns:0 frame:0
          TX packets:321 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:40074 (39.1 KiB)  TX bytes:40074 (39.1 KiB)
sixxs     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1280  Metric:1
          RX packets:1 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:1028 (1.0 KiB)  TX bytes:0 (0.0 B)
wifi0     Link encap:Ethernet  HWaddr 00:aa:bb:cc:dd:ee
          RX packets:28690 errors:0 dropped:0 overruns:0 frame:9504
          TX packets:772 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7565024 (7.2 MiB)  TX bytes:184247 (179.9 KiB)
Edit (29-12-2013: 0:52):
-Tried freetz-1.2 again, where after starting AICCU the sixxs interface is correctly assigned a global IPv6 address.
-Found an old image with trunk-revision 9434, but with that image the sixxs interface doesn't get an IPv6 address assigned.
I know I'm overlooking something e.g. wrong/missing parameter, or not compiled with a needed parameter introduced after freetz-1.2 which is needed for the 7270v3 but not for the 7390...just haven't found it yet.
Edit2 (30-12-2013: 14:45):
Tried a few other trunk-revisions:
(7270v3 int support added with revision 6607, Annex-A must be added somewhere after 6698. Jumped to trunk-revision 7000)
-trunk-revision 7000 works correct
-trunk-revision 7397 no web-interface, so could not test
-trunk-revision 7398 doesn't compile correctly
-trunk-revision 7404 compile ok, but ATM-PVC selection broken in AVM 74.05.04 image (also true for trunk-revision 7764)
-trunk-revision 7796 sixxs doesn't get IPv6 address
-trunk-revision 9434 sixxs doesn't get IPv6 address
-trunk-revision 11058 sixxs doesn't get IPv6 address
-trunk-revision 11440 sixxs doesn't get IPv6 address
vapep43913
