[Gelöst] Alle Freetz Einstellungen werden alle paar reboots resettet.
Tho³n³
13 Dez 2008
Moin zusammen,
alle paar reboots werden alle Einstellungen von Freetz resettet. (PW, Autostart, ....).
Meine Box/Firmware.
Firmware-Informationen
Boxtyp
    7140
AVM-Firmwareversion
    04.33
Sprache
    de
Kernelversion
    2.6.13.1-ohio (723) (gcc version 3.4.6)
Freetz-Version
    freetz-devel-6492
Erstellungsdatum
    04.02.2011 14:56:57
Ursprünglicher Dateiname
    7140_04.33freetz-devel-6492.de_20110204-145657.image
FREETZ-Konfiguration
Patches:
automount
freetzmount
Pakete:
downloader
fstyp
haserl
inetd
mod
modcgi
samba
Libraries:
ld_uClibc
libcrypt
libdl
libfreetz
libgcc_s
libm
libnsl
libpopt
libpthread
libresolv
librt
libuClibc
Ebefalls nutze ich noch Fritz!Load.
Die Logs nachdem es passiert ist.
/var/log/mod_load.log
Loading /var/flash/freetz ... failed.
Creating /var/flash/freetz ... done.
Loading users, groups and passwords ... done.
Loading hosts ... done.
Loading config ... done.
Loading modules ... done.
/var/log/mod.log
rc.mod version freetz-devel-6492
crond is disabled.
AVM telnetd is disabled.
Starting Freetz webinterface ... done.
swap is disabled.
downloader is disabled.
Starting inetd ... done.
Samba-smbd is disabled.
.config nachdem resettet wurde.
FREETZ_HAVE_DOT_CONFIG=y
FREETZ_AVM_VERSION_04_33=y
FREETZ_TYPE_FON_WLAN_7140=y
FREETZ_AVM_VERSION_STRING="04.33"
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7140"
FREETZ_INSTALL_BASE=y
FREETZ_PACKAGE_MOD=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_TARGET_REF_8MB=y
FREETZ_TARGET_REF="8mb"
FREETZ_KERNEL_REF_8MB=y
FREETZ_KERNEL_REF="8mb"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_LIBSSL=y
FREETZ_HAS_PHONE=y
FREETZ_HAS_USB_HOST=y
FREETZ_HAS_WLAN=y
FREETZ_LANG_DE=y
FREETZ_LANG_STRING="de"
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_PACKAGE_INETD=y
FREETZ_PACKAGE_SAMBA=y
FREETZ_PACKAGE_FSTYP=y
FREETZ_PACKAGE_DOWNLOADER=y
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
FREETZ_DL_KERNEL_SITE="@AVM/develper/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox-source-files-04.33.tar.bz2"
FREETZ_DL_KERNEL_SOURCE_MD5="99b6a701f9cd09319086c8655fced242"
FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7140/firmware/deutsch"
FREETZ_DL_SOURCE="fritz.box_fon_wlan_7140.annexb.30.04.33.image"
FREETZ_DL_SOURCE_MD5="08eeaf5239709d8582d730de2bcb10bf"
FREETZ_MOD_DL_NUM_SITES="5"
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
FREETZ_MOD_DL_SITE_4=""
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_GREY=y
FREETZ_STYLE="grey"
FREETZ_FAVICON_CUMA=y
FREETZ_FAVICON_STRING="cuma"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_TAR_OLDGNU_COMPATIBILITY=y
FREETZ_BUSYBOX_WGET=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libfreetz=y
FREETZ_LIB_libpopt=y
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
FREETZ_LIB_libuClibc=y
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_DOWNLOAD_TOOLCHAIN=y
FREETZ_KERNEL_VERSION_2_6_13_1=y
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_KERNEL_LAYOUT_OHIO=y
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_UCLIBC_0_9_28_BASED_BOX=y
FREETZ_KERNEL_COMPILER_GCC_3_4_6=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.18"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
FREETZ_TARGET_COMPILER_GCC_4_4_5=y
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_GCC_VERSION="4.4.5"
FREETZ_TARGET_BINUTILS_VERSION="2.21.51.0.4"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_TARGET_LFS=y
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
.config wenn ich wieder alle eingestellt habe.
FREETZ_HAS_LIBSSL=y
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
FREETZ_LANG_DE=y
FREETZ_JLEVEL=2
FREETZ_STYLE_GREY=y
FREETZ_STYLE="grey"
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_librt=y
FREETZ_TARGET_LFS=y
Benötigt ihr sonst noch irgendwelche angaben?
Aufgefallen ist mir
Ich hoffe ihr kennt eine Lösung, vielen Dank schon einmal.
Mfg tho³n³
Das ist das erste mal das auf der Box Freetz ist. Somit weiß ich nicht ob es daran liegt.
Ok, dann werde ich das spätestens am Weekend mal machen.
Nach dem Recover läuft die Box schon mal deutlich schneller. Mal sehen ob Sie immer noch resettet.
Wenn die Freetz Einstellungen beim Start nicht geladen werden können, dann wir mit den defaults gestartet. Die von dir gepostete Meldung deutet darauf hin. Ich kann mir jedoch nicht erklären warum das bei dir passiert, da ich mich nicht erinnern kann das Problem schon öfter gesehen zu haben.
Oliver
Die Box läuft nun wunderbar. Keine Ahnung was jetzt genau los war. Im Image kann es eher nicht geliegen haben, dies ist fast gleich, im neuen ist nur Samba nicht enthalten. Nach dem Recover lief die BOX, viel schneller, vllt war da irgendwo der Fehler.
Ich stell oben mal auf "Gelöst."
thx @ all
Okay. Ich mach dann mal hier zu.
Oliver
molto22
