Another reboot!!!
vasila
7 Mai 2008
Hello,
After the reset explained in http://www.ip-phone-forum.de/showthread.php?t=179446, i get another reboot of my fritz 7270 (FW 54.04.63freetz-devel-2670M).
I'm downloading at around 130kb with a P2P program, and when i try to make a call the box reboots!
Here is the log:
Jan  1 00:00:54 fritz user.warn kernel: [free_bootmem]
Jan  1 00:00:54 fritz user.warn kernel: [reserve_bootmem]
Jan  1 00:00:54 fritz user.debug kernel: On node 0 totalpages: 98240
Jan  1 00:00:54 fritz user.err kernel: [mem_map-hack]: reduce size from 3145728 524288 Bytes
Jan  1 00:00:54 fritz user.err kernel: [mem_map-hack]: move map base from 0x9431e000 to 0x9409e000
Jan  1 00:00:54 fritz user.debug kernel:   DMA zone: 767 pages used for memmap
Jan  1 00:00:54 fritz user.debug kernel:   DMA zone: 0 pages reserved
Jan  1 00:00:54 fritz user.debug kernel:   DMA zone: 97473 pages, LIFO batch:31
Jan  1 00:00:54 fritz user.debug kernel:   Normal zone: 0 pages used for memmap
Jan  1 00:00:54 fritz user.warn kernel: Built 1 zonelists.  Total pages: 97473
Jan  1 00:00:54 fritz user.notice kernel: Kernel command line:  console=ttyS0,38400n8r
Jan  1 00:00:54 fritz user.warn kernel: Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Jan  1 00:00:54 fritz user.warn kernel: Primary data cache 16kB, 4-way, linesize 16 bytes.
Jan  1 00:00:54 fritz user.info kernel: Synthesized TLB refill handler (20 instructions).
Jan  1 00:00:54 fritz user.info kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan  1 00:00:54 fritz user.info kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan  1 00:00:54 fritz user.info kernel: Synthesized TLB modify handler fastpath (31 instructions).
Jan  1 00:00:54 fritz user.warn kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Jan  1 00:00:54 fritz user.warn kernel: CPU frequency 360.00 MHz
Jan  1 00:00:54 fritz user.warn kernel: Using 180.000 MHz high precision timer.
Jan  1 00:00:54 fritz user.warn kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan  1 00:00:54 fritz user.warn kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan  1 00:00:54 fritz user.warn kernel: [free_all_bootmem]
Jan  1 00:00:54 fritz user.info kernel: Memory: 61056k/65280k available (2048k kernel code, 4096k reserved, 643k data, 136k init, 0k highmem)
Jan  1 00:00:54 fritz user.debug kernel: Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Jan  1 00:00:54 fritz user.warn kernel: Mount-cache hash table entries: 512
Jan  1 00:00:54 fritz user.warn kernel: Checking for 'wait' instruction...  available.
Jan  1 00:00:54 fritz user.info kernel: NET: Registered protocol family 16
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init]
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] flashsize = 0x01000000 Byte 16 MBytes
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[1] = 0x90020000,0x90F80000
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[2] = 0x90000000,0x90020000
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[3] = 0x90F80000,0x90FC0000
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[4] = 0x90FC0000,0x91000000
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
Jan  1 00:00:54 fritz user.err kernel: pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Jan  1 00:00:54 fritz user.err kernel: Master and Slave Enabled
Jan  1 00:00:54 fritz user.info kernel: pktsched: using high resolution timer
Jan  1 00:00:54 fritz user.info kernel: NET: Registered protocol family 2
Jan  1 00:00:54 fritz user.warn kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan  1 00:00:54 fritz user.warn kernel: TCP established hash table entries: 16384 (order: 4, 65536 bytes)
Jan  1 00:00:54 fritz user.warn kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Jan  1 00:00:54 fritz user.info kernel: TCP: Hash tables configured (established 16384 bind 8192)
Jan  1 00:00:54 fritz user.info kernel: TCP reno registered
Jan  1 00:00:54 fritz user.info kernel: squashfs: version 3.2 (2007/01/02) Phillip Lougher
Jan  1 00:00:54 fritz user.info kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Jan  1 00:00:54 fritz user.info kernel: io scheduler noop registered (default)
Jan  1 00:00:54 fritz user.info kernel: avm_net_trace: Up and running.
Jan  1 00:00:54 fritz user.warn kernel: [avm] configured: watchdog event debug led enable direct gpio
Jan  1 00:00:54 fritz user.warn kernel: AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct  2 2008 15:33:08)
Jan  1 00:00:54 fritz user.info kernel: Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports, IRQ sharing disabled
Jan  1 00:00:54 fritz user.info kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 15)
Jan  1 00:00:54 fritz user.info kernel:  is a UR8_UART
Jan  1 00:00:54 fritz user.err kernel: [cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
Jan  1 00:00:54 fritz user.info kernel: tun: Universal TUN/TAP device driver, 1.6
Jan  1 00:00:54 fritz user.info kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Jan  1 00:00:54 fritz user.notice kernel: physmap platform flash device: 01000001 at 10000000
Jan  1 00:00:54 fritz user.info kernel: physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
Jan  1 00:00:54 fritz user.warn kernel:  Amd/Fujitsu Extended Query Table at 0x0040
Jan  1 00:00:54 fritz user.warn kernel: physmap-flash.1: CFI does not contain boot bank location. Assuming top.
Jan  1 00:00:54 fritz user.notice kernel: number of CFI chips: 1
Jan  1 00:00:54 fritz user.notice kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jan  1 00:00:54 fritz user.notice kernel: RedBoot partition parsing not available
Jan  1 00:00:54 fritz user.warn kernel: [ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f5853c
Jan  1 00:00:54 fritz user.warn kernel: [ur8_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
Jan  1 00:00:54 fritz user.warn kernel: [ur8_jffs2_parser_function] magic 20031985 found @pos 0xae0000, size 4849664
Jan  1 00:00:54 fritz user.warn kernel: [ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f5853c
Jan  1 00:00:54 fritz user.warn kernel: [ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
Jan  1 00:00:54 fritz user.warn kernel: [ur8_squashfs_parser_function] try partition kernel (offset 0x20000 len 16121856 blocksize=20000)
Jan  1 00:00:54 fritz user.warn kernel: [ur8_squashfs_parser_function] magic found @pos 0x100700
Jan  1 00:00:54 fritz user.notice kernel: 6 find_squashfs partitions found on MTD device physmap-flash.1
Jan  1 00:00:54 fritz user.notice kernel: Creating 6 MTD partitions on "physmap-flash.1":
Jan  1 00:00:54 fritz user.notice kernel: 0x00100700-0x00f80000 : "rootfs"
Jan  1 00:00:54 fritz user.warn kernel: mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name rootfs
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] use rootfs
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
Jan  1 00:00:54 fritz user.notice kernel: 0x00020000-0x00100700 : "kernel"
Jan  1 00:00:54 fritz user.warn kernel: mtd: partition "kernel" doesn't end on an erase block -- force read-only
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name kernel
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] skip kernel
Jan  1 00:00:54 fritz user.notice kernel: 0x00000000-0x00020000 : "urlader"
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name urlader
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] skip urlader
Jan  1 00:00:54 fritz user.notice kernel: 0x00f80000-0x00fc0000 : "tffs (1)"
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name tffs (1)
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] skip tffs (1)
Jan  1 00:00:54 fritz user.notice kernel: 0x00fc0000-0x01000000 : "tffs (2)"
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name tffs (2)
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] skip tffs (2)
Jan  1 00:00:54 fritz user.notice kernel: 0x00ae0000-0x00f80000 : "jffs2"
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] name jffs2
Jan  1 00:00:54 fritz user.warn kernel: [ur8_mtd_add_notifier] skip jffs2
Jan  1 00:00:54 fritz user.warn kernel: Generic platform RAM MTD, (c) 2004 Simtec Electronics
Jan  1 00:00:54 fritz user.err kernel: mtd-ram mtd-ram.2: no memory resource specified
Jan  1 00:00:54 fritz user.err kernel: [ur8_ram_mtd_set_rw] PLATRAM_RO
Jan  1 00:00:54 fritz user.warn kernel: mtd-ram: probe of mtd-ram.2 failed with error -2
Jan  1 00:00:54 fritz user.notice kernel: CAPI Subsystem Rev 1.1.2.8
Jan  1 00:00:54 fritz user.info kernel: TCP cubic registered
Jan  1 00:00:54 fritz user.info kernel: mcfw: IGMPv3 fast forwarding
Jan  1 00:00:54 fritz user.info kernel: NET: Registered protocol family 17
Jan  1 00:00:54 fritz user.info kernel: NET: Registered protocol family 8
Jan  1 00:00:54 fritz user.info kernel: NET: Registered protocol family 20
Jan  1 00:00:54 fritz user.warn kernel: MUSB UR8 pdev active!
Jan  1 00:00:54 fritz user.err kernel: PCI_STATUS_SET: 40000
Jan  1 00:00:54 fritz user.err kernel: PCI_STATUS_CLR: 40000
Jan  1 00:00:54 fritz user.err kernel: PCI_HOST_INT_EN: 0
Jan  1 00:00:54 fritz user.err kernel: PCI_HOST_INT_CLR: 0
Jan  1 00:00:54 fritz user.err kernel: PCI_BE_INT_En: 0
Jan  1 00:00:54 fritz user.err kernel: PCI_BE_INT_CLR: 0
Jan  1 00:00:54 fritz user.err kernel: [pci_int_init] done
Jan  1 00:00:54 fritz user.warn kernel: TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
Jan  1 00:00:54 fritz user.info kernel: Time: MIPS clocksource has been installed.
Jan  1 00:00:54 fritz user.warn kernel:       mount on mtd3 and mtd4 (double buffering)
Jan  1 00:00:54 fritz user.info kernel: Adam2 environment variables API installed.
Jan  1 00:00:54 fritz user.info kernel: [avm_new] push_button_gpio=25 value=0 enabled
Jan  1 00:00:54 fritz user.warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan  1 00:00:54 fritz user.warn kernel: Freeing prom memory: 0kb freed
Jan  1 00:00:54 fritz user.info kernel: Freeing unused kernel memory: 136k freed
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 1 pos 0 name power
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 9 pos 1 name internet
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 27 pos 2 name festnetz
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 28 pos 3 name wlan
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 17 pos 4 name info
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 35 pos 5 name rot1
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 36 pos 6 name rot2
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 32 pos 7 name rot3
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 22 pos 8 name rot4
Jan  1 00:00:54 fritz user.warn kernel: [avm_led_gpio_bit_driver_init] gpio 21 pos 9 name rot5
Jan  1 00:00:54 fritz user.warn kernel: AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
Jan  1 00:00:54 fritz user.warn kernel: TFFS Name Table C
Jan  1 00:00:54 fritz user.warn kernel: Piglet_noemif: module license '
Jan  1 00:00:54 fritz user.warn kernel: (C) Copyright 2007 by AVM
Jan  1 00:00:54 fritz user.warn kernel: ' taintskernel.
Jan  1 00:00:54 fritz user.warn kernel: patch_dectfw: patch_adress: 6538 max_len: 22 with Version 2 Len: 16
Jan  1 00:00:54 fritz user.warn kernel: patch_dectfw: c0051000, datalen = 30588,
Jan  1 00:00:54 fritz user.warn kernel: ******************
Jan  1 00:00:54 fritz user.info kernel: *****************************************
Jan  1 00:00:54 fritz user.warn kernel: dect_file_process: upload of '/lib/modules/dectfw_secondlevel.hex' successfull
Jan  1 00:00:54 fritz user.info kernel: [avm_new]push_button_ctrl: gpio=23 value=1 enabled
Jan  1 00:00:54 fritz user.info kernel: [avm_new]push_button_ctrl:'Taster_4': enable=2 gpio=23 regaddr=00000000 button_type=0
Jan  1 00:00:54 fritz user.err kernel: [piglet]bitfile '/lib/modules/microvoip_isdn_top.bit'
Jan  1 00:00:54 fritz user.info kernel: [avm_new]push_button 'Taster_4', released: GPIO=23 presses=0 key=button_key_10
Jan  1 00:00:54 fritz user.err kernel: [piglet] Read 169291 bytes total from file
Jan  1 00:00:54 fritz user.warn kernel: [piglet]TDM: FS: 7990 Hz CLK:2047805 Hz
Jan  1 00:00:54 fritz user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Jan  1 00:00:54 fritz user.info kernel: loop: loaded (max 8 devices)
Jan  1 00:00:54 fritz user.warn kernel: [avm_debug]redirect kernel-messages (/dev/debug)
Jan  1 00:00:54 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:00:54 fritz user.err ctlmgr[685]: ctlmgr: plugin_install()
Jan  1 00:00:56 fritz authpriv.info dropbear[1326]: Running in background
Jan  1 00:00:56 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:00:56 fritz user.err ctlmgr[685]: ctlmgr: plugin_install()
Jan  1 00:01:01 fritz daemon.warn chronyd[1043]: Could not read address at line 15
Jan  1 00:01:01 fritz daemon.info chronyd[1043]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Jan  1 00:01:01 fritz daemon.info chronyd[1043]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jan  1 00:01:01 fritz daemon.info chronyd[1043]: Linux kernel major=2 minor=6 patch=19
Jan  1 00:01:01 fritz daemon.info chronyd[1043]: calculated_freq_scale=0.99902439 freq_scale=0.99902439
Jan  1 00:01:01 fritz daemon.err chronyd[1043]: Could not open /dev/rtc, No such file or directory
Jan  1 00:01:01 fritz daemon.err chronyd[1043]: Real time clock not supported on this operating system
Jan  1 00:01:02 fritz user.info telefon[1510]: websrv_init with support_stream(1)
[B]Jan  1 00:01:02 fritz user.err tr069discover[947]: discover_timeout_cb occured!, sig=0
Jan  1 00:01:02 fritz daemon.info chronyd[1043]: System's initial offset : 280005270.819417 seconds slow of true (step)
Nov 14 19:15:33 fritz user.err telefon[970]: set initial telefon time from linux time to 19:15 14.11 2008!
Nov 14 19:15:33 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed![/B]
Nov 14 19:15:34 fritz user.err usermand[939]: /var/flash/user.cfg: is empty
Nov 14 19:15:34 fritz user.err usermand[939]: load_config(user): factory default loaded
Nov 14 19:15:34 fritz daemon.warn chronyd[1043]: Could not send to 87.238.168.24 : Bad file descriptor
Nov 14 19:15:35 fritz daemon.warn chronyd[1043]: Could not send to 87.238.168.24 : Bad file descriptor
Nov 14 19:15:36 fritz daemon.warn chronyd[1043]: Could not send to 87.238.168.24 : Bad file descriptor
Nov 14 19:15:39 fritz user.err ctlmgr[685]: ctlmgr: plugin_install()
Nov 14 19:15:39 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov 14 19:15:41 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov 14 19:15:53 fritz user.err ctlmgr[685]: ctlmgr: plugin_install()
Nov 14 19:15:53 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov 14 19:15:55 fritz user.err ctlmgr[685]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Any ideia or help?
Thanks in advance
Best Regards
I can't see any hint why a reboot occurs in your log.
Regards,
Oliver
That is the new feature of AVM against P2P-networks...
MfG
I mark as bold the reboot.
Can someone help ?
I try with a FTP download and is the same :mad:
Another reboot!!!
Now, there is no P2P traffic... The computers in the network are off....
Jan  1 00:00:54 fritz user.warn kernel: [piglet]TDM: FS: 8000 Hz CLK:2047795 Hz
Jan  1 00:00:54 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:00:54 fritz user.err ctlmgr[690]: ctlmgr: plugin_install()
Jan  1 00:00:56 fritz authpriv.info dropbear[1313]: Running in background
Jan  1 00:00:56 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:00:56 fritz user.err ctlmgr[690]: ctlmgr: plugin_install()
Jan  1 00:00:58 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:01:03 fritz user.info telefon[1518]: websrv_init with support_stream(1)
Jan  1 00:01:03 fritz user.err tr069discover[948]: discover_timeout_cb occured!, sig=0
Jan  1 00:01:04 fritz daemon.warn chronyd[1035]: Could not read address at line 15
Jan  1 00:01:04 fritz daemon.info chronyd[1035]: Initial txc.tick=10000 txc.freq=0 (0.00000000) txc.offset=0 => hz=100 shift_hz=7
Jan  1 00:01:04 fritz daemon.info chronyd[1035]: set_config_hz=0 hz=100 shift_hz=7 basic_freq_scale=1.28000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000
Jan  1 00:01:04 fritz daemon.info chronyd[1035]: Linux kernel major=2 minor=6 patch=19
Jan  1 00:01:04 fritz daemon.info chronyd[1035]: calculated_freq_scale=0.99902439 freq_scale=0.99902439
Jan  1 00:01:04 fritz daemon.err chronyd[1035]: Could not open /dev/rtc, No such file or directory
Jan  1 00:01:04 fritz daemon.err chronyd[1035]: Real time clock not supported on this operating system
Jan  1 00:01:04 fritz user.err ctlmgr[690]: ctlmgr: plugin_install()
[B]Jan  1 00:01:04 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Jan  1 00:01:05 fritz daemon.info chronyd[1035]: System's initial offset : 280316828.555002 seconds slow of true (step)
Nov 18 09:48:14 fritz user.err telefon[985]: set initial telefon time from linux time to 9:48 18.11 2008!
Nov 18 09:48:14 fritz user.err usermand[939]: /var/flash/user.cfg: is empty
Nov 18 09:48:14 fritz user.err usermand[939]: load_config(user): factory default loaded
Nov 18 09:48:14 fritz daemon.warn chronyd[1035]: Could not send to 131.211.84.189 : Bad file descriptor[/B]
Nov 18 09:48:15 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov 18 09:48:15 fritz daemon.warn chronyd[1035]: Could not send to 131.211.84.189 : Bad file descriptor
Nov 18 09:48:17 fritz daemon.warn chronyd[1035]: Could not send to 131.211.84.189 : Bad file descriptor
Nov 18 09:48:27 fritz user.err ctlmgr[690]: ctlmgr: plugin_install()
Nov 18 09:48:27 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov 18 09:48:29 fritz user.err ctlmgr[690]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
@RalfFriedl:
Because the time for the reboot is correct....
Can anyone help me please ?
Best regards
Your log shows the startup of the box after the reboot. So it contains no information about the cause for the reboot.
I think you marked these lines because the time changes there. But the reason for this that the box made its internet connection and got the right time from a time server.
these entrys in your log are not showing any reason for a unforeseen reboot
you better should take a look on your memory usage/cpu usage...maybe there are some reasons like a hanging process or something else...
figo12
