[Gelöst] Asterisk 1.8.11 Anbindung an FB 7390 Ankommendes Gespräch Klingelt nicht.
marc_nic
20 Apr 2009
ich habe AsteriskNow unter VMWare installiert, Dectgeräte der FB an Asterisk angemeldet. Trunk an der FB angemeldet.
Outbound klappt, leider bekomme ich keinen Klingelton rein, bzw. das Gespräch kommt nicht rein.
Inbound hört auf alles.
Hat jemand eine Idee für mich?
Vielen Dank und Gruß aus Lüdenscheid
Marc
[2012-05-22 12:44:18] WARNING[30020] chan_iax2.c: Error opening firmware directory '/var/lib/asterisk/firmware/iax': No such file or directory
[2012-05-22 12:44:18] NOTICE[30020] iax2-provision.c: No IAX provisioning configuration found, IAX provisioning disabled.
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'app_playback.so' (Sound File Playback Application)
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'res_phoneprov.so' (HTTP Phone Provisioning)
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_general_additional.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_general_custom.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_nat.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_registrations_custom.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_registrations.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_custom.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_additional.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[30020] config.c: == Parsing '/etc/asterisk/sip_custom_post.conf': [2012-05-22 12:44:18] VERBOSE[30020] config.c: == Found
[2012-05-22 12:44:18] WARNING[30020] res_phoneprov.c: Unable to load users.conf
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'chan_sip.so' (Session Initiation Protocol (SIP))
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'codec_dahdi.so' (Generic DAHDI Transcoder Codec Translator)
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'codec_gsm.so' (GSM Coder/Decoder)
[2012-05-22 12:44:18] VERBOSE[30020] loader.c: -- Reloading module 'cdr_custom.so' (Customizable Comma Separated Values CDR Backend)
[2012-05-22 12:44:18] ERROR[30020] cdr_custom.c: Unable to load cdr_custom.conf. Not logging custom CSV CDRs.
[2012-05-22 12:44:18] VERBOSE[15675] chan_sip.c: Reloading SIP
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_general_additional.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_general_custom.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_nat.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_registrations_custom.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_registrations.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_custom.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_additional.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_custom_post.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] pbx.c: -- Added extension 'auto_hint_730' priority -1 to from-internal
[2012-05-22 12:44:18] VERBOSE[15675] pbx.c: -- Added extension 'auto_hint_720' priority -1 to from-internal
[2012-05-22 12:44:18] VERBOSE[15675] pbx.c: -- Added extension 'auto_hint_721' priority -1 to from-internal
[2012-05-22 12:44:18] VERBOSE[15675] pbx.c: -- Added extension 'auto_hint_725' priority -1 to from-sip-external
[2012-05-22 12:44:18] VERBOSE[15675] pbx.c: -- Added extension 'auto_hint_726' priority -1 to from-internal
[2012-05-22 12:44:18] WARNING[15675] chan_sip.c: No valid transports available, falling back to 'udp'.
[2012-05-22 12:44:18] VERBOSE[15675] netsock2.c: == Using SIP TOS bits 96
[2012-05-22 12:44:18] VERBOSE[15675] netsock2.c: == Using SIP CoS mark 4
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_notify.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_notify_custom.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:18] VERBOSE[15675] config.c: == Parsing '/etc/asterisk/sip_notify_additional.conf': [2012-05-22 12:44:18] VERBOSE[15675] config.c: == Found
[2012-05-22 12:44:28] VERBOSE[15675] netsock2.c: == Using SIP RTP TOS bits 184
[2012-05-22 12:44:28] VERBOSE[15675] netsock2.c: == Using SIP RTP CoS mark 5
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: -- Executing [s@from-internal:1] Macro("SIP/726-00000110", "hangupcall") in new stack
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/726-00000110", "1?theend") in new stack
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: -- Goto (macro-hangupcall,s,3)
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: -- Executing [s@macro-hangupcall:3] Hangup("SIP/726-00000110", "") in new stack
[2012-05-22 12:44:28] VERBOSE[30031] app_macro.c: == Spawn extension (macro-hangupcall, s, 3) exited non-zero on 'SIP/726-00000110' in macro 'hangupcall'
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: == Spawn extension (from-internal, s, 1) exited non-zero on 'SIP/726-00000110'
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/726-00000110", "") in new stack
[2012-05-22 12:44:28] VERBOSE[30031] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/726-00000110'
[2012-05-22 12:44:42] VERBOSE[15675] netsock2.c: == Using SIP RTP TOS bits 184
[2012-05-22 12:44:42] VERBOSE[15675] netsock2.c: == Using SIP RTP CoS mark 5
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: -- Executing [s@from-internal:1] Macro("SIP/726-00000111", "hangupcall") in new stack
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/726-00000111", "1?theend") in new stack
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: -- Goto (macro-hangupcall,s,3)
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: -- Executing [s@macro-hangupcall:3] Hangup("SIP/726-00000111", "") in new stack
[2012-05-22 12:44:42] VERBOSE[30032] app_macro.c: == Spawn extension (macro-hangupcall, s, 3) exited non-zero on 'SIP/726-00000111' in macro 'hangupcall'
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: == Spawn extension (from-internal, s, 1) exited non-zero on 'SIP/726-00000111'
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/726-00000111", "") in new stack
[2012-05-22 12:44:42] VERBOSE[30032] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/726-00000111'
[2012-05-22 12:45:19] VERBOSE[15675] netsock2.c: == Using SIP RTP TOS bits 184
[2012-05-22 12:45:19] VERBOSE[15675] netsock2.c: == Using SIP RTP CoS mark 5
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: -- Executing [s@from-internal:1] Macro("SIP/726-00000112", "hangupcall") in new stack
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/726-00000112", "1?theend") in new stack
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: -- Goto (macro-hangupcall,s,3)
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: -- Executing [s@macro-hangupcall:3] Hangup("SIP/726-00000112", "") in new stack
[2012-05-22 12:45:19] VERBOSE[30033] app_macro.c: == Spawn extension (macro-hangupcall, s, 3) exited non-zero on 'SIP/726-00000112' in macro 'hangupcall'
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: == Spawn extension (from-internal, s, 1) exited non-zero on 'SIP/726-00000112'
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/726-00000112", "") in new stack
[2012-05-22 12:45:19] VERBOSE[30033] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/726-00000112'
Schau mal ob Du irgend eine Einstellung für die Authentifizierung ankommender Anrufe findest, im echten Leben heißt der Parameter insecure.
Ansonsten zeig bitte Screenshots von den Einstellungen.
Vielen Dank für den Tip, leider finde ich unter den Einstellungen kein Insecure. Anbei schicke ich die Screenshots meiner Einstellungen.
Vielen Dank, Gruß Marc
[Beitrag 2:]
Ich habe da noch etwas gefunden:
Asterisk an die FB angemeldet, raustelefonieren klappt.
Jetzt habe ich versucht, über die FB Asterisk zu erreichen Durchwahl: 627 und bekomme folgende Fehler:
24.05.12
15:51:53
Internettelefonie mit [email protected] über 192.168.1.11 war nicht erfolgreich. Ursache: Decline (603)
24.05.12
15:51:53
Internettelefonie mit [email protected]:5060 über 192.168.1.171:5060 war nicht erfolgreich. Ursache: Declined (603)
Könnte hier der Fehler liegen?
Vielen Dank für Eure Hilfe
Gruß aus Lüdenscheid Marc
Ha, Updates eingespielt und ankommende Anrufe werden angezeigt;-)
figo12
