Asterisk als CISCO Voicemailbox
dubsch
31 Dez 2004
wir setzten eine CISCO VoIP Telefonanlage ein und haben nun eine Asterisk Installation für Anrufbeantworter und Konferenzräume aufgesetzt. Unser Asteriskserver hat also keine ISDN Karten o.ä. installiert. Nun erhalten wir immer foldegnde Fehler im Logfile und ich finde keine Lösung sie zu beseitigen. Kann mir jemand helfen?
Hier der Auszug aus dem Log File:
[Jul 17 15:32:23] WARNING[10238] res_smdi.c: No SMDI interfaces were specified to listen on, not starting SDMI listener.
[Jul 17 15:32:23] ERROR[10238] res_config_pgsql.c: Postgresql RealTime: Failed to connect database server asterisk on 127.0.0.1. Check debug for more info.
[Jul 17 15:32:23] WARNING[10238] res_config_pgsql.c: Postgresql RealTime: Couldn't establish connection. Check debug.
[Jul 17 15:32:23] NOTICE[10238] indications.c: Removed default indication country 'de'
[Jul 17 15:32:23] NOTICE[10238] res_odbc.c: Adding ENV var: INFORMIXSERVER=my_special_database
[Jul 17 15:32:23] NOTICE[10238] res_odbc.c: Adding ENV var: INFORMIXDIR=/opt/informix
[Jul 17 15:32:23] NOTICE[10238] app_playback.c: Reloading say.conf
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: Starting AEL load process.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: calculated config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] NOTICE[10238] pbx_ael.c: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:32:23] WARNING[10238] chan_misdn.c: chan_misdn is not initialized properly, still reloading ?
[Jul 17 15:32:54] WARNING[10368] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:33:02] WARNING[10369] app_voicemail.c: Couldn't read username
[Jul 17 15:36:23] WARNING[10771] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:36:32] WARNING[10781] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:40:46] WARNING[10943] app_voicemail.c: Couldn't read username
[Jul 17 15:40:58] WARNING[10948] app_voicemail.c: Unable to read password
[Jul 17 15:46:34] WARNING[11055] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:47:53] NOTICE[11566] cdr.c: CDR simple logging enabled.
[Jul 17 15:47:53] WARNING[11566] res_smdi.c: No SMDI interfaces were specified to listen on, not starting SDMI listener.
[Jul 17 15:47:53] ERROR[11566] res_config_pgsql.c: Postgresql RealTime: Failed to connect database server asterisk on 127.0.0.1. Check debug for more info.
[Jul 17 15:47:53] WARNING[11566] res_config_pgsql.c: Postgresql RealTime: Couldn't establish connection. Check debug.
[Jul 17 15:47:53] NOTICE[11566] indications.c: Removed default indication country 'de'
[Jul 17 15:47:53] NOTICE[11566] res_odbc.c: Adding ENV var: INFORMIXSERVER=my_special_database
[Jul 17 15:47:53] NOTICE[11566] res_odbc.c: Adding ENV var: INFORMIXDIR=/opt/informix
[Jul 17 15:47:53] NOTICE[11566] app_playback.c: Reloading say.conf
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: Starting AEL load process.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: calculated config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] NOTICE[11566] pbx_ael.c: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
[Jul 17 15:47:53] WARNING[11566] chan_misdn.c: chan_misdn is not initialized properly, still reloading ?
[Jul 17 15:51:54] WARNING[11603] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:54:36] WARNING[11615] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:56:37] WARNING[11616] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:56:40] WARNING[11617] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 15:57:05] WARNING[11617] pbx.c: Channel 'SIP/10.42.34.61-b5803788' sent into invalid extension 's' in context 'default', but no invalid handler
[Jul 17 16:00:32] WARNING[11675] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 16:01:46] WARNING[11690] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 16:02:09] WARNING[11690] pbx.c: Channel 'SIP/10.42.34.61-b5803788' sent into invalid extension 's' in context 'default', but no invalid handler
[Jul 17 16:05:02] WARNING[11711] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 16:09:13] WARNING[11729] file.c: Failed to write frame
[Jul 17 16:09:46] WARNING[11734] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 16:10:08] WARNING[11734] pbx.c: Channel 'SIP/10.42.34.61-b5814aa8' sent into invalid extension 's' in context 'default', but no invalid handler
[Jul 17 16:11:57] WARNING[11753] app_dial.c: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
[Jul 17 16:12:53] WARNING[11748] file.c: Failed to write frame
[Jul 17 16:23:52] WARNING[11782] app_voicemail.c: Couldn't read username
[Jul 17 16:26:13] WARNING[11787] app_voicemail.c: Couldn't read username
Etwas mehr Sorgfalt, z.B. die Benutzung von
-Tags, könnte die Bereitschaft, Dir zu antworten, erhöhen...
Sorry,
ich kenne mich in in den Tags nicht so aus - ich hoffe ich habe die Änderung korekt durch geführt
Und was ist /genau/ Dein Problem? Mal von den Fehlermeldungen abgesehen.
Weder NOTICE noch WARNING sind Fehlermeldungen. Mach einfach "set verbose 3" im Asterisk CLI und gut ist.
Evtl. willst Du noch in /etc/modules.conf dafür sorgen dass realtime nicht geladen wird, dann verschwinden auch die zwei verbliebenen Fehlermeldungen mit Postgres. Realtime benötigst Du nicht.
IchBinEsDoch
