Asterisk And Fritz
kandy
19 Feb 2005
I configured asterisk in order to work with my fritz but I receive
-- Got SIP response 489 "Bad Event" back from 192.168.0.15
sip.conf
[715]
type=friend
username=715
secret=sipxxxxxx
host=dynamic
context=from-sip
mailbox=715
auth=md5
nat=yes
reinvite=no
canreinvite=no
qualify=yes
disallow=all
allow=alaw
allow=ulaw
Apr 2 14:15:10 WARNING[22016]: chan_sip.c:2764 process_sdp: No compatible codecs!
Apr 2 14:15:10 NOTICE[22016]: chan_sip.c:7295 handle_request: Unable to create/find channel
if I receive a call this is the error
-- Got SIP response 488 "Not Acceptable Here" back from 192.168.0.15
seems as if there is an audio codec mismatch happening here. What way should the call be routed? I assume the Fritz is the local sip user 715 here. But what is the direction of your call?
Your sip.conf does have a "[general]" section?
Are you sure about the "auth=md5" ? I don't know what *-version you're using but afaik in the sip.conf there's still only "md5secret=<md5-hash>" a valid option. And if so, you don't need "secret=..."
smileysun
