Asterisk auf 7140 39.04.47: keine audio (no audio) [eng]
ramik
3 Mai 2007
[i started to learn german reading this forum, but better english]
After i updated to firmware 39.04.47 on my 7140 annex A english version, the asterisk doesn't work anymore as expected, it run, i can hear audio of others, but they don't hear me, also the moh (Music-On-Hold) test doesn't work anymore. the echo test (80) i hear the other part giving instructions, but i don't hear my self...
is there something new in the new firmware that need to be fixed to make asterisk work again?
Did you try to do a complete clean re-install of Asterisk, after your upgrade ?
Not sure, if this is going to resolve the issue but it'll at least exclude the Asterisk Installation as a source of the problem.
Regards
dynamic
i tried a reinstall, and for a moment it seemed to have worked, but only locally, when i'm on the same network.
when i connect from work to my home network with openVPN, and connect the sjPhone sip client to home, it doesn't work as before, one-way audio.
But it seems that i solved it by using IAX client, connects and echo test works.
@ramik
Why do you use VPN for connecting via the internet.
You could do without VPN and directly connect through Port 5060 ( or any other Port, that you have forwarded and have your Asterisk listening on ) to your Asterisk.
The default configuration files include an example, as to how this could look like.
Regards
dynamic
i tried to do so when i was trying to connect with sip, but i was unable to make it work, as the remote computer is also behind a nat and it might complicate things.
anyway, it is working with vpn, ok there will be an overhead of data to transfer, and time to encrype/decrypt packages, but it is enough for my needs, and secure :)
@ramik
Good to hear, that everything is working now.
What was the problem and what was done to resolve ... may be of interest for others in the forum, too ;-) ?
btw. connecting without VPN should work, too, but VPN for sure is much safer :-)
SignalCheck97
