asterisk fehler!?
hjuhnke
7 Mrz 2010
hallo habe mir auf meinem ubuntu server asterisk installiert.
habe die conf dateien nach der kurs beschreiben bearbeitet.
in der cli kommt nun folgende fehlermeldung und die softphones auf den pcs können sich nicht gegenseitig anrufen.
root@server:~# asterisk -r
Asterisk 1.4.17~dfsg-2ubuntu1.1, Copyright (C) 1999 - 2007 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
This package has been modified for the Debian GNU/Linux distribution
Please report all bugs to http://bugs.debian.org/asterisk
Connected to Asterisk 1.4.17~dfsg-2ubuntu1.1 currently running on server (pid = 4959)
server*CLI> reload
[Mar 20 13:30:31] ERROR[5055]: config.c:748 process_text_line: *********************************************************
[Mar 20 13:30:31] ERROR[5055]: config.c:749 process_text_line: *********** YOU SHOULD REALLY READ THIS ERROR ***********
[Mar 20 13:30:31] ERROR[5055]: config.c:750 process_text_line: Future versions of Asterisk will treat a #include of a file that does not exist as an error, and will fail to load that configuration file.  Please ensure that the file 'manager.d/*.conf' exists, even if it is empty.
[Mar 20 13:30:31] ERROR[5055]: config.c:754 process_text_line: *********** YOU SHOULD REALLY READ THIS ERROR ***********
[Mar 20 13:30:31] ERROR[5055]: config.c:755 process_text_line: *********************************************************
[Mar 20 13:30:31] WARNING[5055]: res_smdi.c:746 reload: No SMDI interfaces were specified to listen on, not starting SDMI listener.
[Mar 20 13:30:31] WARNING[5055]: chan_zap.c:13004 process_zap: Ignoring switchtype
[Mar 20 13:30:31] WARNING[5055]: chan_zap.c:13004 process_zap: Ignoring signalling
[Mar 20 13:30:31] WARNING[5055]: chan_zap.c:13004 process_zap: Ignoring rxwink
[Mar 20 13:30:31] WARNING[4983]: chan_mgcp.c:4201 reload_config: Unable to get our IP address, MGCP disabled
[Mar 20 13:30:31] WARNING[5055]: pbx_dundi.c:4404 set_config: Unable to look up host 'server'
server*CLI>
wo ist da der fehler?
vielen dank!!!
Hi hjuhnke!
Bitte benutze doch deine SHIFT-Taste damit der Text bessr lesbar ist.
Die Softphones auf den PC sollen doch sicher über das SIP-Protokoll kommunizieren. Die Fehlermeldungen und Warnungen auf deinem CLI beziehen sich jedoch nicht daruf. Was steht denn in der sip.conf und der extensions.conf zu den Softphones und den PC?
Der Fehler, der als Error in der CLI angezeigt wird, wird Dir dort auch wortwörtlich beschrieben.
Wie ilmtuelp schon sagte hat das aber wahrscheinlich nichts mit Deinen Softphones zu tun. Interessant wäre auch noch die CLI Ausgabe eines Wählversuchs.
Rentier
Callendaar
