Asterisk + Hylafax: versenden funktioniert nicht
moodsx
6 Nov 2006
Hallo Community,
bin gerade dabei mir den Hylafax + iaxmodem auf meinem Asterisk einzurichten. Das empfangen von Faxen funktioniert bereits, beim versenden gibt mir das Log vom Hylafax folgendes aus:
Apr 05 13:50:24.06: [13089]: SESSION BEGIN 000000040 +49(RUFNUMMER)
Apr 05 13:50:24.06: [13089]: HylaFAX (tm) Version 5.1.12
Apr 05 13:50:24.06: [13089]: CallID: '(RUFNUMMER)' '(RUFNUMMER)' '<NONE>' '1796'
Apr 05 13:50:24.06: [13089]: <-- [4:ATA\r]
Apr 05 13:50:27.78: [13089]: --> [7:CONNECT]
Apr 05 13:50:27.78: [13089]: ANSWER: FAX CONNECTION  DEVICE '/dev/ttyIAX0'
Apr 05 13:50:27.79: [13089]: RECV FAX: begin
Apr 05 13:50:27.79: [13089]: <-- data [33]
Apr 05 13:50:27.79: [13089]: <-- data [2]
Apr 05 13:50:28.75: [13089]: --> [7:CONNECT]
Apr 05 13:50:28.75: [13089]: <-- data [23]
Apr 05 13:50:28.75: [13089]: <-- data [2]
Apr 05 13:50:29.49: [13089]: --> [7:CONNECT]
Apr 05 13:50:29.49: [13089]: <-- data [13]
Apr 05 13:50:29.49: [13089]: <-- data [2]
Apr 05 13:50:30.07: [13089]: --> [2:OK]
Apr 05 13:50:30.07: [13089]: <-- [9:AT+FRH=3\r]
Apr 05 13:50:37.07: [13089]: --> [0:]
Apr 05 13:50:37.07: [13089]: MODEM <Empty line>
Apr 05 13:50:37.07: [13089]: <-- data [1]
Apr 05 13:50:37.08: [13089]: --> [2:OK]
Apr 05 13:50:37.08: [13089]: <-- [9:AT+FRS=7\r]
Apr 05 13:50:37.09: [13089]: --> [2:OK]
Apr 05 13:50:37.09: [13089]: <-- [9:AT+FTH=3\r]
Apr 05 13:50:37.10: [13089]: --> [7:CONNECT]
Apr 05 13:50:37.10: [13089]: <-- data [33]
Apr 05 13:50:37.11: [13089]: <-- data [2]
Apr 05 13:50:38.90: [13089]: --> [7:CONNECT]
Apr 05 13:50:38.90: [13089]: <-- data [23]
Apr 05 13:50:38.90: [13089]: <-- data [2]
Apr 05 13:50:39.64: [13089]: --> [7:CONNECT]
Apr 05 13:50:39.64: [13089]: <-- data [13]
Apr 05 13:50:39.64: [13089]: <-- data [2]
Apr 05 13:50:40.25: [13089]: --> [2:OK]
Apr 05 13:50:40.25: [13089]: <-- [9:AT+FRH=3\r]
Apr 05 13:50:47.26: [13089]: --> [0:]
Apr 05 13:50:47.26: [13089]: MODEM <Empty line>
Apr 05 13:50:47.26: [13089]: <-- data [1]
Apr 05 13:50:47.26: [13089]: --> [2:OK]
Apr 05 13:50:47.26: [13089]: <-- [9:AT+FRS=7\r]
Apr 05 13:50:47.28: [13089]: --> [2:OK]
Apr 05 13:50:47.28: [13089]: <-- [9:AT+FTH=3\r]
Apr 05 13:50:47.29: [13089]: --> [7:CONNECT]
Apr 05 13:50:47.29: [13089]: <-- data [33]
Apr 05 13:50:47.29: [13089]: <-- data [2]
Apr 05 13:50:49.09: [13089]: --> [7:CONNECT]
Apr 05 13:50:49.09: [13089]: <-- data [23]
Apr 05 13:50:49.09: [13089]: <-- data [2]
Apr 05 13:50:49.83: [13089]: --> [7:CONNECT]
Apr 05 13:50:49.83: [13089]: <-- data [13]
Apr 05 13:50:49.83: [13089]: <-- data [2]
Apr 05 13:50:50.43: [13089]: --> [2:OK]
Apr 05 13:50:50.43: [13089]: <-- [9:AT+FRH=3\r]
Apr 05 13:50:57.43: [13089]: --> [0:]
Apr 05 13:50:57.43: [13089]: MODEM <Empty line>
Apr 05 13:50:57.43: [13089]: <-- data [1]
Apr 05 13:50:57.45: [13089]: --> [2:OK]
Apr 05 13:50:57.45: [13089]: <-- [9:AT+FRS=7\r]
Apr 05 13:50:57.47: [13089]: --> [2:OK]
Apr 05 13:50:57.47: [13089]: <-- [9:AT+FTH=3\r]
Apr 05 13:50:57.49: [13089]: --> [7:CONNECT]
Apr 05 13:50:57.49: [13089]: <-- data [33]
Apr 05 13:50:57.49: [13089]: <-- data [2]
Apr 05 13:50:59.29: [13089]: --> [7:CONNECT]
Apr 05 13:50:59.29: [13089]: <-- data [23]
Apr 05 13:50:59.29: [13089]: <-- data [2]
Apr 05 13:51:00.03: [13089]: --> [7:CONNECT]
Apr 05 13:51:00.03: [13089]: <-- data [13]
Apr 05 13:51:00.03: [13089]: <-- data [2]
Apr 05 13:51:00.63: [13089]: --> [2:OK]
Apr 05 13:51:00.63: [13089]: <-- [9:AT+FRH=3\r]
Apr 05 13:51:07.63: [13089]: --> [0:]
Apr 05 13:51:07.63: [13089]: MODEM <Empty line>
Apr 05 13:51:07.63: [13089]: <-- data [1]
Apr 05 13:51:07.65: [13089]: --> [2:OK]
Apr 05 13:51:07.65: [13089]: RECV FAX: No sender protocol (T.30 T1 timeout) {E102}
Apr 05 13:51:07.65: [13089]: RECV FAX: end
Apr 05 13:51:07.65: [13089]: No sender protocol (T.30 T1 timeout) {E102}
Apr 05 13:51:07.65: [13089]: SESSION END
Hat da jemand eine Idee was fehlt oder was ich vergessen habe?
Danke für Eure Hilfe
MfG
du könntest mal ein paar Infos mitgeben, worüber du versendest. Entsprechende Teile deines Dialplanes wären auch nicht schlecht. was wird auf der * CLI während des Versendens ausgegeben?
IchBinEsDoch
