asterisk kernel logs ?
pinguin2008
10 Mrz 2008
tail -f /var/log/messages
dann bekomme ich ständig diese Ausgabe:
Dec  8 08:14:12 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45331 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:13 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45333 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:13 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45337 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:14 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45343 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:15 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45353 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:16 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45357 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:17 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45362 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:17 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45367 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:18 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45374 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:19 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45381 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:20 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45389 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:20 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45391 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:21 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45393 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:22 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45394 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:23 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45396 PROTO=UDP SPT=137 DPT=137 LEN=58
Dec  8 08:14:23 asterisk kernel: RULE 16 -- DENY IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:11:f6:80:97:c9:08:00 SRC=192.168.1.26 DST=192.168.1.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=45398 PROTO=UDP SPT=137 DPT=137 LEN=58
Edit Guard-X: Code-Tags eingefügt!
Was soll das heissen ? Irgendas mit Iptable aber was genau ? Mein Cent OS Rechner macht lahm. bitte um Hilfe !
Das hat aber nu wirklich nüscht mit Asterisk zu tun. Wenn Du die 192.168.1.26 abschaltest, sind die Fehler weg, stümmts? UDP/137 Netbios.
Callendaar
