[Problem] Asterisk lädt Module nicht
daschacka
14 Jan 2006
ich habe ein Problem und zwar habe ich Asterisk auf meinem Router installiert. Sonst habe ich nur noch chan_dongle als Modul zusätzlich installiert.
Meine modules.conf sieht so aus:
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
; Any modules that need to be loaded before the Asterisk core has been
; initialized (just after the logger has been initialized) can be loaded
; using 'preload'. This will frequently be needed if you wish to map all
; module configuration files into Realtime storage, since the Realtime
; driver will need to be loaded before the modules using those configuration
; files are initialized.
; An example of loading ODBC support would be:
;preload => res_odbc.so
;preload => res_config_odbc.so
; Uncomment the following if you wish to use the Speech Recognition API
;preload => res_speech.so
; If you want Asterisk to fail if a module does not load, then use
; the "require" keyword. Asterisk will exit with a status code of 2
; if a required module does not load.
; require = chan_sip.so
; If you want you can combine with preload
; preload-require = res_odbc.so
; If you want, load the GTK console right away.
noload => pbx_gtkconsole.so
;load => pbx_gtkconsole.so
; Load one of: chan_oss, alsa, or console (portaudio).
; By default, load chan_oss only (automatically).
noload => chan_alsa.so
;noload => chan_oss.so
noload => chan_console.so
Jedoch bekomme ich beim starten folgendes Asterisk Log:
[Mar 25 13:13:46] WARNING[2437] db.c: Unable to open Asterisk database '/var/lib/asterisk/astdb': No such file or directory
[Mar 25 13:13:46] WARNING[2437] ccss.c: Could not find valid ccss.conf file. Using cc_max_requests default
[Mar 25 13:13:46] NOTICE[2437] loader.c: 20 modules will be loaded.
[Mar 25 13:13:46] WARNING[2437] loader.c: Error loading module 'chan_dongle.so': /usr/lib/asterisk/modules/chan_dongle.so: undefined symbol: ast_unregister_file_version
[Mar 25 13:13:46] WARNING[2437] loader.c: Module 'chan_dongle.so' did not register itself during load
[Mar 25 13:13:46] WARNING[2437] loader.c: Module 'chan_dongle.so' could not be loaded.
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: No valid transports available, falling back to 'udp'.
[Mar 25 13:13:46] ERROR[2437] netsock2.c: getaddrinfo("OpenWrt", "(null)", ...): Name or service not known
[Mar 25 13:13:46] WARNING[2437] acl.c: Unable to lookup 'OpenWrt'
[Mar 25 13:13:46] NOTICE[2437] chan_sip.c: The 'username' field for sip peers has been deprecated in favor of the term 'defaultuser'
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: Unknown insecure mode 'very' on line 16
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: !!! PLEASE NOTE: Setting 'nat' for a peer/user that differs from the  global setting can make
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: !!! the name of that peer/user discoverable by an attacker. Replies for non-existent peers/users
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: !!! will be sent to a different port than replies for an existing peer/user. If at all possible,
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: !!! use the global 'nat' setting and do not set 'nat' per peer/user.
[Mar 25 13:13:46] WARNING[2437] chan_sip.c: !!! (config category='1450938' global force_rport='Yes' peer/user force_rport='No')
Telefonieren geht zwar aber den chan_dongle kann ich nicht nutzen. Also er registriert sich nicht. Auch nicht manuell mit
CLI>module load chan_dongle.so
CLI>module unload chan_dongle.so
CLI>module reload chan_dongle.so
Kann mir jemand bitte helfen, Es wäre echt nett.
Mein System: NAS mit OpenWRT Port drauf und Asterisk 1.8.10.0
rmh
Aktives Mitglied
6 Jul 2008
Hast du mal einen Blick in /usr/lib/asterisk/modules geworfen? Sind alle Module, die du laden möchtest dort vorhanden?
R.
daschacka
14 Jan 2006
Ja die sind da:
[email protected]:/usr/lib/asterisk/modules# ls
app_dial.so           codec_ulaw.so         func_strings.so
app_echo.so           format_gsm.so         func_timeout.so
app_macro.so          format_pcm.so         pbx_config.so
app_playback.so       format_wav.so         res_rtp_asterisk.so
chan_dongle.so        format_wav_gsm.so     res_rtp_multicast.so
chan_sip.so           func_callerid.so
codec_gsm.so          func_logic.so
Im Grunde genommen benötige ich jetzt nur chan_dongle, aber ich denke mal der Rest ist Standard? Weil ich zusätzlich nichts installiert habe.
waldoo
Aktives Mitglied
28 Jan 2006
sorry überlesen, welche asterisk version du im Einsatz hast.
Ich vermute, dass asterisk und chan_dongle nicht zusammen passen
auf welche quellen greifst du zurück?
Und bitte schreibe noch mal ganz klar, wo du das zum laufen bekommen willst. Zum einen schreibst du Router und weiter unten schreibst du NAS.
Da ist wohl eine Zusatzinfo nötig.
daschacka
14 Jan 2006
Es ist ein NAS mit einem OpenWRT Port. Der Programmierer des Ports hat die Packages bereitgestellt.
Also asterisk18_1.8.10.0 und asterisk18-chan-dongle_1.1.r10
waldoo
Aktives Mitglied
28 Jan 2006
kannst du auch eine quelle angeben, dann können wir mal drüberschauen.
Schumis
