Asterisk mit BN8S0 beroNet
blingbling
24 Okt 2006
Hallo!
Kommt hier zufällig jemand aus dem Raum Aachen und hat Ahnung von der Implementierung einer BN8S0 (mISDN) in ein Asterisksystem?
Hab es für mein Abschlussprojekt mal mit der Trixbox 1.2 versucht, aber komme da echt nicht weiter! Die Karte wird erkannt, aber Asterisk startet nicht mehr...:noidea:
Dann wäre ich unendlich dankbar wenn er sich mal mit mir in Verbindung setzen würde! Danke!
Edit Guard-X: Bitte Code statt Quote verwenden!
Parsing /etc/asterisk/asterisk.conf
Parsing /etc/asterisk/extconfig.conf
Asterisk 1.2.12.1, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'show license' for details.
Parsing /etc/asterisk/logger.conf
Asterisk Event Logger Started /var/log/asterisk/event_log
Asterisk Dynamic Loader loading preload modules:
  == Manager registered action Ping
  == Manager registered action Events
  == Manager registered action Logoff
  == Manager registered action Hangup
  == Manager registered action Status
  == Manager registered action Setvar
  == Manager registered action Getvar
  == Manager registered action Redirect
  == Manager registered action Originate
  == Manager registered action Command
  == Manager registered action ExtensionState
  == Manager registered action AbsoluteTimeout
  == Manager registered action MailboxStatus
  == Manager registered action MailboxCount
  == Manager registered action ListCommands
Asterisk Management interface listening on port 5038
  == RTP Allocating from port range 10000 -> 20000
Asterisk PBX Core Initializing
Registering builtin applications:
 [AbsoluteTimeout]
  == Registered application 'AbsoluteTimeout'
 [Answer]
  == Registered application 'Answer'
 [BackGround]
  == Registered application 'BackGround'
 [Busy]
  == Registered application 'Busy'
 [Congestion]
  == Registered application 'Congestion'
 [DigitTimeout]
  == Registered application 'DigitTimeout'
 [Goto]
  == Registered application 'Goto'
 [GotoIf]
  == Registered application 'GotoIf'
 [GotoIfTime]
  == Registered application 'GotoIfTime'
 [ExecIfTime]
  == Registered application 'ExecIfTime'
 [Hangup]
  == Registered application 'Hangup'
 [NoOp]
  == Registered application 'NoOp'
 [Progress]
  == Registered application 'Progress'
 [ResetCDR]
  == Registered application 'ResetCDR'
 [ResponseTimeout]
  == Registered application 'ResponseTimeout'
 [Ringing]
  == Registered application 'Ringing'
 [SayNumber]
  == Registered application 'SayNumber'
 [SayDigits]
  == Registered application 'SayDigits'
 [SayAlpha]
  == Registered application 'SayAlpha'
 [SayPhonetic]
  == Registered application 'SayPhonetic'
 [SetAccount]
  == Registered application 'SetAccount'
 [SetAMAFlags]
  == Registered application 'SetAMAFlags'
 [SetGlobalVar]
  == Registered application 'SetGlobalVar'
 [SetLanguage]
  == Registered application 'SetLanguage'
 [Set]
  == Registered application 'Set'
 [SetVar]
  == Registered application 'SetVar'
 [ImportVar]
  == Registered application 'ImportVar'
 [Wait]
  == Registered application 'Wait'
 [WaitExten]
  == Registered application 'WaitExten'
  == Manager registered action DBGet
  == Manager registered action DBPut
Asterisk Dynamic Loader Starting:
 [format_wav.so] => (Microsoft WAV format (8000hz Signed Linear))
  == Registered file format wav, extension(s) wav
 [format_pcm.so] => (Raw uLaw 8khz Audio support (PCM))
  == Registered file format pcm, extension(s) pcm|ulaw|ul|mu
 [format_au.so] => (Sun Microsystems AU format (signed linear))
  == Registered file format au, extension(s) au
 [format_mp3.so] => (MP3 format [Any rate but 8000hz mono optimal])
  == Registered file format mp3, extension(s) mp3
 [res_musiconhold.so] => (Music On Hold Resource)
  == Registered application 'MusicOnHold'
  == Registered application 'WaitMusicOnHold'
  == Registered application 'SetMusicOnHold'
  == Registered application 'StartMusicOnHold'
  == Registered application 'StopMusicOnHold'
 [res_agi.so] => (Asterisk Gateway Interface (AGI))
  == Registered application 'DeadAGI'
  == Registered application 'EAGI'
  == Registered application 'AGI'
 [res_odbc.so] => (ODBC Resource)
 [res_monitor.so] => (Call Monitoring Resource)
  == Registered application 'Monitor'
  == Registered application 'StopMonitor'
  == Registered application 'ChangeMonitor'
  == Manager registered action Monitor
  == Manager registered action StopMonitor
  == Manager registered action ChangeMonitor
 [res_config_odbc.so] => (ODBC Configuration)
res_config_odbc loaded.
 [res_features.so] => (Call Features Resource)
  == Remapping feature One Touch Monitor (automon) to sequence '*1'
  == Registered application 'ParkedCall'
  == Registered application 'Park'
  == Manager registered action ParkedCalls
 [res_config_mysql.so] => (MySQL RealTime Configuration Driver)
MySQL RealTime driver loaded.
 [res_adsi.so] => (ADSI Resource)
 [res_crypto.so] => (Cryptographic Digital Signatures)
    -- Loaded PUBLIC key 'iaxtel'
    -- Loaded PUBLIC key 'freeworlddialup'
 [res_speech.so] => (Generic Speech Recognition API)
 [res_indications.so] => (Indications Configuration)
    -- Registered indication country 'at'
    -- Registered indication country 'au'
    -- Registered indication country 'br'
    -- Registered indication country 'be'
    -- Registered indication country 'ch'
    -- Registered indication country 'cl'
    -- Registered indication country 'cn'
    -- Registered indication country 'cz'
    -- Registered indication country 'de'
    -- Registered indication country 'dk'
    -- Registered indication country 'ee'
    -- Registered indication country 'es'
    -- Registered indication country 'fi'
    -- Registered indication country 'fr'
    -- Registered indication country 'gr'
    -- Registered indication country 'hu'
    -- Registered indication country 'it'
    -- Registered indication country 'lt'
    -- Registered indication country 'mx'
    -- Registered indication country 'nl'
    -- Registered indication country 'no'
    -- Registered indication country 'nz'
    -- Registered indication country 'pl'
    -- Registered indication country 'pt'
    -- Registered indication country 'ru'
    -- Registered indication country 'se'
    -- Registered indication country 'sg'
    -- Registered indication country 'uk'
    -- Registered indication country 'us'
    -- Registered indication country 'us-o'
    -- Registered indication country 'tw'
    -- Setting default indication country to 'us'
  == Registered application 'PlayTones'
  == Registered application 'StopPlayTones'
 [pbx_loopback.so] => (Loopback Switch)
 [pbx_functions.so] => (Builtin dialplan functions)
  == Registered custom function MD5
  == Registered custom function CHECK_MD5
  == Registered custom function MATH
  == Registered custom function GROUP_COUNT
  == Registered custom function GROUP_MATCH_COUNT
  == Registered custom function GROUP_LIST
  == Registered custom function FIELDQTY
  == Registered custom function REGEX
  == Registered custom function LEN
  == Registered custom function STRFTIME
  == Registered custom function EVAL
  == Registered custom function CDR
  == Registered custom function ISNULL
  == Registered custom function SET
  == Registered custom function EXISTS
  == Registered custom function IF
  == Registered custom function IFTIME
  == Registered custom function ENV
  == Registered custom function DB
  == Registered custom function DB_EXISTS
  == Registered custom function TIMEOUT
  == Registered custom function LANGUAGE
  == Registered custom function MUSICCLASS
 [pbx_spool.so] => (Outgoing Spool Support)
 [pbx_realtime.so] => (Realtime Switch)
 [pbx_dundi.so] => (Distributed Universal Number Discovery (DUNDi))
  == Using TOS bits 0
  == DUNDi Ready and Listening on 0.0.0.0 port 4520
  == Registered application 'DUNDiLookup'
  == Registered custom function DUNDILOOKUP
 [pbx_config.so] => (Text Extension Configuration)
  == Setting global variable 'CALLFILENAME' to '""'
  == Setting global variable 'DIAL_OPTIONS' to 'tr'
  == Setting global variable 'TRUNK_OPTIONS' to 'r'
  == Setting global variable 'DIAL_OUT' to '9'
  == Setting global variable 'FAX' to ''
  == Setting global variable 'FAX_RX' to 'system'
  == Setting global variable 'FAX_RX_EMAIL' to '[email protected]'
  == Setting global variable 'INCOMING' to 'group-all'
  == Setting global variable 'NULL' to '""'
  == Setting global variable 'OPERATOR' to ''
  == Setting global variable 'PARKNOTIFY' to 'SIP/200'
  == Setting global variable 'RECORDEXTEN' to '""'
  == Setting global variable 'RINGTIMER' to '15'
  == Setting global variable 'DIRECTORY' to 'last'
  == Setting global variable 'AFTER_INCOMING' to ''
  == Setting global variable 'IN_OVERRIDE' to 'forcereghours'
  == Setting global variable 'REGTIME' to '7:55-17:05'
  == Setting global variable 'REGDAYS' to 'mon-fri'
  == Setting global variable 'DIRECTORY_OPTS' to ''
  == Setting global variable 'DIALOUTIDS' to '1'
  == Setting global variable 'OUT_1' to 'ZAP/g0'
  == Setting global variable 'VM_PREFIX' to '*'
  == Setting global variable 'TONEZONE' to 'us'
  == Setting global variable 'ALLOW_SIP_ANON' to 'no'
  == Setting global variable 'FAX_RX_FROM' to '[email protected]'
  == Setting global variable 'VM_DDTYPE' to ''
  == Setting global variable 'VM_GAIN' to ''
    -- Including context 'app-recordings-custom' in context 'app-recordings'
    -- Including context 'app-dialvm-custom' in context 'app-dialvm'
    -- Including context 'app-vmmain-custom' in context 'app-vmmain'
    -- Including context 'app-userlogonoff-custom' in context 'app-userlogonoff'
    -- Including context 'app-zapbarge-custom' in context 'app-zapbarge'
    -- Including context 'ext-test-custom' in context 'ext-test'
    -- Including context 'ext-did-custom' in context 'ext-did'
    -- Including context 'ext-local-custom' in context 'ext-local'
    -- Including context 'outbound-allroutes-custom' in context 'outbound-allroutes'
    -- Including context 'outrt-001-9_outside' in context 'outbound-allroutes'
    -- Including context 'outrt-001-9_outside-custom' in context 'outrt-001-9_outside'
    -- Including context 'from-internal-additional-custom' in context 'from-internal-additional'
    -- Including context 'ext-queues' in context 'from-internal-additional'
    -- Including context 'app-recordings' in context 'from-internal-additional'
    -- Including context 'app-dialvm' in context 'from-internal-additional'
    -- Including context 'app-vmmain' in context 'from-internal-additional'
    -- Including context 'app-userlogonoff' in context 'from-internal-additional'
    -- Including context 'app-zapbarge' in context 'from-internal-additional'
    -- Including context 'ext-test' in context 'from-internal-additional'
    -- Including context 'ext-local' in context 'from-internal-additional'
    -- Including context 'outbound-allroutes' in context 'from-internal-additional'
    -- Including context 'custom-speed-dial' in context 'from-internal-trixbox'
    -- Including context 'ext-meetme' in context 'custom-meetme'
    -- Including context 'from-internal-trixbox' in context 'from-internal-custom'
    -- Including context 'from-pstn' in context 'from-trunk'
    -- Including context 'from-pstn-custom' in context 'from-pstn'
    -- Including context 'ext-did-direct' in context 'from-pstn'
    -- Including context 'ext-did' in context 'from-pstn'
    -- Including context 'ext-findmefollow' in context 'from-pstn'
    -- Including context 'ext-findmefollow' in context 'from-did-direct'
    -- Including context 'ext-local' in context 'from-did-direct'
    -- Including context 'parkedcalls' in context 'from-internal'
    -- Including context 'from-internal-custom' in context 'from-internal'
    -- Including context 'ext-fax' in context 'from-internal'
    -- Including context 'from-internal-additional' in context 'from-internal'
    -- Including context 'ext-local' in context 'default'
 [pbx_ael.so] => (Asterisk Extension Language Compiler)
 [chan_local.so] => (Local Proxy Channel)
  == Registered channel type 'Local' (Local Proxy Channel Driver)
 [chan_iax2.so] => (Inter Asterisk eXchange (Ver 2))
  == Registered custom function IAXPEER
  == Registered application 'IAX2Provision'
  == Manager registered action IAXpeers
  == Manager registered action IAXnetstats
  == Using TOS bits 0
  == Binding IAX2 to '0.0.0.0:4569'
  == Registered channel type 'IAX2' (Inter Asterisk eXchange Driver (Ver 2))
  == IAX Ready and Listening
  == Loaded firmware 'iaxy.bin'
    -- Loaded provisioning template 'default'
 [chan_skinny.so] => (Skinny Client Control Protocol (Skinny))
  == Skinny listening on 0.0.0.0:2000
  == Registered channel type 'Skinny' (Skinny Client Control Protocol (Skinny))
 [chan_features.so] => (Feature Proxy Channel)
  == Registered channel type 'Feature' (Feature Proxy Channel Driver)
 [chan_h323.so] => (Objective Systems H323 Channel)
 [chan_phone.so] => (Linux Telephony API Support)
  == Registered channel type 'Phone' (Standard Linux Telephony API Driver)
 [chan_sip.so] => (Session Initiation Protocol (SIP))
  == SIP Listening on 0.0.0.0:5060
  == Using TOS bits 104
  == Registered channel type 'SIP' (Session Initiation Protocol (SIP))
  == Registered application 'SIPDtmfMode'
  == Registered application 'SIPAddHeader'
  == Registered application 'SIPGetHeader'
  == Registered custom function SIP_HEADER
  == Registered custom function SIPPEER
  == Registered custom function SIPCHANINFO
  == Registered custom function CHECKSIPDOMAIN
  == Manager registered action SIPpeers
  == Manager registered action SIPshowpeer
 [chan_misdn.so] => (Channel driver for mISDN Support (Bri/Pri))
[root@asterisk1 cache]# asterisk -gvvvvvvcd
 [AbsoluteTimeout]
 [Answer]
 [BackGround]
 [Busy]
 [Congestion]
 [DigitTimeout]
 [Goto]
 [GotoIf]
 [GotoIfTime]
 [ExecIfTime]
 [Hangup]
 [NoOp]
 [Progress]
 [ResetCDR]
 [ResponseTimeout]
 [Ringing]
 [SayNumber]
 [SayDigits]
 [SayAlpha]
 [SayPhonetic]
 [SetAccount]
 [SetAMAFlags]
 [SetGlobalVar]
 [SetLanguage]
 [Set]
 [SetVar]
 [ImportVar]
 [Wait]
 [WaitExten]
  == Using TOS bits 0
  == Using TOS bits 0
 [chan_misdn.so] => (Channel driver for mISDN Support (Bri/Pri))[/QUOTE]
und...
[OK] found the following devices:
card=1,0x8
[ii] run "/usr/sbin/misdn-init config" to store this information to /etc/misdn-init.conf
Weiß einer weiter?
Schonmal den BeroNet-Support für diese leichte Anfrage bemüht?
foschi
ja foschi aber die ham nix besseres zu sagen als dass ich das problem besser spizifizieren sollte!
Aber foschi, kannst den fred zu machen, problem hat sich gelöst, mit debian sarge und asterisk 2.1.13 läufts einwandfrei, sowohl raus, rein, intern etc...
aber danke dass du wenigstens etwas schreibst!
mfg
und läufts mittlerweile ?
upps !
der tag war dann wohl doch zu lange, sorry habs übersehen ...
