[Info] Asterisk Susceptibility to POODLE Vulnerability
rainer1402
9 Jun 2011
an alle die TLS-SSLv3-fallback zulassen!!!!
Rainer
The POODLE vulnerability – described under CVE-2014-3566 – is described at https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-3566. This advisory describes the Asterisk's project susceptibility to this vulnerability.
The POODLE vulnerability consists of two issues:
1) A vulnerability in the SSL protocol version 3.0. This vulnerability has no known solution.
2) The ability to force a fallback to SSLv3 when a TLS connection is negotiated.
Asterisk is susceptible to both portions of the vulnerability in different places.
1) The res_jabber and res_xmpp module both use SSLv3 exclusively, and are hence susceptible to POODLE.
2) The core TLS handling, used by the chan_sip channel driver, Asterisk Manager Interface (AMI), and the Asterisk HTTP server, defaults to allowing SSLv3/SSLv2 fallback. This allows a MITM to potentially force a connection to fallback to SSLv3, exposing it to the POODLE vulnerability.
Asterisk has been patched such that it no longer uses SSLv3 for the res_jabber/res_xmpp modules. Additionally, when the encryption method is not specified, the default handling in the TLS core no longer allows for a fallback to SSLv3 or SSLv2.
1) Users of Asterisk's res_jabber or res_xmpp modules should upgrade to the versions of Asterisk specified in this advisory.
2) Users of Asterisk's chan_sip channel driver, AMI, and HTTP server may set the “tlsclientmethod” or “sslclientmethod” to “tlsv1” to force TLSv1 as the only allowed encryption method. Alternatively, they may also upgrade to the versions of Asterisk specified in this advisory. Users of Asterisk are encouraged to NOT specify “sslv2” or “sslv3”. Doing so will now emit a WARNING.
Quelle -> http://downloads.asterisk.org/pub/security/AST-2014-011.html
!!! und hier noch ein Online SSL Scanner um ein HTTPS Webinterface zu prüfen !!!
https://www.ssllabs.com/ssltest/
figo12
