Asterisk und Integral 3
PietKlocke
17 Mai 2006
Hallo Leute,
habe folgendes Problem mit meiner Integral3 hinter Asterisk und hoffe auf Hilfe!
Konfiguration:
1. ISDN Anlagenanschluß
2. Asterisk Server mit 2 HFC-S Karten ( 1. Karte im TE Modus und 2. Karte im NT Modus)
3. Crossover ISDN Kabel zum Eingang an die Integral 3
zaptel.conf
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
span=2,1,3,ccs,ami
bchan=4-5
dchan=6
zapta.conf
[channels]
language=de
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancelwhenbridged=yes
callgroup=1
pickupgroup=1
switchtype=euroisdn
signalling=bri_cpe
echocancel=yes
immediate=no
pridialplan=local
nationalprefix=0
internationalprefix=00
overlapdial=yes
disallow=all
allow=ulaw
allow=alaw
group=1
context=local
channel => 1-2
signalling=bri_net_ptmp
group=2
channel => 4-5
Ausgabe beim Start von Asterisk
Asterisk Ready.
*CLI> May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 64
== Primary D-Channel on span 1 up
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 65
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 66
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 67
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 68
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 69
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 70
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 71
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 72
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 73
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 74
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 75
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 76
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 77
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 78
May 18 14:26:00 WARNING[6166]: chan_zap.c:8498 zt_pri_error: 2 TEI remove TEI = 79
== Restart on requested on entire span 1
Die Auswirkung ist das ich über die Integral kein Amt bekomme.
Wenn ich aber anstatt der Integral eine andere TK ( z.bsp. T-Concept XI521) oder ein ISDN Telefon anschließe funktioniert das ganze Fehlerfrei.
Da ich gelesen habe das es hier Leute gibt die es schon geschaft haben eine Integral hinter Asterisk zum laufen zu bekommen, hoffe ich auf euere HILFE!
MfG
Piet
Also die Stichworte sollten dich auf die richtige Lösung bringen:
Das passt nicht!
Olaf
Danke, hat funktioniert, warum ich den Fehler selber nicht gefunden habe weiß ich auch nicht so genau.
Dafür habe ich jetzt ein neues Problem, wie kann man die IRQ´s der Zaptel Treiber ändern. Die sharen sich bei mir mit meinen Soundkarten, Netzwerkkarten und USB Treibern. Das führt ab und zu zum totalen Stillstand :( des Rechners.
Mfg
Piet
PietKlocke Dafür habe ich jetzt ein neues Problem schrieb:
Das geht nur über das Bios, wenn du dort IRQ zu Slot zuweisen kannst.
Wenn du eine HFC-Karte alleine auf einen IRQ bekommst, hilft dir uU der Florz-Patch, dann brauchst du für alle Hfc nur noch einen IRQ.
Asterisk Integral3
Guten Abend,
habe mir jetzt eine 3. ISDN Karte eingebaut und habe nun wieder einen kleinen Fehler.
Zaptel.conf
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
span=2,1,3,ccs,ami
bchan=4-5
dchan=6
span=3,1,3,ccs,ami
bchan=7-8
dchan=9
Zapta.conf
[channels]
language=de
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
callgroup=1
pickupgroup=1
switchtype=euroisdn
signalling=bri_cpe
echocancel=yes
immediate=no
pridialplan=local
nationalprefix=0
overlapdial=yes
disallow=all
allow=ulaw
allow=alaw
group=1
context=local
channel => 1-2
signalling=bri_net
group=2
channel => 4-5
group=3
channel => 7-8
/proc/zaptel/1
Span 1: ZTHFC1 "HFC-S PCI A ISDN card 0 [TE] layer 1 ACTIVATED (F7)" AMI/CCS
1 ZTHFC1/0/1 Clear
2 ZTHFC1/0/2 Clear
3 ZTHFC1/0/3 HDLCFCS
/proc/zaptel/2
Span 2: ZTHFC2 "HFC-S PCI A ISDN card 1 [NT] layer 1 ACTIVATED (G3)" AMI/CCS
4 ZTHFC2/0/1 Clear
5 ZTHFC2/0/2 Clear
6 ZTHFC2/0/3 HDLCFCS
/proc/zaptel/3
Span 3: ZTHFC3 "HFC-S PCI A ISDN card 2 [TE] layer 1 ACTIVATED (F7)" AMI/CCS
7 ZTHFC3/0/1 Clear
8 ZTHFC3/0/2 Clear
9 ZTHFC3/0/3 HDLCFCS
Konfiguration:
1. Karte Verbindung zum NTBA
2. Karte Eingang Integral
3. Karte S0 Port Integral
Fehler:
jetzt kommt auf der 3. Karte wieder
Primary D-Channel on span 3 down
Frage:
muß ich das Kabel von der 3. Karte auch wieder kreuzen?
welche Einstellungen muß ich in der Zapta.conf machen
muß ich den Zaptel Treiber neu kompilieren?
MfG
Piet
erledigt: Asterisk Integral3
Der Fehler lag in der Zapta.conf
MfG
Piet
Moin,
dann schreib doch mal den Fehler hier in den Thread. Dann können später andere davon lernen!
Olaf
Guten Morgen,
für alle die es interessiert die bereinigte Zapta.conf wurde von mir schon unter dem Thread "Asterisk Mehr und Anlagenanschluß" gepostet.
Der Fehler war bei mir ein Denkfehler.
MfG
Piet
Callendaar
