Asterisk v1.4 Probleme
Huflatisch
20 Mrz 2006
Hey
Habe gedacht ich spiel mir mal die v1.4 auf (wegen dem WEB-GUI). Funktioniert aber nicht so richtig.
Ein reload bringt mir diese Fehlermeldungen. Könnt mir jemand einen Tip dazu geben was da schief läuft
linux:~ # asterisk -r
Asterisk 1.4.0, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 1.4.0 currently running on linux (pid = 31530)
linux*CLI> reload
[Feb 28 11:56:32] NOTICE[32401]: cdr.c:1092 do_reload: CDR simple logging enabled.
[Feb 28 11:56:32] NOTICE[32401]: indications.c:505 ast_unregister_indication_country: Removed default indication country 'us'
[Feb 28 11:56:32] WARNING[32401]: res_smdi.c:746 reload: No SMDI interfaces were specified to listen on, not starting SDMI listener.
[Feb 28 11:56:32] NOTICE[32401]: app_playback.c:455 reload: Reloading say.conf
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3859 pbx_load_module: Starting AEL load process.
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3866 pbx_load_module: AEL load process: calculated config file name '/etc/asterisk/extensions.ael'.
[Feb 28 11:56:32] WARNING[32401]: ael.y:205 ael_yyparse: ==== File: /etc/asterisk/extensions.ael, Line 112, Cols: 34-34: Warning! The empty context ael-dundi-e164-canonical will be IGNORED!
[Feb 28 11:56:32] WARNING[32401]: ael.y:205 ael_yyparse: ==== File: /etc/asterisk/extensions.ael, Line 120, Cols: 34-34: Warning! The empty context ael-dundi-e164-customers will be IGNORED!
[Feb 28 11:56:32] WARNING[32401]: ael.y:205 ael_yyparse: ==== File: /etc/asterisk/extensions.ael, Line 128, Cols: 33-33: Warning! The empty context ael-dundi-e164-via-pstn will be IGNORED!
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3874 pbx_load_module: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Feb 28 11:56:32] WARNING[32401]: pbx_ael.c:816 check_includes: Warning: file /etc/asterisk/extensions.ael, line 141-145: The included context 'ael-dundi-e164-canonical' cannot be found.
[Feb 28 11:56:32] WARNING[32401]: pbx_ael.c:816 check_includes: Warning: file /etc/asterisk/extensions.ael, line 141-145: The included context 'ael-dundi-e164-customers' cannot be found.
[Feb 28 11:56:32] WARNING[32401]: pbx_ael.c:816 check_includes: Warning: file /etc/asterisk/extensions.ael, line 141-145: The included context 'ael-dundi-e164-via-pstn' cannot be found.
[Feb 28 11:56:32] WARNING[32401]: pbx_ael.c:816 check_includes: Warning: file /etc/asterisk/extensions.ael, line 276-283: The included context 'ael-parkedcalls' cannot be found.
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3877 pbx_load_module: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3879 pbx_load_module: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3882 pbx_load_module: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Feb 28 11:56:32] WARNING[32401]: pbx.c:6194 ast_context_verify_includes: Context 'ael-local' tries includes nonexistent context 'ael-parkedcalls'
[Feb 28 11:56:32] WARNING[32401]: pbx.c:6194 ast_context_verify_includes: Context 'ael-dundi-e164-local' tries includes nonexistent context 'ael-dundi-e164-canonical'
[Feb 28 11:56:32] WARNING[32401]: pbx.c:6194 ast_context_verify_includes: Context 'ael-dundi-e164-local' tries includes nonexistent context 'ael-dundi-e164-customers'
[Feb 28 11:56:32] WARNING[32401]: pbx.c:6194 ast_context_verify_includes: Context 'ael-dundi-e164-local' tries includes nonexistent context 'ael-dundi-e164-via-pstn'
[Feb 28 11:56:32] NOTICE[32401]: pbx_ael.c:3885 pbx_load_module: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
linux*CLI>
cu Huflatisch
Ein paar mehr Infos bräuchten wir hier schon um dir weiterzuhelfen. Kann es sein dass du die extensions.conf verändert hast, z.B. die Dundi Einträge gelöscht aber noch ein include für diese Einträge drin gelassen hast?
Poste mal deine extensions.conf und deine sip.conf.
Hey
Sorry ....
Ist genau nach Anleitung gemacht http://www.ip-phone-forum.de/showthread.php?t=91217
sip.conf
[general]
context=default ; Default context for incoming calls
bindport=5060 ; UDP Port to bind to (SIP standard port is 5060)
bindaddr=0.0.0.0 ; IP address to bind to (0.0.0.0 binds to all)
srvlookup=yes ; Enable DNS SRV lookups on outbound calls
[30]
callerid=Phone 30 <30>
host=dynamic
domain=0.0.0.0
nat=yes
type=friend
user=30
secret=geheim
mailbox=30
canreinvite=no
[31]
callerid=Phone 31 <31>
host=dynamic
domain=0.0.0.0
nat=yes
type=friend
user=31
secret=geheim
mailbox=31
canreinvite=no
[32]
callerid=Phone 32 <32>
host=dynamic
domain=0.0.0.0
nat=yes
type=friend
user=32
secret=geheim
mailbox=32
canreinvite=no
[33]
callerid=Phone 33 <33>
host=dynamic
domain=0.0.0.0
nat=yes
type=friend
user=33
secret=geheim
mailbox=33
canreinvite=no
extensions.conf
[general]
static=yes
writeprotect=no
[echotest]
exten => 99,1,answer
exten => 99,2,wait,1
exten => 99,3,playback,demo-echotest
exten => 99,4,echo
exten => 99,5,playback,demo-echodone
exten => 99,6,hangup
[lokal]
exten => _3X,1,NoCDR()
exten => _3X,n,Dial,SIP/${EXTEN}|55|Ttr
[default]
include => lokal
include => echotest
Bei der 1.4 kann wohl die anleitung nicht mehr verwendet werden ?
cu Huflatisch
Bei dir wird noch die extensions.ael geladen. Diese hat bei 1.4 Vorrang vor der .conf. Entweder diese ausmisten oder, wenn du ael gar nicht nutzen willst:
modules.conf
noload => pbx_ael.so
Gruss,
Sachmet.
IchBinEsDoch
